Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 03-22-2009, 05:07 PM   #15751
R40Victim's Avatar
Some brushless action:
+ YouTube Video
+ YouTube Video
+ YouTube Video
+ YouTube Video
R40Victim is offline   Reply With Quote
Old 03-22-2009, 05:49 PM   #15752
Slokomo's Avatar
Has anyone had their MMM v3 quit on them? My ESC just stoppped working for no apparent reason yesterday. I heard some people have had issues with the on/off switch and and have fixed this by passing it. I tried this but it didn't fix the problem. I wasn't getting any power to the reciever at all. Will Castle cover a repair under warranty? HELP!
Slokomo is offline   Reply With Quote
Old 03-22-2009, 06:02 PM   #15753
stfitzgerald's Avatar
Originally Posted by superlapS15 View Post
Thanks Glassdoctor! Hopefully the motor can be salvaged.
I had this motor all you have to do is slam the shaft straight down on a hard surface like concrete and it will pop right off and when you put it back together just use some shoe goo to put it back together.It worked for me i ran it for another 3 months..
ALL STATE DRIVESHAFT
TEKNO PERFORMANCE PARTS
stfitzgerald is offline   Reply With Quote
Old 03-22-2009, 06:46 PM   #15754
rearviewmirror's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to rearviewmirror Send a message via Yahoo to rearviewmirror
Almost done.. just waiting on new diff bearings.
ARCTIC DOG RACING (Nitro free since 2009)
"Straights are for fast cars, curves are for fast drivers...."
8ight-E / 8ight-TE / T4 / Slash
rearviewmirror is offline   Reply With Quote
Old 03-22-2009, 06:50 PM   #15755
Krio's Avatar
Trader Rating: 67 (100%+)
I had that happen to me several times. It is most likely the bec on the mmm and castle should replace it for no charge.
Panther Racing Tires - RCProductDesigns.com
Bulldawgrc.com - Teamtekin.com
http://www.youtube.com/KriosCrea
Krio is offline   Reply With Quote
Old 03-22-2009, 07:04 PM   #15756
Slokomo's Avatar
Thanks!
Old 03-22-2009, 07:10 PM   #15757
jhautz's Avatar
+ YouTube Video
+ YouTube Video
+ YouTube Video
+ YouTube Video
Nice video. I see some broken rear hubs over the course of the season on that board at the end of that straight.
They should. Send it in to them.
jhautz is offline   Reply With Quote
Old 03-22-2009, 08:24 PM   #15758
Gary NJ's Avatar
Originally Posted by SuperEk4 View Post
As promised a review of Hobbywing 150 amp car esc.
I use it in the turf city Singapore race for nitro buggy n truggy. It burnt, the whole tent smell of the burnt electronics.
I ran 2 heats 10 mins each (temp was 35plus degrees) miss the first to avoid the wet track. All went well was able to get 11 laps in ten mins. Prepared for the 30 mins main, downgraded to a medusa 1600kv motor n plug in a 6s 5000 zippy punch was set at 4, the truck still wheelie at will. Used my program card set the punch to 1. N tried the car again.
Switched on the esc gave out purplish thick smoke, temp went up to 80degrees wires were hot.
I immediately unplug my batt n check wats wrong. The esc caps all burnt. Reason unknown. Emailed hobbywing no reply 2 address bounce back some more.
Let's wait a few days n see wat they say. Was a sad ending. It was a 30min main n I hv the advantage to b in top 3
I thought the Hobbywing/Speed passion ESC was a 4S max unit - could explain why the magic smoke came out when you plugged a 6S pack in.
Gary
GMK Supply
www.gmksupply.com
Great products. Goofy names.
Gary NJ is offline   Reply With Quote
Old 03-22-2009, 08:26 PM   #15759
bradfox2's Avatar
Looks good, I would shorten up those motor wires some though.
your also gonna want to reinforce the radio tray in the front between the servo and the rx box because they always break right there.
Make sure you have velcro on the battery and tray otherwise the battery will smash through the front of the box the first time you lawn dart it.
8ight-E 2.0, Tekin RX8 1350-T, 13/46, 6s zippy/neu power, fut. 4pk
bradfox2 is offline   Reply With Quote
Old 03-22-2009, 08:50 PM   #15760
Shorten the motor wires? Really? I could probably take 1/2-3/4 of an inch out of them, but is it really necessary? I definitely plan on putting a strip velcro on all battery packs. What do you mean reinforce the radio tray? Where exactly does it break?
Old 03-22-2009, 09:09 PM   #15761
joeling's Avatar
My speed run "buggy"
Hopefully good for 89mph (140km/h)
Motor - Teckno Neu 1515 2200kv
ESC - CC MMM
Battery - 6S 20c 5000mah
gearing - 25/46
Regards,
Joe Ling
HN X2 CR OS Speed WC Ti, HN X1 CR Polyquest 5S Neu 1512 2000kv MMM
HN X2 Neu 1515 2000KV Polyquest 5S 6000mah MMM, HN X2 OS Speed WC
Hyper 9e Medusa 2000KV 4S 6000mah MMM, Hyper mini STe Medusa 3300KV 3S 2500mah MM
Savage FLM ext. 5S MMM 8XL, E REVO Medusa 1600KV 6S MMM
Thunder Tiger ST Neu 1515 2000KV Lutach esc 5S 4800mah
joeling is offline   Reply With Quote
Old 03-22-2009, 09:16 PM   #15762
Slokomo's Avatar
I dont see any reason to shorten the motor wires. Its not going to make any difference.
Old 03-22-2009, 09:19 PM   #15763
bradfox2's Avatar
Looks cleaner, less noise, better for electronics.
look at attachment for reinforcing. I use a zip tie around the entire radio tray and servo but you can try some carbon fiber or fiberglass or something where i circled, because that is where the tray WILL break. I have broken two there, and friends have broken a bunch more.
Old 03-23-2009, 01:31 AM   #15764
eXraycer's Avatar
Had a spot of bad luck with my esc. Was pulling it off the mount in my buggy which is just velcro and a cable tie. So anyway I just snipped the cable tie and pulled on the esc to lift it off the velcro as I always do when the case popped apart in my hand and basically totalled the esc. Not sure if I had a good grip on the bottom half of the case but as it ripped apart a component which is hard against the side of the case dropped off the board and the switch wire ripped out the solder tab on the board. Felt like an idiot I tell you. Sheeeez man. That's the stupidist way to total an esc I've ever heard of. Why me? Hope they'll beleive my story. Imagine the tech guy reading the explanation of the problem "I was only cleaning it when it happened." ....... (Technician) "Yeah sure, that's what they all say".
Xray xb8tq, (1:8 ep Buggy). Medusa, Neu, Castle, Enerland, Zippy, Nomadio.
Smartech Traveller (1:6 Buggy). FG, Elcon, Zenoah 26cc.
AE RC18r (stock) + Sportwerks recoil pro 1:14 - Reedy Brushless.
eXraycer is offline   Reply With Quote
Old 03-23-2009, 01:53 AM   #15765
big greg's Avatar
Trader Rating: 44 (100%+)
Originally Posted by pullinteef View Post
The pinion size / punch theory is a myth with brushless motors It will usually have more punch with a bigger pinion if your batteries can push the juice. On the other hand, gearing for the appropriate top speed is still a good idea
thats what i was getting at, with a bigger pinion the tires will spin faster, sooner, resulting in more torque
losi 8 T8 2250 "T" MMM
losi 8T 2.0 T8 1550 MMM
hobbycity zippy packs
try em out they arent bad!!!
rcproduct designs rocks!
big greg is offline   Reply With Quote
Forum Jump
Official: Novak's 1/8 Scale Nitro to Electric Conversion Kits NovakTwo Electric Off-Road 1132 09-30-2009 12:41 AM
Savage X Conversion Kits!!! speedzonerc.com Speedzone Hobbies 2 02-20-2009 06:10 AM
Novak 1/8th Scale Electric Conversion Kit Craps Electric Off-Road 295 12-16-2008 05:44 PM
1/8 Scale Electric Conversion Items, Nitro Items, Charger, Balancer, Truck Tires, etc Cain R/C Items: For Sale/Trade 14 03-03-2008 06:59 AM
WTB any conversion kits for FT TC3 TheRaven R/C Items: Wanted to Buy 1 09-17-2003 04:59 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
