Old 03-27-2007, 08:40 PM   #1
Default Servo Blowing Problem
Does anyone have a old Novak ESC(410 series) that they still use with newer electronics?
I have a old Novak HPC that I was using with a real old airtronics radio. Everthing worked fine. I understand the old airtronics receivers pin polarities are different than the current receivers. I would change the pins on newly manufactured servos and plug it into the old receiver. It would work for a couple of seconds than the servo blows. I figured it is the receiver blowing the servo.
Next, I replaced the old airtronics reciever with a new spektrum receiver. I plugged in a working JR 590 servo and the Old novak ESC into the spektrum receiver. I turned everything on the throttle worked fine and the servo would not operate. I plugged the servo into another receiver and it no longer works.
Can a speed control Blow a servo? Does anyone know if the old speed controls still be used with new radio equipment?
goat585 is offline   Reply With Quote
Blowing servos jgtruggy Nitro Off-Road 12 04-13-2008 10:14 PM
blowing plugs spudly12 Nitro Off-Road 6 12-28-2007 03:41 PM
Why? (Blowing plugs) Bob Moore Electric Off-Road 8 07-17-2006 12:19 PM
*Servo/PT Problem* tc3blue Electric On-Road 16 08-12-2005 05:48 PM
battery blowing up davioh Electric On-Road 11 04-20-2003 09:55 PM
SEO by vBSEO 3.5.0
