Old 04-17-2007, 12:25 PM   #1
dsl's Avatar
Default Throttle/Brake Linkage Setup
What is the correct order to setup throttle and brake linkage in a 1/8 scale truggy (MBX5T).
...I did a search and could not find any answers.
Thank you
dsl is offline   Reply With Quote
Old 04-17-2007, 01:36 PM   #2
kdub's Avatar
1-Turn on electronics and transmitter.
2-Set servo horn (using sub trim) to run parallel to chassis centerline.
3-Set preload on throttle spring to keep carb shut at idle.
4-Set collar on back side of throttle with about 0.5 mm gap
5-Set brake spring tension collars with about 1 mm gap between the end of the spring and the collar when you pull the cams toward the servo to the point where the brakes engage. This will give you some dead band so the brakes aren't engaged at neutral.
Chief Engineer, Schelle Racing Innovations, SchelleRacing.com - Team Associated - Reedy - JConcepts - Sanwa - MIP - StickyKicksRC - UpGradeRC - Darkside Designs
kdub is offline   Reply With Quote
LOSI 8 THROTTLE/BRAKE LINKAGE HELP PLEASE mike williams Nitro Off-Road 3 05-18-2008 08:41 PM
throttle/break linkage setup gflyer_22040 Nitro Off-Road 5 05-05-2008 08:53 AM
Dynamite Pro Tune Throttle/Brake Linkage AndyH5212 R/C Items: For Sale/Trade 0 10-21-2007 10:08 AM
how should throttle/brake linkage sit? cant get right. atebit Rookie Zone 2 10-11-2007 07:00 AM
Jammin .5 Throttle&Brake Linkage tooofast Nitro Off-Road 3 10-04-2007 08:51 PM
SEO by vBSEO 3.5.0
