RC10GT to electric
RC10GT to electric
Here's my electric RC10(GT) Don
It's a Fiegao 380c 13t. The battery is a A123 4s-13.2v. As to why, I wanted a mid-motor 1/10 electric truck. Once I get it wrung out I believe it will be fast enough to run with the gas trucks. Don
nice ride!
why?
because it's a cool fun project. but i'll have to ask why you would put the buggy tires on the front. if your a basher, who cares.
why?
Actually those are an original set of narrow fronts that used to come with the RC10T. I have another set- if they don't work I'll go with the wide ones. Don
Thank you, I still need to test it. Hopefully it will have enough rear traction. All up weight is 65oz. It still appears to have a rearward weight bias. Part of my goal was mass centralization. Don
I've yet to look at KO. The one on the truck is a FP-S9102. Hopefully it will prove adequate. Don
Yes, it is normally used in an airplane wing for the ailerons. It has the additional advantage of always returning to center even when you suddenly let go fo the stick/wheel and the control bounces. Don
