You want to tone your motor down just don't pull trigger so far back
I might have to try this idea . I have the trigger somewhat reversed on my touring car. I have to push my finger forward for full throttle. Since it is a little more unnatural I tend to stay out of the throttle a little more. Ok, that was a lie--does not matter which way the throttle trigger is configured--I mash it all the way whenever I can .
I know the pieces fit.
Associated T4 - Novak GTB 10.5
Associated B4 - Novak GTB 13.5
Hi, my mmmv3 is under repair at CC, but I still want to race, can I use my airplane/boat hobbywing 100amp (3.1version) esc put a fan n heatsink n put it in my 1/8 truck? It can handle up to 6s 120amp burst.
Will it work?
CRT RCM, slip diff, Neu 1515/3d, HW150
X2CR, slip diff, Neu 1512/2.5D/F, MM
" First 1/8 Ep racing team in singapore "
http://8scaleracers.web44.net
Finally finished my D8. Its running a Mamba Monster ESC, Neu 1512/3D, and a Neu 4300 5s pack. Haven't even gotten a chance to run it yet, but I'll let you guys know how it does.
* Mugen MBX6T -- TEKNO Conversion -- Tekin 1700kv System on 5S
* Losi E-8ight-B 1.8 -- TEKNO Conversion -- Tekin 1900kv System on 5S
* Mugen EMBX5 Prospec -- Castle Creation MMM 2200kv System on 4S
* Xray M18 -- Castle something on 2S
* EMBX6 in HD action and E-8ight-T 2.0 in HD action: just YOUTUBE(teeforb)
How well does the Losi heat sink fit the Neu motor?
Jus as good as a fan.
fan temps 125
heat sink temps 125
it was about 60 degrees out side. The real test is when it gets a little hotter out here....
Yah, I was thinking this too. The only problem is that there are two cutouts under the battery tray to put the straps, which is where the current straps are. I'll think of something though. Thanks for the recommendation!
I too use the Mike's RC-Monster tray in my 1/8th on-road conversion. I am also looking for a way to add more velcro--not as important as off-road but do not want to damage a $200+ Lipo nonetheless.
Impakt/Tekno RC sells their velcro battery strap separately and was wondering if there was a way to get it to fit onto the RCPD tray?
Got to the track for the first time today with my new rc8t electric. Man this thing is awesome. I can't belive how much power it has and very easy to drive. Turns in awesome , jumps are easy and the truck is very stable.
I freakin love it..
Later Rob
Associated T4 ,Tekin RS PRO 7.5 , thunder power 40c 2s 5000mah , 20/84 gears
Jconcepts J82 , mamba max 5700 , thunder power 40c 5000mah , 18/87
Factory Team RC8T mamaba monster , losi 2100kv motor , zippy 5s 5000mah H , 15/46 plastic spur.
Lots of helis and airplanes
