Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 02-03-2009, 03:06 AM   #14251
SuperEk4's Avatar
hi, I recently short a 9xl motor, feigao china email me saying that I may hv over amp d motor how can that be? I m using 14 pinion on 62 spur,mmmv3 n on 4s 5000 25c lipo?
Just 1 run it was short? Anyone can advise me on this?
CRT RCM, slip diff, Neu 1515/3d, HW150
X2CR, slip diff, Neu 1512/2.5D/F, MM
" First 1/8 Ep racing team in singapore "
http://8scaleracers.web44.net
SuperEk4 is offline   Reply With Quote
Old 02-03-2009, 04:56 AM   #14252
jhautz's Avatar
Originally Posted by mickrcarver View Post
lets see some pics of xray 808 brushless conversions,anyone using the hv maxx pro system in one?
Originally Posted by Customworksking View Post
2nd that i have a 808 on the way
Here are a couple of old pictures of mine. It looks quite a bit different now from changes made allong the way, but it should give you a basic idea. Also look in the 808 thread. Edumakated posted a couple pictures of his 808 conversion. http://www.rctech.net/forum/5357046-post3391.html
Also here is a link to my photobucket album of my 808 conversion. You can see alot of different things I tried with it. http://s66.photobucket.com/albums/h2...808/?start=all
jhautz is offline   Reply With Quote
Old 02-03-2009, 05:10 AM   #14253
jhautz's Avatar
Default New Neu???
Anyone else seen a Nue with a front endbell like this? I just sent my almost 3 year old 1515/2.5D in to Neu to have the bearings replaced and a generall tune up done. ( noticed the bearings getting a bit loud during a bench test and figured it was due after almost 3 years of running in the dirt. lol)
Anyway, they told me that the motor was too old and they didnt have bearings for that type of motor can any more so they needed to replace the whole can. What I got back was something I havent seen before. It used to be the front and sides of the motor can were one solid piece, this one looks like it has the front screwed into the main part of the can and then a set crew through the side to keep it from unthreading, and the front cover now has both 3mm mount holes and 4mm mount holes in it. I havent seen this before, but most of my neus have been around for a while now so I was just wondering if anyone else has seen this on one of their newer motors. The 4mm mount holes could be good for those using the Losi conversion motor mount that has 4mm holes in it.
Oh Yea... and the front bearing on it is HUGE now compared to the one that was on there.
Old 02-03-2009, 06:08 AM   #14254
mickrcarver's Avatar
Trader Rating: 54 (100%+)
hey Thanks for the pics that gives me some ideas, what battery are you using? how many cells?
www.ovrccc.com
www.speedybillsrc.com
www.nexusracing.com
mickrcarver is offline   Reply With Quote
Old 02-03-2009, 06:13 AM   #14255
robman's Avatar
I just built a FT rc8t and I'm going to run 5s. which motor and pinon do I need? I've read this forum till I couldn't see anymore , wow lot's of info.
Associated T4 ,Tekin RS PRO 7.5 , thunder power 40c 2s 5000mah , 20/84 gears
Jconcepts J82 , mamba max 5700 , thunder power 40c 5000mah , 18/87
Factory Team RC8T mamaba monster , losi 2100kv motor , zippy 5s 5000mah H , 15/46 plastic spur.
Lots of helis and airplanes
robman is offline   Reply With Quote
Old 02-03-2009, 06:14 AM   #14256
jhautz's Avatar
Default Check this 1/10 out!
Check out the layout on this 1/10 4wd buggy. This is what I would love to see in e 1/8. The f/r diffs have the pinion shaft comming out at an upward angle allowing the battery to go under the center driveshaft.
Take this buggy move the motor diff assembly all the way to the back as far as you can and have a single battery go across the chassis under the front drive shaft and then have the servo and Rx box in the front. ESC would sit on the other side of the chassis in the back opposite the motor.
That would be a perfectly balanced layout for a 1/8 e buggy.
Someone make this happen PLEASE!!!!!
http://www.redrc.net/2009/02/exclusi...urango-dex410/
Old 02-03-2009, 06:29 AM   #14257
Cain's Avatar
Trader Rating: 34 (100%+)
I would say use the following link and gear for a top speed of 35 - 40 mph, this is assuming you know what motor you are going to use already of course.
http://scriptasylum.com/rc_speed/_top_speed.html
Well, got my RC8T all dissassembled ready for a good cleaning, and here is what I found:
Anyone seen this happen to anyone before? Conversions or not? I had a crash with a couple of tangled up vehicles about 3/4 down the long straight. this also broke the little plastic front chassis brace part that goes into the front aluminum top plate. (broke this part twice).
Another thing I noticed but I am not sure if its an issue as my RCPD conversion doesn't show this is that when I looked at the RCM motor mount, it has like a very slight curve / bow towards the end farthest from where the center diff goes in. maybe about 1/4" in from the end, if that and ever so slight that you really would be looking for it to notice. Looking at pics from before taking the vehicle out for its first run, it seems like its already there, and I am not sure how I could slightly bow the end like that when the motor was mounted in further than where it occurred. There is no other bowing anywhere on the mount and the motor sits nice and flat still.
Academy GV2 Pro 1/10 Scale Brushless Buggy
Academy STR4 Pro II 1/10 Scale Brushless Sedan
Ofna Hyper 9E 1/8 Scale Brushless Buggy
Old 02-03-2009, 06:42 AM   #14258
badassrevo's Avatar
A friend of mine with a RCM motor mount on a Kyosho lawn darted and bent the motor mount. He tried to straighten it but could never get it right. he ended up getting a RCPD mount. He will never bend it.
www.casterracingusa.com - Caster Racing USA
www.maxamps.com - MaxAmps Batteries
www.paintmonsterairbrushing.com - Paint Monster Airbrushing
www.BFastrc.com - Feel the Diff
badassrevo is offline   Reply With Quote
Old 02-03-2009, 06:59 AM   #14259
Cain's Avatar
do you recall where he bent the mount at? I would think that if the mount bends, it should bend closer to the center of the mount, as that is where the force would be applied around by the the motor.
I'll post pics tonight of what I am seeing.
Old 02-03-2009, 07:09 AM   #14260
jhautz's Avatar
The RC8T handles awesome, but seems like its pretty weak to me. Ive broken quite a few things on mine alreay. Not the motor mount though. Seems like it would take something pretty sever for that to bend. Ive never bent one in any vehicle.
But the chassis braces in the RC8T are junk IMO. Ive bent the rear (looks just like yours), and broken the plastic end on the front brace twice now also. I just ordered the King Headz RC8T chassis braces. Carolinas RC has them in stock (or they did yesterday) Ive also broken the the rear wheel hub uprights like crazy (2 lefts and 1 right) and bent hinge pins like they are butter. I replaced the rear wheel uprights with Kings Headz also and changed out all of the hinge pins for some spare Xray pins I had left over from my XT8 and havent bent one since. I have also broke a steering turnbuckle end and I even snapped the front bumper clean off at last sundays race. Never seen anything like that before. I didnt even hit anything. It was just gone after one of the qualifier heats.
All of this is 3 race days. I didnt break that mant parts on my XT8 in the entire year+ that I owned it!!
The handeling on the RC8T is awesome, the parts quality is crap IMO. I hope I get to the end of the fragile parts soon or this thing wont be around long for me. I dont care if it is fast as hell. If I dont finish the race its no use to me.
(sorry, just venting... I'm actually very annoyed with the AE quality at the moment if you couldnt tell. One the flip side... I did TQ with it Sunday. Never did that with my XT8)
Old 02-03-2009, 07:21 AM   #14261
JAM MaxAmps's Avatar
Yeah jhautz, that about how Cain's day went. I guess it is nice to know it's not anything he did but rather a few weak points that AE needs to address. I hope he gets his figured out because it was insane. Them Nitro boys were doing all they could to keep up with him. i'm hoping to give him a run for the money at the end of the month with my CC 2200kv powered fusion Truggy.
Jason
Jason
MaxAmps Marketing Manager
jason@maxamps.com
www.NitroKillers.com www.MaxAmps.com *Team Terribles Sponsor/Member* Caster Driver
JAM MaxAmps is offline   Reply With Quote
Old 02-03-2009, 08:19 AM   #14262
warpig's Avatar
Someone needs to post pics of an MBX6 converted... I'm really curious..
It's a new day! :)
PLUG IT IN, TURN IT ON, DRIVE!!! MAN, I LOVE ELECTRIC.
warpig is offline   Reply With Quote
Old 02-03-2009, 08:24 AM   #14263
Matt Howard's Avatar
I'm guessing it has the battery where the engine and tank were, with the motor on the other side. Just a guess though Hey Ben!
Team Losi, Horizon Hobby, Express motorsports, BMI racing, Hobbytown Hobbyplex-home of the 2008 carpet nats and 2009 electric offroad nats
Official member of The Guild of Calamitous Intent
Matt Howard is offline   Reply With Quote
Old 02-03-2009, 08:25 AM   #14264
warpig's Avatar
I'll just glue them in place... haha
It's a new day! :)
Old 02-03-2009, 08:26 AM   #14265
Cain's Avatar
Thats good to know at least that its not something special here with what I am doing. I guess I know what to order now for sure and I agree about the handling. Last race was the first time I ever broke anything on the RC8, and the RC8T was the first run when it broke.
By the way, what conversion are you running?
If the vehicle though doesn't shape up even with the braces, have no problem going to something else. sometimes you have to stop the bleeding.
Looking forward to seeing your F8T (Fate?) Jason!
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Forum Jump
Official: Novak's 1/8 Scale Nitro to Electric Conversion Kits NovakTwo Electric Off-Road 1132 09-30-2009 12:41 AM
Savage X Conversion Kits!!! speedzonerc.com Speedzone Hobbies 2 02-20-2009 06:10 AM
Novak 1/8th Scale Electric Conversion Kit Craps Electric Off-Road 295 12-16-2008 05:44 PM
1/8 Scale Electric Conversion Items, Nitro Items, Charger, Balancer, Truck Tires, etc Cain R/C Items: For Sale/Trade 14 03-03-2008 06:59 AM
WTB any conversion kits for FT TC3 TheRaven R/C Items: Wanted to Buy 1 09-17-2003 04:59 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
