Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-05-2008, 08:25 PM   #7351
HEAT's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Colby View Post
I sent mine in two weeks ago, my second one. I called CC's tech people and they told me it would be mid June before they had the parts to repair them with.
My first one died after 10 minutes runtime. I sent it back and received a replacement in 3 days. It wasn't my first repaired, it was a new one off the shelve ... it died after 4 minutes of runtime. I guess they ran out of new ones and now they are waiting for actual parts to repair all the dead ones that have been sent in.
I had about 2hrs of runtime on mine , i did the case mod and put one new fan in it so i sure do hope cc gets the MMM figured out ! I think im going to get a MM and a bec to see how that works .
XXX-4 G+
XXX-CR
XXXT-CR
HEAT is offline   Reply With Quote
Old 06-06-2008, 04:23 AM   #7352
macr0w's Avatar
I haven't taken any pictures yet but, I just set up my MMM with an external bec and wired an Integy fan to the receiver. I also put a bunch of holes in the case infront of the caps.
Let's see how she runs tonight.
www.clearspotrecording.com
macr0w is offline   Reply With Quote
Old 06-06-2008, 04:32 AM   #7353
chewiefttc4's Avatar
Trader Rating: 22 (96%+)
Send a message via AIM to chewiefttc4 Send a message via Yahoo to chewiefttc4
Originally Posted by Apl Hed View Post
hey chewie, what pinion should i run in my associated RC8 with the neu 1512 2D/F ? ill prob be running the neu 5000 mah batt. also what kind of connectors come on the neu 5000 mah batt?
thanx to all for the info
apple
hey apple
i have no experience with the 2 d so i cant truefully help you.
if i had a good guess i would say around a 13 or 14 tooth pinon
High Velocity Racing
renos ragu. tire additives,castle creations,tekin
factory team t4 ,electric converted 3.3 revo
whoever said power isnt everything obviously doesnt own brushless/lipo power
rdub202's pit and marshall
chewiefttc4 is offline   Reply With Quote
Old 06-06-2008, 05:04 AM   #7354
Originally Posted by puddle View Post
Hey, Can someone with a mamba monster tell me if motor breaking can be disabled all together, so no reverse, no brake at all in the mamba.
As I only have spektrum HRS in my 3pk I only have 2 channels and I am going to have to Y-cable mix throttle and brake. This is because I want to use physical brakes in my 1/8th convert.
Thanks for any information.
Go a head and try if you need to... but over and over again in this thread. Guys have concluded that it is not a necessary arrangement. Even NOVAK had their cars set up like that at first and then concluded is was not needed and went away from the design.
www.rcproductdesigns.com
Electric 1/8th scale conversions
Washtenaw RC Raceway Michigans Biggest and Best Indoor Dirt Racing.
Tekin RX8
Portland RC Raceway
DJ1978 is offline   Reply With Quote
Old 06-06-2008, 05:28 AM   #7355
jfruge's Avatar
That is what I did for now. I canceled my first MMM order and got 2 of the MM's and CCBEC's and they are working great so far. I have not needed to add fans or the novak cap's yet (I did buy them). I am going up a tooth on gearing this weekend so I will see how it goes. Also it was quite cool here @ the night race 2 weeks ago.
Fun Fun,
John Fruge
Madera, CA
jfruge is offline   Reply With Quote
Old 06-06-2008, 06:33 AM   #7356
HEAT's Avatar
When you hook up a bec you hook the red and black wire to the deans that goes on the battery wires that come off the esc correct ???
XXX-4 G+
XXX-CR
XXXT-CR
Old 06-06-2008, 06:45 AM   #7357
Originally Posted by chewiefttc4 View Post
hey apple
For big open tracks, 14T works well. If you are on a smaller track then 13 or 12 should be good. I'm running a 14T on 4S, 1512/2D/smooth in an RC8. This is with the 44T spur.
pullinteef is offline   Reply With Quote
Old 06-06-2008, 07:41 AM   #7358
jfruge's Avatar
Yes, you can tap into the main battery connection @ any location an it should work fine.
John Fruge
Madera, CA
Old 06-06-2008, 07:52 AM   #7359
Cain's Avatar
Trader Rating: 34 (100%+)
Hey guys, due to some issues that have come up and others that still stuck around, I won't be able to do an RC8 conversion at this time and will be going down to one vehicle for the rest fo the offroad season.
Because of this, I will be selling a variety of conversion stuff, namely the following:
- New RC8 Less fuel tank and motor mount (also has the extra shim kit ready to install, plus the service pack ready to install)
- PolyRC 6000mah 25C 4S pack New, added deans connector
- Variety of Mod1 Pinions, several of them brand new RC Monster ones never ran. Would say the range is from 12T - 19T pinions.
Also, depending if Dan isn't able to do a refund on the RC8 conversion, I will have a New one with two spur gears as well.
I may also sell my 1512 2.5D motor to get a Medusa one as its cheaper (if anyone wants to work a swap on that let me know)
I will also have a variety of tires, etc. for sale too.
Academy GV2 Pro 1/10 Scale Brushless Buggy
Academy STR4 Pro II 1/10 Scale Brushless Sedan
Ofna Hyper 9E 1/8 Scale Brushless Buggy
Old 06-06-2008, 08:16 AM   #7360
TonysScrews's Avatar
Cain,
Email me what pinions you have and brand. I'll probably take them.
Is the 1512 2.5D the old or new style can? Used or new?
Best regards,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
TonysScrews is offline   Reply With Quote
Old 06-06-2008, 08:42 AM   #7361
Cain's Avatar
TonyScrews: I will do that when I get home. The lower range pinions between 12T - 16T (may not have a 15T, need to check) I have to look at and see what they are as I am not sure. the 17T, 18T, and 19T I just purchased from RC Monster.
As for the 1512, I got it with my MBX5 last year, so it probably the older style with the longer shaft.
Old 06-06-2008, 10:19 AM   #7362
(quote)As for battery packs, I have the MaxAmps 4S2P 6000mah HV pack and it is a pinch too tall under the MBX5 body. It pushes it up a bit and I really don't like it. It is also only a 20C pack and with the higher amps the MMM is capable of pulling from the pack you need to be careful not to over discharge the pack ( 80-85% discharge).
maxamps now have 25c packs
Lipo 4200 2S 7.4V Flight Pack
4200mah Capacity
7.4 Volts
45mm X 138mm X 16mm
25C Constant(105 amps)
35C Sustained(147 amps)
60C Burst(252 amps)
231 grams
bring it on is offline   Reply With Quote
Old 06-06-2008, 11:46 AM   #7363
Hi Puddle,
Yes, braking can be disabled on the ESC and you can then run a Y-splitter or better yet, use throttle mixing to control the brake servo. In air handling and corner entry is greatly improved with the use of a clutch and mechanical brakes. Disengaging the motor from the drivetrain has other benefits as well, like lower temps and lower wear on your components. This is a hot topic of debate, but both setups are viable (mechanical brakes / motor brakes).
Tekno RC / Impakt RC
www.teknorc.com / www.impaktrc.com
teknorc is offline   Reply With Quote
Old 06-06-2008, 12:17 PM   #7364
Uncle Cliffy's Avatar
I've been really busy lately and haven't been following this thread as close... I finally have all the pieces to fire up my Losi buggy for the first time but I find it crazy my Monster Maxx may fail as soon as I hit the dirt!
Question is: I know the fan shim mod and the dremeling of the bottom case mod, but it just seems crazy to tear into this controller without ever turning it on. Should I run it, have it break, they do the mods or should I just do them before I even solder my Deans plug?!?
Uncle Cliffy is offline   Reply With Quote
Old 06-06-2008, 01:18 PM   #7365
According to what has been posted, the mods don't protect against the problem. They are just to help the fan work. According to Castle they should fail in minutes if they are defective; however some on here have run and they failed on the second use, some ran and they failed after a few minutes not immediately. I would say, run and see if you have immediate failure, if not shim the fan and run again. If you are one of the lucky ones, you may not have a failure. If you do, return it and Castle will make it right but now there is a delay while they are waiting on parts.
nutz4rcyktw is offline   Reply With Quote
Forum Jump
Official: Novak's 1/8 Scale Nitro to Electric Conversion Kits NovakTwo Electric Off-Road 1132 09-30-2009 12:41 AM
Savage X Conversion Kits!!! speedzonerc.com Speedzone Hobbies 2 02-20-2009 06:10 AM
Novak 1/8th Scale Electric Conversion Kit Craps Electric Off-Road 295 12-16-2008 05:44 PM
1/8 Scale Electric Conversion Items, Nitro Items, Charger, Balancer, Truck Tires, etc Cain R/C Items: For Sale/Trade 14 03-03-2008 06:59 AM
WTB any conversion kits for FT TC3 TheRaven R/C Items: Wanted to Buy 1 09-17-2003 04:59 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
