Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 02-22-2009, 07:28 AM   #14971
SuperEk4's Avatar
Originally Posted by Miller_Time View Post
60-70F?
degrees
CRT RCM, slip diff, Neu 1515/3d, HW150
X2CR, slip diff, Neu 1512/2.5D/F, MM
" First 1/8 Ep racing team in singapore "
http://8scaleracers.web44.net
SuperEk4 is offline   Reply With Quote
Old 02-22-2009, 07:37 AM   #14972
SuperEk4's Avatar
i was thinking of a CC Neu 2200kv will it help?
Old 02-22-2009, 08:08 AM   #14973
dangerwr's Avatar
Default 3mm vs. 4mm motor mount screws?
Guys, I have noticed a lot of people talking about modifying their motors to use 4mm motor mount screws. I believe some of the Neu's are shipping with 4mm tapped holes as well.
Are the 3mm motor mounts not holding up? I have been keeping a check on mine and no problems so far. They do not fit inside the Losi motor mount as well the 4mm would but am not going to disassemble and re-tap the Neu in my buggy unless I run the risk of damaging the thing permanently by running the 3mm screws.
I would like to hear what issues people have been encountering. Thanks!
I know the pieces fit.
Associated T4 - Novak GTB 10.5
Associated B4 - Novak GTB 13.5
dangerwr is offline   Reply With Quote
Old 02-22-2009, 08:22 AM   #14974
JAM MaxAmps's Avatar
The only issues I know of are the goofy 3mm threads on the medusa's. They strip real easy. I took mine and tapped it for 4MM and no more worries.
Jason
Jason
MaxAmps Marketing Manager
jason@maxamps.com
www.NitroKillers.com www.MaxAmps.com *Team Terribles Sponsor/Member* Caster Driver
JAM MaxAmps is offline   Reply With Quote
Old 02-22-2009, 09:19 AM   #14975
badassrevo's Avatar
I have run 3mm for 2+ years with no issues at all. I use the Traxxas Revo engine mount 3x10 screws with a captured flat and lock washer. They work really well.
www.casterracingusa.com - Caster Racing USA
www.maxamps.com - MaxAmps Batteries
www.paintmonsterairbrushing.com - Paint Monster Airbrushing
www.BFastrc.com - Feel the Diff
badassrevo is offline   Reply With Quote
Old 02-22-2009, 09:35 AM   #14976
TeamTekin's Avatar
We have 6 mounting holes on the Tekin T8 motors. We just decided to make 2 of them 4mm and leave the other 4 3mm. The front endbell can be clocked to where ever the user needs for a good mount.
TeamTekin is offline   Reply With Quote
Old 02-22-2009, 11:27 AM   #14977
warpig's Avatar
Does anyone know what kind of multi adapter balance board I need for a hyperion charger to charge a zippy pack? One hobbycity is says it has a JST-XH balance plug.
It's a new day! :)
PLUG IT IN, TURN IT ON, DRIVE!!! MAN, I LOVE ELECTRIC.
warpig is offline   Reply With Quote
Old 02-22-2009, 12:07 PM   #14978
dangerwr's Avatar
This one?
http://www.maxamps.com/proddetail.ph...-ALIGN&cat=212
I just gave one of these away with the balancer I just sold .
Old 02-22-2009, 12:16 PM   #14979
kvrc's Avatar
Jason
yes a few months ago medusa had a bad production run with their mount threads being sloppy. i had a 36 60 2000 motor with this problem and they took care of me no problem.
kvrc is offline   Reply With Quote
Old 02-22-2009, 12:53 PM   #14980
Waters's Avatar
3mm motor mount suck azz. If you are useing the losi motor mount. 3mm bolts would not hold even with lock tight. track has big 30ft flying big jumps, and you start to do some chassis slapping. drill and tap my NEU to 4mm. No more problems.
Waters is offline   Reply With Quote
Old 02-22-2009, 01:01 PM   #14981
rexiphi's Avatar
tried finding it on CC's website with no luck...
what motor mount size (3mm or 4mm) does the CC-Neu motors have?
rexiphi is offline   Reply With Quote
Old 02-22-2009, 01:16 PM   #14982
dangerwr's Avatar
To the best of my knowledge the "NeuCastle" combos use 3mm. Look here and a guy did a complete pictorial of the process he used to drill and tap for 4mm.
Old 02-22-2009, 01:25 PM   #14983
The Castle Neu is 3mm, it feels plenty strong to me on the Losi mount. Make sure you use the plastic rear support and you should be fine.
Linkdead is offline   Reply With Quote
Old 02-22-2009, 01:37 PM   #14984
warpig's Avatar
This one?
I have no idea if that is the correct one. I don't know what a JST-XH connector is. Hyperion has several different adapter boards. I was just hoping someone knew which one is correct for the zippy packs.
It's a new day! :)
Old 02-22-2009, 01:39 PM   #14985
Trader Rating: 114 (100%+)
Are there no conversion kits made for the mbx6 yet?
hemi4me is offline   Reply With Quote
Forum Jump
Official: Novak's 1/8 Scale Nitro to Electric Conversion Kits NovakTwo Electric Off-Road 1132 09-30-2009 12:41 AM
Savage X Conversion Kits!!! speedzonerc.com Speedzone Hobbies 2 02-20-2009 06:10 AM
Novak 1/8th Scale Electric Conversion Kit Craps Electric Off-Road 295 12-16-2008 05:44 PM
1/8 Scale Electric Conversion Items, Nitro Items, Charger, Balancer, Truck Tires, etc Cain R/C Items: For Sale/Trade 14 03-03-2008 06:59 AM
WTB any conversion kits for FT TC3 TheRaven R/C Items: Wanted to Buy 1 09-17-2003 04:59 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
