Mugen MBX5
#31
to be honest i dont know what the p5 runs like does it favor the top or bottom
if i dont race this weekend i may put it on and break it in
i currently use the 053 pipe but i have a 086 thats in so so condition
by the way i have the new p5 with the purple head supposed to be 2.6hp and 31k rpm vs the blue head was 2.1hp and 29k rpm
i was thinking the p5 would be a bottom end engine so i would want a pipe that was good for medium to high rpm right?
#32
Registered User
Do any of you guys know where I can find a new Mugen MBX-4XR??? Changed my mind once again............just can't spend that much on the K2!!!
#33
Originally posted by jason102276
what does the rdlogic pipe give you better top or bottom?
i dont need a whole lot of top end at all the track i race on doesnt give us much room to go fast on
i am very interested in the rdlogic pipe becuase of its price and the fact ive used their onroad pipes for a while with great results
#34
The P5 is an on-road engine (S1 stamped on the crankcase), ported to suit off-road. Being an on-road engine, it is a long stoke. Therefore, the torque curve is more gradual (less bottom end). If it were a short stroke, it would have more bottom end. But, the top end in both short stroke and long stroke is similar. The only difference is how they get there.
I have a CLB long stroke Nova Rossi, which I modified after testing by Nova Rossi and European driver Daniel Vega showed more power and better fuel economy by 1. changing to a larger (on-road) head and turbo button; 2. 25% nitro, 9% oil, 66% methanol & also using the 9886 on-road pipe. These long stroke engines are suited to tracks with less grip as the power comes on more gradually then the short strokes that give you instant power & torque.
The P5 is essentially the CLB modified as above, just reconfigured and sold by Nova Rossi. I know this as I also have a P5. So, if you want more bottom end buy a short stroke eg. SBK and run a 9853 Nova Rossi pipe (good in high grip situations), for slippery tracks run the P5 with 9886 pipe. Give it a go. Let me know. It works Down Under.
#35
my local track is blue groove as long as its dry either way wet or dry it has great traction just alot of bumps and jumps tight turns etc i need torque
so should i run the 053 pipe with it
or a 086 with a waller adapter
#38
do you have any idea about when it could be available here in USA?
#40
i havent been able to test yet the waller adapter should get here today and the servos i need to put my buggy back together should arrive sometime this week
mothers day was sunday so there was no racing last weekend i hope to be able to go this weekend but that isnt 100% either
