Old 03-30-2007, 06:01 PM   #1
aN4rK1's Avatar
Default Starting an engine which hasnt been used for a while
I havent used my Hellfire for about 6 months now, but since the good weather is here iam going to be firing her up again. Is there anything special I should do before I start it? I was panning to get the engine upto temperature by heating it with a heat gun for a bit then starting it. anything else?
aN4rK1 is offline   Reply With Quote
Old 03-30-2007, 07:18 PM   #2
GymBeam's Avatar
all maintenance should of been done BEFORE putting it away so it didnt rust.
provided you ran out all the fuel and had after run oil in there 6 months ago, just start it up like normal
GymBeam is offline   Reply With Quote
Old 03-31-2007, 02:11 PM   #3
aN4rK1's Avatar
Yes I drained out all the fuel before i put it away, and I made sure to put extra after run oil then normal since i wasnt going to use it in a while. Anything else?
Old 04-01-2007, 07:07 AM   #4
amain's Avatar
you should be fine then it may take a little bit to get all the after run oil out while starting but i should fire up no problem. aslo make sure your fule isnt stale
amain is offline   Reply With Quote
Old 04-01-2007, 01:12 PM   #5
It should fire up O.K. If not, and you don't mind pulling it apart, take the backing plate off, (and the plug out) and flush the engine out with some fresh fuel. Just pour a little in the back of the engine, turn the flywheel over a few times, drain it, then put her back together. This will help flush any "gluggy" residue out of the engine and make it easier to turn over.
Some R.C. stuff.
UNSTABLE is offline   Reply With Quote
engine not starting? whitrzac Nitro Off-Road 5 06-27-2008 03:52 PM
Starting Up engine shaun_dini Onroad Nitro Engine Zone 1 02-17-2007 06:45 PM
ENGINE STARTING 32819toon Nitro On-Road 6 02-17-2007 12:56 PM
Need Help with starting up my engine! kmaheartless Rookie Zone 3 01-12-2007 10:41 PM
hpi rs4 3 engine starting srowell3 Nitro On-Road 9 01-09-2007 09:32 AM
SEO by vBSEO 3.5.0
