Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-17-2007, 06:51 PM   #2251
ccm399's Avatar
I found this after a good amount of searching:
NEU1509F/S
1000 Watts Continuous
2000Watts - 30sec
Max rpm: 60,000
Stator Dia. 1.5"
Magnet/rotor length 0.9"
Shaft: 5mm
Shaft length: .75"
Weight, S 212g, F 225g
Dimensions 2.1"L x 1.56" dia.
Model RPM/Volt Volts Max Amps Efficiency Rm (Ohms) Io
1509/1.5D 4500 7-13 135* 85+ 0.004 3.8
1509/1Y 3600 7-16 105* 87+ 0.004 3
1509/2.5D 2700 7-20 85* 85+ 0.0082 2.5
1509/1.5Y 2400 7-25 65* 87+ 0.007 2
1509/2Y 1820 7-30 55* 87+ 0.018 1.5
*20 sec. at max. voltage. Otherwise, = Watts/your voltage.
NEU1512F/S
1200 Watts Continuous
2500Watts - 30sec
Max rpm: 60,000
Stator Dia. 1.5"
Magnet/rotor length 1.2"
Shaft: 5mm
Shaft length: .75"
Weight: S 280g, F 290g
Dimensions 2.4"L x 1.56" dia.
1512/2D 2600 7-20 125* 86+ 0.006 2.3
1512/2.5D 2000 8-30 85* 86+ n/a n/a
1512/3D 1700 7-35 70* 88+ 0.012 1.5
1512/1.5Y 1900 8-32 80* 86+ n/a n/a
1512/2Y 1400 7-40 60* 88+ 0.015 1.1
But this is still not quite as helpful as the other chart.....I'll keep looking! Plus it doesn't have specs for the 1509 1d
Chris
ccm399 is offline   Reply With Quote
Old 11-17-2007, 07:32 PM   #2252
IR13's Avatar
well i should get atleast 20 minutes outta the 3200kv motor with 6000mah battery packs
-Slash with brushless
-B44 with losi brushless
IR13 is offline   Reply With Quote
Old 11-17-2007, 08:16 PM   #2253
markhat250's Avatar
I have the 3200kv (1512 1.5 d/f....geared 10/46) motor and honestly wish I would have gone with the 2d or possibly 2.5d. This is soley because I run on a smaller track 90% of the time. This is why you have heard me say my motor, or the 1.5d is simply too much. So yeh.....it all depends on who you are talking to or thier conditions. Some on a big track, letting it breath, may love the 1.5d. I have tried it on a bigger track and it puts a smile on my face when I open 'er up It's a friggin rocket!! But for racing, I kinda wish I had a 2.5d 2000kv.
I definitley get over 20 min with my 4S 6000 MAmps.
HOT BODIES /HPI: Blitz, D8, D8T,
JAMMIN: eCRT.5,
ASSOCIATED: B4, B44,
markhat250 is offline   Reply With Quote
Old 11-17-2007, 09:01 PM   #2254
JsnKVA's Avatar
I can't wait to go High Voltage
Google Is cool!
Does any use a Data logger like the Eagle Tree?
8T / 1512 1.5d / MM @ 4s / RCDP / CCbec / React ..... T4 -MM5700 and a lonely modded nitro Savage X racer
JsnKVA is offline   Reply With Quote
Old 11-17-2007, 09:15 PM   #2255
cfwdude's Avatar
derrr.
cfwdude is offline   Reply With Quote
Old 11-18-2007, 03:42 AM   #2256
connyw's Avatar
Originally Posted by ccm399 View Post
Where do you get specs like these?
I have looked at the NEU website but no luck. I am in the process of searching through the RC-Monster website but I thought I would ask on here. I am looking for the same type of data for the 1509 series motors.
Thanks in advance.
Chris
Look at this site
http://www.nesail.com/detail.php?productID=3859
HB Ve8
XRay XB8EC-E
T2 007 EU BL
Ford F-350 + junfac
ASS B4 FT
connyw is offline   Reply With Quote
Old 11-18-2007, 05:00 AM   #2257
lxmuff's Avatar
The data is extracted from Neu's distributor's web page.
http://www.flydma.com/catalog/index.php?cPath=1_2
Thanks in advance.
Chris
Losi 8ight--MMM 2650 Castle
Losi 8T 2.0--Neu 1515 1Y/F MMM V1 or 2200 Castle
Enerland Batteries 5S-5000 Mah or 5S-5000 Turnigy
www.rcproductdesigns.com
Schmutz ist für den Rennsport, asphalt ist für die Anreise
lxmuff is offline   Reply With Quote
Old 11-18-2007, 06:22 AM   #2258
ccm399's Avatar
Thanks for that.
So the other chart is just a couple mathmatical calculations away then (man I must have been out of it last night...).
So moving on, if I were to run a 1509 on 3s (and set the Mamba to not over rev it) I should see 2220 Watts or 2.98 HP.....WOW
Maybe the 1509 1.5d might be better then I don't have to worry about the over-rev and the specs should work out like this 1498 Watts or 2.01 HP on 3s. Of course the above numbers assume 100% eff which is not likely....
Hmmmm
Thanks for all the help guys.
Old 11-18-2007, 07:31 AM   #2259
ccm399's Avatar
So the website lists eff. specs for the motors too so the real world numbers should look like this.
1509 1D on 3s 1909.2 Watts or 2.56 HP Top RPM 60,000 (need to limit RPM in ESC)
1509 1.5 D on 3s 1288.7 Watts or 1.723 HP Top RPM 49,950
1512 1.5D on 4s 1698.3 Watts or 2.28 HP Top RPM 47,360
1512 2D on 4s 1591.0 Watts or 2.13 HP Top RPM 38,480
1512 2.5D on 4s 992.78 Watts or 1.33 HP Top RPM 29,600
Seems the biggest issue with the 1509 1D might be gearing the car. However,
An Xray geared 10/46 (4.6 -1 Ratio) with a 1512 1.5D would hit about 39.05 MPH on 4s
The 1509 1D would need geared 9/52 (5.78 -1 Ratio) to hit 39.39 MPH on 3s
I think a previous post indicated a 9 tooth MOD 1 pinion can be had. It would seem to me that all that extra ratio moving the same weight (actually lighter) car would work out well.
Old 11-18-2007, 08:22 AM   #2260
Hello can you guys please tell me how you come up with this stuff
dont want to sound like a dumb A#$ but you guys realy know your stuff please share
Also has any one tryed a plane ESC the motors are made for planes?
eric l is offline   Reply With Quote
Old 11-18-2007, 09:32 AM   #2261
Plane ESC's have no brakes!!!
Electric 1/8th scale conversions
Washtenaw RC Raceway Michigans Biggest and Best Indoor Dirt Racing.
Tekin RX8
Portland RC Raceway
DJ1978 is offline   Reply With Quote
Old 11-18-2007, 09:59 AM   #2262
ccm399's Avatar
MPH Formula
Motor RPM / Final drive ratio * Tire Circumference (in inches) / 12 / 88 = MPH
So in my example:
1509 1D on 3s reving 60,000RPM
60,000/19.24 * 13.352/12/88 = 39.43 (Must have used a slightly different number for the tire circumference to get 39.39MPH)
Final drive ratio is Primary Ratio (spur/pinion) * Internal ratio (Gearbox)
So for the Xray that would be 52/9 * 3.33 = 19.24 to 1
Make sense?
Chris
Also, these calculations are based on a tire 4.25" in diameter. No tire growth was figured in the equations.
Old 11-18-2007, 04:49 PM   #2263
Bobby Gately's Avatar
Hey guys I haven’t posted in a while been working like crazy and racing 10th scale. I just took a quick test run with my RC8e, I have an idea and I am wondering if any of you guys have though to doing this...... I am considering taking out the center diff, simply making the drive train more like a 10th scale 4wd. I am thinking that I would get better efficiency because I would be putting more of the power to the ground instead of blowing the front tires off the wheels. Have any of you tried this ?? What were your results???
Bobby Gately
www.GATELYAUDIO.com
Clearly The Best!!!!!
Bobby Gately is offline   Reply With Quote
Old 11-18-2007, 04:50 PM   #2264
lanerbrainer205's Avatar
Send a message via AIM to lanerbrainer205
Can someone help me out on a Revo and a Losi 8ight brushless Li-Po electric conversion? I have already found the motor mounts I need at http://www.rc-monster.com/ Also a charger... MRC Super Brain 989. However, I am completely lost when it comes to choosing the motors and speed controls. I am wanting these for racing so they need to be faster thand stock and also need to handle 30-45 minutes of runtime. Please help me!
..............................Pin it to win it!..............................
lanerbrainer205 is offline   Reply With Quote
Old 11-18-2007, 07:03 PM   #2265
Well then you will have a wheely master, it will make the car very uncontrolable. In my opinion there is just as much of a need for a center diff in a electic buggy than a nitro buggy, its not like a center diff is a nitro specific piece, it is there for handling, I realy dont know everything that it helps with, I just know that it will help my electric buggy just as much as anyones nitro buggy. But that is just my opinion.
Nitro syco is offline   Reply With Quote
Forum Jump
Official: Novak's 1/8 Scale Nitro to Electric Conversion Kits NovakTwo Electric Off-Road 1132 09-30-2009 12:41 AM
Savage X Conversion Kits!!! speedzonerc.com Speedzone Hobbies 2 02-20-2009 06:10 AM
Novak 1/8th Scale Electric Conversion Kit Craps Electric Off-Road 295 12-16-2008 05:44 PM
1/8 Scale Electric Conversion Items, Nitro Items, Charger, Balancer, Truck Tires, etc Cain R/C Items: For Sale/Trade 14 03-03-2008 06:59 AM
WTB any conversion kits for FT TC3 TheRaven R/C Items: Wanted to Buy 1 09-17-2003 04:59 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
