xxx cr rear suspention on a xx4
Has anybody tried this? I was painkillers the other night. (leagle). I was wanting the VLA hubs on my xx4. I tried the BK2 hubs, but they made the dogbones to short. So, wile I was in my drug induced trip. I started looking at my xxx cr rear end. I did some measuring. Wow, if I use the EA3 rear arms and the xxx cr hubs. It would be a direct swap. None of the dimenchions (bad spelling) changed. So I pulled it off of the CR and installed it onto the xx4. I like to run the suspention as wide as I can. This should be perfect. I'm weighting for my 9000s to get back from Horizion. (I cooked it). I hope it will give me more options for adjustability. I hope I didn't do this for no reason.
Doug
Doug
Doug
Doug
With the shorter arm setup you should pick up some forward bite and off power steering.
I thought I was the only one who thought of this. I guess I'm the 1000th one. oh well.
