Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-03-2009, 09:23 PM   #17491
glassdoctor's Avatar
Originally Posted by RC America View Post
In most cases, qualifying determines the starting grid for the mains. The starting order for each main does not change for each of the triple mains; TQ starts in the 1st stop every round. Points will be awarded for the finish order after each round, and the top score (high or low depending on how the points are awarded) after all three rounds is the winner. If someone wins main 1 and 2, they will have the win guaranteed if it is best 2 out of 3, and it will probably be up to them to run the third round, or sit it out and let everyone battle for overall second place.
Some like the triple mains, some don't. It does help reduce the impact of breaking, or a bad start, etc as it would have to happen multiple times to eliminate someone from contention. Of course, if it is not best 2 out of 3, one bad round will still kill ya!
Bryan
10 minute races also take out the whole issue of run time and battery selection... and what to do about pitting, changing batteries vs. huge heavy packs, etc. I run a 4s 4200 setup.. it's light and works great. I might be trying a 6s 3000 setup again soon... with a little 1300kv motor
glassdoctor is offline   Reply With Quote
Old 07-03-2009, 10:52 PM   #17492
big greg's Avatar
Trader Rating: 42 (100%+)
Originally Posted by DJ1978 View Post
Where do you get them Greg?
the condems? i used heatshrink on the buggy and its lasted since i put the buggy together mid-washtenaw. the truggy came with em, im not sure exactly where to get em
losi 8 T8 2250 "T" MMM
losi 8T 2.0 T8 1550 MMM
hobbycity zippy packs
try em out they arent bad!!!
rcproduct designs rocks!
big greg is offline   Reply With Quote
Old 07-03-2009, 11:57 PM   #17493
TonysScrews's Avatar
Dan,
You can get the CVD Condoms and a lot of other neat products from GMK Supply (Gary NJ).
Gary
GMK Supply
www.gmksupply.com
Great products. Goofy names.
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
TonysScrews is offline   Reply With Quote
Old 07-04-2009, 12:53 AM   #17494
longbill76's Avatar
Here is my latest project, E-MBX6T
Like the E-MP9 I have flipped the diff for a front motor setup, and I also centered the driveline. You will notice that I squeezed everything towards the center for the best balance possible, now there's no uneven weights on the outside like most electric setups.
Please visit my site for more pictures and my other conversions..
www.EliteRCD.com
longbill76 is offline   Reply With Quote
Old 07-04-2009, 05:57 AM   #17495
RC America's Avatar
Absolutely true. I was just pointing out the general application of the triple A mains.
It will be interesting to see where people settle in terms of pack size if the 10min triple A main becomes the norm. Instead of capacity being the key factor to make the longer run times, it will be current handling of smaller, lighter packs that can holdup to the current draw for 10 minutes. A lightweight pack with one of the smaller systems could be a pretty sweet combo on the track. Still plenty of power, but nimble and jump like a gazelle! I could be well under 7lbs with a setup like in my 808. Hhmmmmmm....where's my credit card!
Bryan
RC America is offline   Reply With Quote
Old 07-04-2009, 08:43 AM   #17496
Sylvéris
Guest
Posts: n/a
www.EliteRCD.com
Hi,
I have checked your cars on you website, and I can tell you that you made a really great job ! I love your Lipo and motor configuration ! I'm sure it's one of the best way to well balance our cars ! Congratulations, your assemblies ares really fines ! ( Excuse my for my poor English, I'm French )
Old 07-05-2009, 08:50 AM   #17497
Hey anyon of you guys know which other brands of spurs will fit on my D8 and do any of them other companies make plastic ones? I want to try 1 out if I can find 1.
Caster Fusion pro SA 2200 combo Hitec servo on 4S- Ve8 MMM 2200 system on 4S W/ACE products. Hitec servo, KO EX1-UR 2.4.
Sponsor
GO-ENGINE.COM, GO TECH ENGINES FACTORY TEAM DRIVER
Caster Racing team member, Team terribles
malik is offline   Reply With Quote
Old 07-05-2009, 09:24 AM   #17498
jhautz's Avatar
Bryan
I can easily get under 7lbs with a 5s 3300mah pack setup and make 10 minutes run time in my 808. I was at 7.2lbs with the 5s 4300mah. This might sound crazy... but I actually like the way my car handles with a bigger/heavier pack in it. It just settles it down a bit. When its too light it gets tossed around to much in the rough stuff and it just seems to get better acceleration traction in general when its a little heavier. I'm sure it could be my setup, but so far I am liking the weight a little over 7.25lbs rather than sub 7lbs.
jhautz is offline   Reply With Quote
Old 07-05-2009, 10:04 AM   #17499
Marzac2's Avatar
Not crazy... All of us Tekno guys are seeing the same results. We actually prefer to run our heavier packs, as it just feels more stable and easier to drive fast without getting tossed around, like you said.
It's kinda sad when some guys go to great lengths to lighten up their cars... End result is not going to satisfy.
Losi 8 2.0 Buggy + 1.5 Truggy & Associated SC8
Tekno RC Conversion Kits on all
MMM ESC
LEKTRON "square can" brushless motors
Fully Max - Polyquest - Neu - Flight Power LiPo's
Marzac2 is offline   Reply With Quote
Old 07-05-2009, 11:12 AM   #17500
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
I tell you what sucks!
I got a brushless setup for this season and with all the forum talk at my local track. Only 3 guys have a ebuggy. All the talk about it being a good class. It turns out to be small. Now I am going to have to take out my brushless system and run nitro again.
I was wanting to run both classes but I don't want to buy another buggy just to run with 3 guys. Not sure if it is worth spending 6 or 700 dollars to have 2 class racing.
Mugen10 is offline   Reply With Quote
Old 07-05-2009, 12:21 PM   #17501
kufman's Avatar
I am guessing that your track/club is not open to the idea of running the two together? We run nitro and electric together with a mandatory "fake" pitstop for the electrics and it works out pretty good.
kufman is offline   Reply With Quote
Old 07-05-2009, 12:48 PM   #17502
EVILGRAFX's Avatar
Get them to run the classes together. After you beat the nitro guys a few times, they'll start switching. Just this weekend I overheard two more hardcore nitro guys talk about switching. It won't happen all at once but, it should happen.
EVILGRAFX is online now   Reply With Quote
Old 07-05-2009, 02:21 PM   #17503
B.A. Racer's Avatar
+1 i hear at least 1 nitro guy a week saying he is converting.,..they dont always cnvert but they want to
Team Associated T4 13.5 brushless
Caster EX-1 PRO Tekin RX8/2050
---------DX3R---------
TEAM DRIVER FOR CASTER RACING USA/TEAM TERRIBLES/FASTLANE GRAPHIX
B.A. Racer is offline   Reply With Quote
Old 07-05-2009, 02:35 PM   #17504
What kit did you get??? With the RCPD design it is only a few screws and you can switch back and forth.
Do a Hobby... NOT Drugs
www.rcproductdesigns.com
TC3 "O" V3
Electric 1/8th scale conversions
Washtenaw RC Raceway Michigans Biggest and Best Indoor Dirt Racing.
LAZER Speedway. Race at LAZER, everywhere else is just a parking lot.
MAX AMPS Batteries
Neu Brushless motors.
DJ1978 is offline   Reply With Quote
Old 07-05-2009, 02:54 PM   #17505
Here's my newly converted MBX6. It's still a little bit dirty from racing yesterday. I used a losi battery tray and rc-monster motor mount.
nik77356 is offline   Reply With Quote
Forum Jump
Official: Novak's 1/8 Scale Nitro to Electric Conversion Kits NovakTwo Electric Off-Road 1132 09-30-2009 12:41 AM
Savage X Conversion Kits!!! speedzonerc.com Speedzone Hobbies 2 02-20-2009 06:10 AM
Novak 1/8th Scale Electric Conversion Kit Craps Electric Off-Road 295 12-16-2008 05:44 PM
1/8 Scale Electric Conversion Items, Nitro Items, Charger, Balancer, Truck Tires, etc Cain R/C Items: For Sale/Trade 14 03-03-2008 06:59 AM
WTB any conversion kits for FT TC3 TheRaven R/C Items: Wanted to Buy 1 09-17-2003 04:59 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
