Like Tree29Likes
Old 11-07-2016, 06:24 AM   #9061
Trader Rating: 119 (99%+)
Paul, do you know when you guys will have more space bars back in stock? Or possibly when they might be hitting the shelves of retailers?
skoalisbad4me is offline   Reply With Quote
Old 11-08-2016, 01:23 PM   #9062
PW
PW's Avatar
Send a message via AIM to PW
Sorry for the delays; just got back into town.
Originally Posted by Cain View Post
for the Associated B6/B6D is this the right body that allows you to run it on both the B6D with its stock transmission and with a laydown setup with the spur gear still protected?
http://www.jconcepts.net/shop/s2-b6-...dy-w-aero-wing
I am looking for a dual use body that i don't need to special cut and basically have the spur exposed when in laydown form.
Thanks!
Unfortunately there isn't a body available that will allow you to run either transmission with only one cutout. You will have to have 2 separate bodies; one for laydown trans and one for stand-up trans if you want the spur completely covered.
Maifield 2wd nationals setup says that he was using 4wd front inserts in his space bars. Is this the preferred way to run space bars or was that track specific?
I think it will be track specific; more or less steering.
What dictates when you run a front wing and how does narrow and wide vary with conditions? Primarily I will run indoor but it's not so much a clay-type base, the soft and super soft compounds seem to be the way most go, so that tells me it's not a true clay track.
Basically the pro guys run the wing 98% of the time now. The only time they take it off is in very low traction conditions.
I personally don't feel much difference with the wing in regards to steering, but feel it makes the car a little more stable high speed.
Hello, which (metric) screws go into the 1:8th scale Inverse wheels and how much are usually used? First time building them, all tips are welcome
2.5x6mm buttonhead
Basically they are coming in bi-weekly and shipping as soon as they come in. We have already shipped to a few dist/dealers, but it was limited quantities. I'm sure it's going to take us a little while to catch up with demand
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 11-10-2016, 06:23 AM   #9063
So do you know when the bi-weekly shipment is going to be? Is that this week or next?
Old 11-10-2016, 06:36 AM   #9064
PW
PW's Avatar
I think we have more coming next week, but not sure how they are allocated. Just a guess, but I'm sure most will ship to Dist/Dealers with a handful offered on the website.
Paul Wynn
Old 11-10-2016, 06:53 AM   #9065
Trader Rating: 16 (100%+)
How tall are the 4wd Swaggers compared to the Rear Pin Downs? My buggy has a center slipper and too big a difference doesnt work well
Associated TC7.1
Associated B6 x2
Associated T5M
Tekno EB48SL
Scott R is offline   Reply With Quote
Old 11-11-2016, 02:59 PM   #9066
iDesign5's Avatar
Is the standard for stadium truck tires still open cell in the front and closed in the rear? Or are guys running c.c. in all 4 corners?
iDesign5 is offline   Reply With Quote
Old 11-14-2016, 05:19 AM   #9067
PW
PW's Avatar
I will have to check on the OD for both.
I don't think that was ever a thing . We have always used the same insert front and rear on truck. Outdoor low-bite we use open-cell and med/high-bite indoor/outdoor use closed-cell.
Paul Wynn
Old 11-14-2016, 06:02 AM   #9068
thecman26's Avatar
Trader Rating: 98 (100%+)
I am running cc all 4, usually firmer in the rear though.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 11-14-2016, 08:32 AM   #9069
iDesign5's Avatar
It was a thing at our old indoor track that closed. That was the standard.
Old 11-14-2016, 08:49 AM   #9070
PW
PW's Avatar
Gotcha...Never heard about that one, but not the craziest thing I've heard . I recommend sticking with the same insert front and rear .
Paul Wynn
Old 11-14-2016, 08:57 AM   #9071
Eli
Eli's Avatar
Hope to get some spacebars soon for my B6 to try.
Eli Westrup - SDRC Raceway - B6D - SC5M - B64D ALL FOR SALE!
Eli is offline   Reply With Quote
Old 11-14-2016, 02:28 PM   #9072
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
got a chance this past saturday to do some running with my B6D (basically a b6 with the parts on it) on carpet for blinky class. As we are not allowed to use hardpin rear tires, I decided to give the JConcepts flipouts a try in combination with the schumacher staggers up front.
Seeing others at the track the common setup seemed to be a clay compound slick with the same front tires. Initially I tried some Proline clay compound "slick" rears sauced with sxt 3.0 compound. The vehicle had a loose rear relative to the grip of the fronts. Probably could tune this out, but was curious to see what a tire swap could do since tires are the most important part of setup.
I went ahead and swapped on the jconcepts flipouts and threw it back on the track. Immediately there was so much grip in comparison but no traction rolling issues. It was to the point I wanted to tune it out slightly to get a tad more rotation.
Wear looked pretty good as well.
I am going to keep giving this setup a go, maybe with a rear sway bar added.
inserts used were AKA reds.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 11-14-2016, 05:46 PM   #9073
Hey guys looking for some input.
So I did a search on "Splitters" and didn't really get the info I was after. So my local indoor track is not your typical "Clay" track. They do keep a decent amount of moisture in it but the surface never really gets tacky. We share the track with 1/8 scales and truggies so there can be some dust on the track.
So far Black or Green Dirt Webs with LW for traction compound are pretty good. The fastest laps have been turned by drivers with M4 Electrons and Duck Sauce (sorry, I know this is a JC thread). I have also tried Black Bar codes (broken to about 2/3rd height) and they are not so good, Dirt Webs are better for sure.
My Black Dirt Webs are worn too far to work now so I am wondering if green or black Splitters might fit the bill better.
Thoughts?
Thank you,
Chris
BFast www.BFastrc.com "Feel the Diff"!
NORCAR www.norcarracing.com
Medina R/C Raceway Find us on Facebook!
ccm399 is offline   Reply With Quote
Old 11-15-2016, 05:20 AM   #9074
measured them myself this morning, I'm just posting for others who may be interested
2wd Swaggers are 77mm +/- Diameter with no inserts
4wd Swaggers are 81mm +/- Diameter with open cell Inserts
Pin Down Rears are 87mm +/- Diameter with Open Cell Inserts
anad just for reference,
Shum. Original Mini Pins were 86mm +/- Diameter with same open cell inserts
Associated TC7.1
Associated B6 x2
Associated T5M
Tekno EB48SL
Old 11-18-2016, 07:28 PM   #9075
iDesign5's Avatar
What have some of you guys used for removing the white residue from the gold Smoothies? Just don't want to compromise the integrity with something they don't like.
These look like they were rolled in flour almost lol
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
