Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-27-2007, 11:40 AM   #301
badassrevo's Avatar
use the 25x25x10 fan.
When you use the UBEC you have to pull the red wire out of the speed control plug.
I also eliminated the switch and use the battery connector as the on off switch.
badassrevo is offline   Reply With Quote
Old 06-27-2007, 04:23 PM   #302
lxmuff's Avatar
On page 9 I have a quick pic of the holes I put on mine. It does help. The MM is at its limit on the buggy and the T is a little heavier. Good luck...
Doug did you try the holes in the MM.
I put them on my second buggies MM too.
Originally Posted by xtremelimits285 View Post
btw guys i live in florida an its been mid 90's out, on my street 6" off the ground its 110-120's.... i have 2 30x30x5's an 1 25x25x10's novak fans what fan is better for the mamba max? also i was thing of putting holes on the side an on the botom of my MM, to help cool the botom fets, but hate to ruin the case, cus i use it for my rc10t3 too(an my 8T)...
how hot is it when u guys run ur mamba's?
btw i got the same ubec u have badass...
lxmuff is offline   Reply With Quote
Old 06-27-2007, 05:29 PM   #303
badassrevo's Avatar
I have drilled holes in the case. I also drilled holes in the bottom and mounted a second fan under the speedo on the bottom side of the diff top plate. I will have to do some test runs to see how it affects the temperature.
Old 06-28-2007, 11:12 AM   #304
Here is my debut EL 1/8 buggy race. Doug you'll have to come up to oakhill so I can have some competition! Three other guys here are in the process of building their El buggies too. I did the same thing you've been doing I qualified 2nd and took the A. Not to bad for never even testing anything out. Just threw it together and spanked!
Part 1 of the A
http://www.youtube.com/watch?v=fEVBD_XeZFQ
Part 2 of the A
I had a buddy take this photo! I couldn't help it, that poor guy spent about 3 min's starting that car, I spent about 3 milliseconds!
Here is a pic of my setup.
I ended up smoking the motor right after the A though. If you look close at the setup pic you'll see the motor and heat sink separated some at the back. I think I'm going to use a hose clamp to hold them together. I'm also getting some of that white lithium CPU grease and I ordered some bigger fans to put on the heat sink. I don't want to smoke another motor.
Later
qbayle is offline   Reply With Quote
Old 06-28-2007, 11:19 AM   #305
lxmuff's Avatar
Your first pic there is priceless........................................
Old 06-28-2007, 12:24 PM   #306
Part 1 of the A
Part 2 of the A
Later
What Chassis is that??
DJ1978 is offline   Reply With Quote
Old 06-28-2007, 12:34 PM   #307
annie_himself's Avatar
Send a message via AIM to annie_himself
I think thats a Sportwerks Turmoil Pro.
annie_himself is offline   Reply With Quote
Old 06-28-2007, 12:54 PM   #308
badassrevo's Avatar
Gary,
Looks good. what is the schedule up there and what time do you start. Is mod truck still big?
You will have to let me know when you have your car ready to go. that is a long drive but I would love to come up to Oak Hill again.
Did Mike get his Mugen built yet?
Doug
Old 06-28-2007, 04:41 PM   #309
badassrevo's Avatar
What motor are you running?
Old 06-28-2007, 05:50 PM   #310
trashedmaxx's Avatar
Send a message via AIM to trashedmaxx
Doug
I have everything but the mamba and the fans. I plan on getting the mamba real soon.
trashedmaxx is offline   Reply With Quote
Old 06-28-2007, 05:56 PM   #311
badassrevo's Avatar
What motor did you go with?
Old 06-28-2007, 07:24 PM   #312
Part 1 of the A
Part 2 of the A
Later
Just a hint get some Arctic Silver 7 from COMP USA, don't use the cheapo paste. Or you could get a quality thermal epoxy to eliminate the hose clamps.
EXPRESS MOTORSPORTS
PARMA/PSE
LEGACY HOBBY
TEAM TEKIN
JRS SPEEDWAY
www.jeffbeaule.acnrep.com
jeffb is offline   Reply With Quote
Old 06-29-2007, 07:25 AM   #313
I've finally got the opportunity to convert my 8ight to brushless. I can get some great prices on some castle creations gear. So I'm looking at getting the Mamba Max ESC. Does any of the motors Castle Creations make work for the losi 8ight?
Also, is the Mamba Max ESC still the best choice for the 8ight?
Thanks a lot,
-Mike
Bohh is offline   Reply With Quote
Old 06-29-2007, 08:20 AM   #314
yeah it's the turmoil pro, I'm waiting for the RC8 this fall.
Old 06-29-2007, 08:22 AM   #315
Thanks for the tip on the artic silver 7 I read reviews and was hunting for artic silver 5 but if 7 is out it must be better??? I hope. I think I'm still going with the clamp though and I'm pretty sure i can sqeeze 4 40mm fans on there to. i have the 10,000mah pack so i have some mah to spare, use it if you got it you know.
Forum Jump
Official: Novak's 1/8 Scale Nitro to Electric Conversion Kits NovakTwo Electric Off-Road 1132 09-30-2009 12:41 AM
Savage X Conversion Kits!!! speedzonerc.com Speedzone Hobbies 2 02-20-2009 06:10 AM
Novak 1/8th Scale Electric Conversion Kit Craps Electric Off-Road 295 12-16-2008 05:44 PM
1/8 Scale Electric Conversion Items, Nitro Items, Charger, Balancer, Truck Tires, etc Cain R/C Items: For Sale/Trade 14 03-03-2008 06:59 AM
WTB any conversion kits for FT TC3 TheRaven R/C Items: Wanted to Buy 1 09-17-2003 04:59 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
