Like Tree38Likes
Old 12-26-2016, 11:17 AM   #9121
PW
PW's Avatar
Send a message via AIM to PW
Originally Posted by John Myall View Post
Any idea when the B6 laydown motor plate with the built in spur gear guard, that Jason showed in a recent video will be out?
No ETA yet. If I had to guess, February or March.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 12-26-2016, 11:49 AM   #9122
Phillip F's Avatar
Trader Rating: 17 (100%+)
Originally Posted by PW View Post
The F2 is scheduled to debut at the up coming Reedy Race .
Thank you. Ive been retrofitting the B5M finnisher body in my B6 and really love the finnisher style. I was wondering if you guys will do one for the TLR 22-4 2.0 too?
Phillip F is offline   Reply With Quote
Old 12-26-2016, 12:20 PM   #9123
PW
PW's Avatar
I don't think so.
Paul Wynn
Old 12-26-2016, 01:33 PM   #9124
Sweet
X-Factory UK / Carisma Racing/ Corally/ Vampire Racing /TEKIN/ AVID/ JConcepts / Lunsford / Exotek Racing / Hiro Seiko / RDRP / GRP Tyres/ Tuning Haus/ DMSPARTZ / McKune/ RCS Graphic Workz / WTF / DMS Racing / Model Junction
John Myall is offline   Reply With Quote
Old 12-26-2016, 03:17 PM   #9125
Tech Legend
Cain's Avatar
Trader Rating: 239 (100%+)
Unfortunately we haven't run them on carpet yet, but I would think they should be pretty good. When we receive more samples, we will have one of our team drivers test them on carpet ASAP .
Good stuff. Looking forward to hearing more on this tire. Something with a little "tread" like this I would be very curious to try out.
Originally Posted by micrors4guy View Post
when we had a track that had this same rule i found that slicked out green dirtwebs were the best tire and provided the most consistent laps from start to finish. Anything else that we used would fall off toward mid to end of the run because we were required to use sxt 3.0 and they would start to gum up too much.
I used green flip outs as that would be a legal pin here since its not hard and went well, but was used to setup with slicks. Here the traction is pretty high ehough we role with slicks but I am always open to giving new things a try
< HB Racing D413 | Tekno EB48SL / SCT410.3 | Tekno EB410 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 12-27-2016, 04:27 PM   #9126
are the reflex 4wd front tires larger in diameter than the flipout 4wd fronts in wheeler class. seems like I can get more steering with a larger diameter front than rear. I,m trying to run 3d's in the rear and the flipout are smaller
2dialed is offline   Reply With Quote
Old 12-28-2016, 01:09 PM   #9127
PW
PW's Avatar
I haven't measured them, but I'm guessing they are bigger than Flipouts. Also keep in mind that Reflex's are 60mm/2.4 tires/wheels.
Paul Wynn
Old 12-28-2016, 05:18 PM   #9128
i'm getting about 86mm for the 3d's rears with avid rims and red aka foams, the flipouts 4wd fronts are 84.5mm with yokomo rims and red foams. are there any 4wd fronts that are 86mm or larger? the reflex comes in 60mm rims and foams but I figured the sidewall was thinner than 2.2 tires
Old 12-30-2016, 10:30 PM   #9129
Trader Rating: 55 (100%+)
I just bought two pair of blue dirt webs for SCT and they came with the blue inserts are these new or are they the old ones with new tires
SC5M, T5M, B6, TRINITY motors and batteries, hobbywing esc
guppy is offline   Reply With Quote
Old 12-31-2016, 10:11 AM   #9130
OriginalDonk's Avatar
Trader Rating: 41 (100%+)
With Maifield's rumored move to Yokomo it'd be ace to see a YZ-4 body from you guys.
OriginalDonk is offline   Reply With Quote
Old 12-31-2016, 05:41 PM   #9131
Amain said the space bars would be available yesterday but they still say back ordered. I need a new set of tires and wanted to try these. Do you guys have an idea when jconcepts or amain will have these in stock?
racingnewb is offline   Reply With Quote
Old 01-01-2017, 08:48 AM   #9132
Jack Bonhomme's Avatar
I really love using Carvers SCT tires on the front of my 2wd Short Course truck. My current pair are finally wearing out after years of use. I can't seem to find a new pair of Green compound replacements anywhere. However, I do have an old pair in good condition mounted on rims from my older truck. Does anyone know if I can use CA debonder to remove the tires from the rims safely for reuse? What would I have to use to clean off the tire bead in order for them to readhere to a fresh set of rims? There's several of us in the Northeast who still run Carvers so it would be nice if JConcepts would reissue this tire again. Or create a modernized replacement.
YouTube Page: JackBonhommeVideos
Sponsors: FTM Grip, Redline Hobbies, Garcia Graphix
Tracks:Barnstormers, 46RC, R/C Madness
Jack Bonhomme is offline   Reply With Quote
Old 01-01-2017, 09:38 AM   #9133
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Just be patient. Amain probably got them in but it is New Years and probably have holiday hours so check back tomorrow or Tuesday.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 01-02-2017, 06:30 AM   #9134
PW
PW's Avatar
We are probably down to the last few with blue inserts, so they haven't made the switch to the grey yet (this is on blue dirt webs). I'm one of the few guys that like the blue insert . Mount them up on wheels (don't glue) and see how they feel, if they are full and don't have any gap, then they should be really good. If they have a gap and don't feel right, email us and we will get you replacements.
We will see
It's a supply and demand thing; demand is extremely low, so unfortunately supply has been put on the back burner.
If you want to remove the tire from the wheel, put some acetone in a bucket (maybe 3/4 of an inch) and then something (small wire rack) to suspend the tires just above the acetone. Put a lid on the bucket over night and the fumes should debond the glue. Don't let the tire sit in the acetone or it will swell up.
Paul Wynn
Old 01-16-2017, 07:00 AM   #9135
Trader Rating: 24 (100%+)
How long before we can get these Truck Tires?
Associated B6 x2
Associated B64D
Associated B64
Associated T5M
Scott R is offline   Reply With Quote
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 12:04 PM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 09:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 10:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 04:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 07:54 PM
