Old 04-23-2007, 03:23 PM   #1
Default Shock Oil Weight
Hi guys,
I'm getting ready to rebuild the shocks in me Team Associated T3 and I was wondering what weight oil I should use. If you go to www.medinarcraceway.com you can see pictures of the current track layout. There are quite a few jumps and sharp turns. Being new to this I don't know what weight I should start with as a baseline.
Bohh is offline   Reply With Quote
Old 04-23-2007, 05:09 PM   #2
20 SMOKE's Avatar
Trader Rating: 100 (100%+)
from what i have seen on setup sheets and what other people have used oil has been between 35-25. i use 30 in my b3
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 04-23-2007, 11:59 PM   #3
WheelNut's Avatar
Send a message via MSN to WheelNut
I would start with AE 30wt oil all around with #2 pistons up front and #1 pistons in the rear.
•Brad Comis
WheelNut is offline   Reply With Quote
shock weight? leigh18 Electric Off-Road 3 05-15-2008 09:29 AM
1/5 scale F1 shock absorber oil weight?? LuisR Oval, Larger Scales and More 3 04-15-2008 05:31 AM
Shock Oil Guru's: Weight diff between brands? dizzy1 Electric On-Road 5 03-14-2005 08:35 AM
Shock Oil Weight Conversion jeffreylin Electric On-Road 4 03-29-2004 02:34 AM
Shock oil weight for a TC? 88Camry Electric On-Road 2 11-26-2002 06:27 AM
SEO by vBSEO 3.5.0
