Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 02-22-2009, 10:03 PM   #15001
Default help
I'm running a 4s 5000mah & cc2200kv motor. im only getting about 10 mins max before the voltage cut off kicks in. 15\45 gearing in a 8t. it started today and when i charge the packs back up they only take about 3100mah to get a full charge. my cut off voltage is set at 12volts......PLEASE HELP ps. motor temps are 130ish and im running on a huge track
Thanks,Jay
rc13 is offline   Reply With Quote
Old 02-22-2009, 10:06 PM   #15002
Default hope this helps
ill post a video if it will help you guys diagnose my problem
Old 02-22-2009, 10:23 PM   #15003
Miller_Time's Avatar
Trader Rating: 6 (88%+)
What type of battery and how new are they? It might be that the battery is unable to meet the demand and is dropping below the cutoff threshold under a heavy load.
== Losi 8ight-E 2.0, Losi conversion kit
== Mugen MBX-6
www.WindyHillRaceway.com
www.CarolinasRC.com
www.HobbyStop.com
Miller_Time is offline   Reply With Quote
Old 02-22-2009, 10:36 PM   #15004
Default brand new
I have 2 losi packs and one max amps 5250 30c pack and they all do the same thing
Old 02-22-2009, 10:41 PM   #15005
teeforb's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to teeforb
Thanks,Jay
what is the individual voltage of your lipo pack once the LVC kicks in and when it's fully charged? it should be around 3.2 to 3v fully discharged and around 4.2v fully charged. it sounds like it is either your battery or charger. i think your system is okay. 3100mah / 10 mins is 310 mah/min. that sounds about right for a truggy. ur ESC and motor is good. it's either ur battery or charger...
* Mugen MBX6T -- TEKNO Conversion -- Tekin 1700kv System on 5S
* Losi E-8ight-B 1.8 -- TEKNO Conversion -- Tekin 1900kv System on 5S
* Mugen EMBX5 Prospec -- Castle Creation MMM 2200kv System on 4S
* Xray M18 -- Castle something on 2S
* EMBX6 in HD action and E-8ight-T 2.0 in HD action: just YOUTUBE(teeforb)
teeforb is offline   Reply With Quote
Old 02-22-2009, 11:02 PM   #15006
SuperEk4's Avatar
Originally Posted by Cain View Post
you should be looking into a lower KV motor when running 6S
Ok here's my case I need to race 3 heats of 10 mins n main of 30/45mins
I use medusa 2000kv on 4s 5000. It can last more ten mins with enough speed.
As for d main either I change the motor to 1600kv n to 6s 5000 or use two 4s 5000 batt to run d main wats runs cooler n better?
CRT RCM, slip diff, Neu 1515/3d, HW150
X2CR, slip diff, Neu 1512/2.5D/F, MM
" First 1/8 Ep racing team in singapore "
http://8scaleracers.web44.net
SuperEk4 is offline   Reply With Quote
Old 02-23-2009, 12:25 AM   #15007
Minicooper 35's Avatar
Default JConcepts fits RC8e?
Hi guys
I have a e-Conversion for an RC8 buggy but I cannot get hold of the 'needed' RC8e body. Does anybody knows if I can also use the JConcepts RC8 Scoopless #0040? I have a feeling that the side pods lack a bit of height up front to fit the battery packs under.
Maybe some of you tried this already?
Cheers
Seb
I'm confused. No wait ... Maybe I'm not!?
Minicooper 35 is offline   Reply With Quote
Old 02-23-2009, 02:20 AM   #15008
xsxboy's Avatar
Default ...
Hello i need from help...
please tell me from where can i buy parts for kyosho kanai 2 and kanai 3 ?
If you can please tell me several online shops for parts.
Thank you
xsxboy is offline   Reply With Quote
Old 02-23-2009, 04:55 AM   #15009
Well it could be the LVC triggering too early, but you're right about checking the voltage before and after the charge. Try a stand alone multimeter rather than trust the charger's readout, as it might be wrong.
Also I would confirm the LVC setting, and if it's set correctly you might try changing it, save, then change it back to 12v and save again just to be sure the ESC is getting the correct setting.
Oh and one more thing.. what was the temperature on these runs? The last two times I ran mine in cold weather (below 50F) and didn't keep the batteries warm before the race, my LVC kicked in very early too.
== Mugen MBX-6
www.CarolinasRC.com
www.HobbyStop.com
Old 02-23-2009, 05:03 AM   #15010
badassrevo's Avatar
Thank you
http://shop.ebay.com/items/__kyosho-...Q_kwZ2QQ_ckwZ3
http://shop.ebay.com/items/_W0QQ_dmp...o+k3&_osacat=0
What do you need? Most of the 7.5 and 777 parts will fit
www.casterracingusa.com - Caster Racing USA
www.maxamps.com - MaxAmps Batteries
www.paintmonsterairbrushing.com - Paint Monster Airbrushing
www.BFastrc.com - Feel the Diff
badassrevo is offline   Reply With Quote
Old 02-23-2009, 05:17 AM   #15011
JAM MaxAmps's Avatar
Yes very true, colder temps will drop your packs capacity down which in turn drops the packs C rate. That means the pack cannot handle the normal amp draw that it could when it's warm leading to your LVC tripping.
Jason
Jason
MaxAmps Marketing Manager
jason@maxamps.com
www.NitroKillers.com www.MaxAmps.com *Team Terribles Sponsor/Member* Caster Driver
JAM MaxAmps is offline   Reply With Quote
Old 02-23-2009, 05:46 AM   #15012
Send a message via MSN to afonsospt
Originally Posted by Minicooper 35 View Post
Hi guys
Cheers
Seb
Anyone?
I wonder the same
afonsospt is offline   Reply With Quote
Old 02-23-2009, 06:54 AM   #15013
Jube's Avatar
Trader Rating: 34 (100%+)
Hi guys
Cheers
Seb
Here is where I got my E body from.
http://order.aeteam.net/product_deta...Itemcode=89523
Jubal Dike
Avers Electric Co~BCE Speed www.bcespeed.com ~Team Tekin www.teamtekin.com Fastlane Graphix www.fastlane-graphix.com ~JCP RC www.jcp-rc.com ~AVID www.avid.com~Team Terribles
Jube is offline   Reply With Quote
Old 02-23-2009, 07:06 AM   #15014
warpig's Avatar
Originally Posted by dangerwr View Post
This one?
http://www.maxamps.com/proddetail.ph...-ALIGN&cat=212
I just gave one of these away with the balancer I just sold .
Hey, I wanted to say thank you! I looked closer at the picture and sure enough it says JST-XH right on it. I appreciate the help.
Ben
It's a new day! :)
PLUG IT IN, TURN IT ON, DRIVE!!! MAN, I LOVE ELECTRIC.
warpig is offline   Reply With Quote
Old 02-23-2009, 07:12 AM   #15015
jhautz's Avatar
6s 5000 is only 50% more energy than 4s 5000. If you are only getting 10 minutes on the 4s 5000 I wouldnt expect more than 50% more runtime with a 6s 5000 setup. Maybe slightly more for some minor efficiency gains, but certainly no where near the 30/45 minutes you are looking for.
If I were you Id look for a solid 15-20 minute setup and then plan a pack swap for the 30 minute race and a 2 swaps for the 45 minute race. Also.. Watch your motor temps during those extended runs. Ive seen motors that were running properly overheat when pushed for that long. A fan on the motor would seem like a good idea to me.
jhautz is offline   Reply With Quote
Forum Jump
Official: Novak's 1/8 Scale Nitro to Electric Conversion Kits NovakTwo Electric Off-Road 1132 09-30-2009 12:41 AM
Savage X Conversion Kits!!! speedzonerc.com Speedzone Hobbies 2 02-20-2009 06:10 AM
Novak 1/8th Scale Electric Conversion Kit Craps Electric Off-Road 295 12-16-2008 05:44 PM
1/8 Scale Electric Conversion Items, Nitro Items, Charger, Balancer, Truck Tires, etc Cain R/C Items: For Sale/Trade 14 03-03-2008 06:59 AM
WTB any conversion kits for FT TC3 TheRaven R/C Items: Wanted to Buy 1 09-17-2003 04:59 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
