Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-21-2009, 07:04 PM   #17341
B.A. Racer's Avatar
Originally Posted by SuperEk4 View Post
I finally got 3rd place in my local club race vs nitro for 40mins. I did 61 laps
Car CRTx2
esc HW 150
motor medusa 1600v2
RCM Slip diff 50
batt 6s 5000 zippy
I ran 20 mins change batt n spray compress air on motor before running again. Esc was 55degrees, motor 68 degrees only.
First 2 drivers are top drivers. Driving a Ep car helps alot
nice..now just win and tell the nitro people electric is better lol
Team Associated T4 13.5 brushless
Caster EX-1 PRO Tekin RX8/2050
---------DX3R---------
TEAM DRIVER FOR CASTER RACING USA/TEAM TERRIBLES/FASTLANE GRAPHIX
B.A. Racer is offline   Reply With Quote
Old 06-21-2009, 07:12 PM   #17342
SuperEk4's Avatar
Originally Posted by joeling View Post
Wow man congratulations ! Well done !
Regards,
Joe Ling
Thx man it's a big begining for 1/8 electric in Singapore will post d video soon
2 of my ep guys broke down. One univ pin fell out d other burnt d motor.
One of them was running on tekin combo on 2300kv with 4s 5000 but the temp was 115degrees on esc n motor? Mayb gearing or becoz it was 70mm.
Temp went up within 15mins while my medusa 1600 kept cool.
CRT RCM, slip diff, Neu 1515/3d, HW150
X2CR, slip diff, Neu 1512/2.5D/F, MM
" First 1/8 Ep racing team in singapore "
http://8scaleracers.web44.net
SuperEk4 is offline   Reply With Quote
Old 06-21-2009, 07:24 PM   #17343
SuperEk4's Avatar
Yes this race has proven that electric can last 40mins n mayb 1hr. With only 1 pit from 3rd postion I drop to 5th but I hv 20mins to catch up. Within the 20mins many engines failed n error they make n I finally caught up n maintain my postion.
The first n 2nd was too far away with 69 laps n 67. Top 2 drivers in my country.
It was a sweet victory for me
Old 06-22-2009, 12:38 PM   #17344
Here is a question for all you E-guru's you have 2 of the same car BUT 1 of them has had extensive lightening done to it chassis parts ect. Which 1 do make E and which Nitro and why?????
Caster Fusion pro SA 2200 combo Hitec servo on 4S- Ve8 MMM 2200 system on 4S W/ACE products. Hitec servo, KO EX1-UR 2.4.
Sponsor
GO-ENGINE.COM, GO TECH ENGINES FACTORY TEAM DRIVER
Caster Racing team member, Team terribles
malik is offline   Reply With Quote
Old 06-22-2009, 12:39 PM   #17345
kufman's Avatar
Make the electric one from the lighter car because the E-parts will weigh a little bit more than the nitro parts. You will probably end up with two cars that are about the same weight when the conversion is done.
kufman is online now   Reply With Quote
Old 06-22-2009, 12:42 PM   #17346
Jube's Avatar
Trader Rating: 34 (100%+)
+1
Jubal Dike
Avers Electric Co~BCE Speed www.bcespeed.com ~Team Tekin www.teamtekin.com Fastlane Graphix www.fastlane-graphix.com ~JCP RC www.jcp-rc.com ~AVID www.avid.com~Team Terribles
Jube is offline   Reply With Quote
Old 06-22-2009, 01:39 PM   #17347
R-E-A-P-E-R-'s Avatar
I havnt weighed mine but it appears to be lighter than a Nitro 8T...
----- Caster EX-1 - Caster F8T - Caster ZX-1.5R - Caster F18 -----
---------------------------- TEKIN ------------------------------
R-E-A-P-E-R- is offline   Reply With Quote
Old 06-22-2009, 02:25 PM   #17348
Also can any of you recommend a diff fluid setup for a Losi 8T for a large fast trace. Low traction
Old 06-22-2009, 06:15 PM   #17349
Well I been thinking I have the LW and stock chassis and I have the LW parts and the non, I also just accuired a custom LW drivetrain lightened diff cups, spur and ring gears. I was thinking use the LW drive train and the rest of the stock car for nitro, my mills are modded and basically too much anyway. Or just go FULL LW on my E-car and bone stock on my nitro. I may even swap them around here and there to give them both a try and see what I like. But I was thinking the LW drivetrain is good for the E-car also for braking correct? Thats where all the heat comes from. I was looking today and have no Idea where i am going to put that Big azz Speed passion ESC? The Japanese conversion kit will be here tomorrow I will have to see if i can get the wife to throw a pic up for you guys to see.
Sponsor
Old 06-22-2009, 06:31 PM   #17350
badassrevo's Avatar
Bring all your stuff with you this weekend. I will see what I can do for you.
www.casterracingusa.com - Caster Racing USA
www.maxamps.com - MaxAmps Batteries
www.paintmonsterairbrushing.com - Paint Monster Airbrushing
www.BFastrc.com - Feel the Diff
badassrevo is offline   Reply With Quote
Old 06-22-2009, 08:52 PM   #17351
I am hoping to have everything except the battery. Dont know how long it takes to get here. I will just leave it with you if you need it. With all the time between heats we may be okay LOL.
Sponsor
Old 06-23-2009, 12:23 PM   #17352
Well just got the conversion kit and it looks awesome. There is a plate thats in there that I am guessing covers the flywheel hole or something not sure. And it came with a 15 tooth pinion gear beautifully machined mount and the mount and the extra plate both have D8 scribed into them. Now the battery tray is nice too just not sure if the battery I ordered will fit. If its the same as 2 stick packs stacked on top of each other I am golden, but I have to say the battery straps are way to small. They are for a 2 cell pack, well walmart here I come lol.
Sponsor
Old 06-23-2009, 04:12 PM   #17353
Trader Rating: 43 (100%+)
Default what charger and balancer are you running?
I have my 4s lipo setup with my hyperion EOS0606i charger, it only puts out 50 watts so the highest it can charge is at 3amps which takes forever, I tried my friends mrc super brain 989 and that thing charged at 5amps. besides the superbrain which does not have a balancer built in,what is everyone else using? My last resort is to get a superbrain and a balancer, but I had this charger before and did not quite like it.
what charger ac/dc are you using that charges over 3 amps for a 4s lipo 5000 battery and what balancer?
my ideal charger would be one that does it all like my hyperion but I could get one with an external balancer, something with a pricepoint under $150 if possible.
joyride153 is offline   Reply With Quote
Old 06-23-2009, 04:13 PM   #17354
After further examination I saw that the plate actually gets bolted to the battery tray then the plate to the chassis, where is my question.
Sponsor
Old 06-23-2009, 04:33 PM   #17355
jhautz's Avatar
malik, If you can post up some pictures that would be awesome. really interested in seeing the parts in a better photo. Thanks.
jhautz is offline   Reply With Quote
Forum Jump
Official: Novak's 1/8 Scale Nitro to Electric Conversion Kits NovakTwo Electric Off-Road 1132 09-30-2009 12:41 AM
Savage X Conversion Kits!!! speedzonerc.com Speedzone Hobbies 2 02-20-2009 06:10 AM
Novak 1/8th Scale Electric Conversion Kit Craps Electric Off-Road 295 12-16-2008 05:44 PM
1/8 Scale Electric Conversion Items, Nitro Items, Charger, Balancer, Truck Tires, etc Cain R/C Items: For Sale/Trade 14 03-03-2008 06:59 AM
WTB any conversion kits for FT TC3 TheRaven R/C Items: Wanted to Buy 1 09-17-2003 04:59 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
