Like Tree38Likes
Old 08-15-2016, 05:52 AM   #9001
PW
PW's Avatar
Send a message via AIM to PW
Originally Posted by Cain View Post
question on carpet racing when you are not allowed to use carpet style pin tires:
At the track i'll be running at in the winter previously I used clay compound tires in either a very minimum tread setup (say a barcode sized tread) or slicks basically sauced. They worked well, but one of the very fast drivers uses a wedge 2wd tire up front and I believe something like a red compound losi ifmar pin. As they are not a "hard" carpet tires, those are legal and he doesnt' sauce which is kind of nice.
Carpet is grey ozite mixed with something else, not sure what though as can be seen here:
For 2wd buggy, ,I am looking to use the one of the various 2wd front tires for carpet out there, but curious how does the jconcepts swagger compare to the schumacher wedge in yellow compound and do you run these without foams?
Also, would flip outs be an option for the rear that could be similar to the losi IFMAR pin I described?
Lastly, I wonder if a similar front and rear flip out setup on 4wd buggy would be an option too based on what i mentioned (right now using worn proline ions)
The flipout is very similar to the IFMAR pin, but it's only available in super soft, so it will be much softer than the red compound.
has the cva kit (part #2437) for the b5m line been discontinued? thanks
Unfortunately yes.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 08-15-2016, 06:19 AM   #9002
Tech Legend
Cain's Avatar
Trader Rating: 235 (100%+)
Thanks for the info. If I tried this would you run a molded insert?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL | Yokomo YZ-2 DTM x 2>
Old 08-15-2016, 06:32 AM   #9003
PW
PW's Avatar
Most likely....
Paul Wynn
Old 08-15-2016, 07:51 AM   #9004
Tech Legend
Cain's Avatar
Most likely....
thanks. will report back how that goes. If it doesnt' work, will just do smoothies or a worn barcodish tire then.
Old 08-16-2016, 07:33 PM   #9005
Trader Rating: 121 (99%+)
Paul, I saw the video with the new products from the Nationals. Any word on when those new space bars are going to be available?
skoalisbad4me is offline   Reply With Quote
Old 08-16-2016, 08:43 PM   #9006
Trader Rating: 18 (100%+)
Any plans for a Strike RC8B3E body or does the Nitro one have enough clearance for the battery?
If you build it I will break it!
EB48.4 - B6 - B64 - TC7.1 - F6
iTz Nicholas72 is offline   Reply With Quote
Old 08-17-2016, 02:54 AM   #9007
ScottKelly911's Avatar
I just wanted to say, it was great to see Maifield running Shortcourse at Nats when many of the others did not. In my opinion, it's one of the most fun classes to run and looks the coolest on track. Just something so cool about how a shortcourse looks fully whipped over a jump going into a turn. Just wanted to say, please keep encouraging your top level drivers to run SC. Luckily 2wd SC's been making a comeback out here in SoCal, so hopefully it'll continue across the country! BTW, are you guys planning on making a racing SC Body (not true scale type) based on the 2017 Ford Raptor?
Associated B6D w/laydown, Hobbywing Just Stock/Schuur Speed 17.5 Race Car
Associated SC5m 2wd Shortcourse truck Tekin RS Pro/Reedy Sonic 8.5 Race Truck
Tekno SCT410, Tekin Pro4hd 3000kv on 3s Mostly for fun
Associated B5M, Hobbywing Just Stock/Reedy 8.5 Mod Just for fun
Home track OCRC & Home away from home SCVRC
ScottKelly911 is offline   Reply With Quote
Old 08-17-2016, 05:22 AM   #9008
PW
PW's Avatar
I'm hearing October.
Yes; the nitro version doesn't clear the battery.
Thanks; Maifield actually enjoys SCT . At a ROAR National, the drivers can only enter 3 classes, so that is why you didn't see more factory drivers run it. The teams have to split the their drivers up between truck and SCT.
I'm not sure about a "race" 2017 Raptor, but a 2017 Raptor is on the list.
Paul Wynn
Old 09-01-2016, 06:21 PM   #9009
Fabulous's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Fabulous View Post
Hey PW,
Seeing your heavily in the market on selling tires. How about develop a small Tupperware type container with a built in brush for washing tires racer could use in their pit area?
Page 559 #8374; 1 1/2 years later. Thanks PW for coming through!!!
http://www.jconcepts.net/shop/wash-brush
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Fabulous is offline   Reply With Quote
Old 09-08-2016, 07:22 AM   #9010
timannnn6's Avatar
Trader Rating: 124 (100%+)
I purchased the bottom caps for a B6D as shown in link below. The hole is too small for the "hat" bushing to sit in. I measured the stock cap and it's 5.25mm. The JC one is 4.75mm. If I install the JC cap it causes binding on the shock shaft. Is this a manufacturing glitch or are they designed like this? They show compatibility with the B6 series but not sure if running change was made for new model.
https://www.amainhobbies.com/jconcep...2492-1/p488680
timannnn6 is offline   Reply With Quote
Old 09-08-2016, 07:40 AM   #9011
PW
PW's Avatar
There was no running change from AE on the B5/B6 parts, but the optional machined B6 shock bushings are slightly larger. We see that you are already in contact with JConcepts directly and it will be handled directly ASAP.
Paul Wynn
Old 09-08-2016, 07:52 AM   #9012
Trader Rating: 19 (100%+)
any plans for a Yokomo YZ-4 Body?
Scott R is offline   Reply With Quote
Old 09-08-2016, 07:58 AM   #9013
PW
PW's Avatar
Not at this time, but a YZ2 is very close
Paul Wynn
Old 09-08-2016, 07:59 AM   #9014
Jtipsy's Avatar
I know alot of people what would love a dex410v5 body and dex210v3 body from you guys.
Joseph Tuepker
Jtipsy is offline   Reply With Quote
Old 09-08-2016, 12:06 PM   #9015
rregl0612's Avatar
Trader Rating: 33 (100%+)
So with the Stackers and hybrids on closeout for the elevated bead, does that mean we will be seeing some new 4.0 truggy tires??? Can I request something indoor biased, as no one makes anything right now. Switch 2.0 the tightest pin I can find. Some bar Flys or Dirtwebs would be killer
rregl0612 is offline   Reply With Quote
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
