Like Tree28Likes
Old 08-09-2016, 06:55 AM   #8986
MiCk B's Avatar
Hi,
Does the Aluminum Servo Mount Bracket (2445-1) fit the B6 buggy?
Thanks,
MiCk B. :-)
http://www.dublinmodelracing.com
http://www.p-dubracing.co.uk
http://www.msdmodels.ie
MiCk B is offline   Reply With Quote
Old 08-09-2016, 08:05 AM   #8987
RC Corral's Avatar
Sorry to drop in on this thread, but I need to purchase 3 original BJ4 bodies. By original, I mean, pre-order-days-original body. I think I was #873 and #874 and #935 from the original preorder list. I was hoping you might have some lying around in the attic or something.
Can anyone here help with that? Or recommend a current body that will fit properly?
Thanks in advance for your thoughts,
Pete
RC Corral is offline   Reply With Quote
Old 08-09-2016, 01:26 PM   #8988
shadowracer24's Avatar
Originally Posted by MiCk B View Post
Hi,
Thanks,
MiCk B. :-)
Yes it fits just fine. Drops right in.
shadowracer24 is offline   Reply With Quote
Old 08-10-2016, 03:50 AM   #8989
MiCk B's Avatar
Thanks,
MiCk B. :-)
Old 08-10-2016, 05:24 AM   #8990
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Thanks,
MiCk B. :-)
I think it will move the servo further forward compared to the standard B6/d mounts. Maybe Paul can confirm.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-10-2016, 08:04 AM   #8991
rregl0612's Avatar
Trader Rating: 33 (100%+)
Default Need some tire Help
So I remember when the evo/60 series tires came out for 1/10 there was some speculation and possibly remember seeing how to's on mounting standard 2.2 tires to evo style beads. Is this possible? Do I just cut the bead off and glue as normal.
Any helps appreciated
rregl0612 is online now   Reply With Quote
Old 08-10-2016, 01:50 PM   #8992
ryan432greening's Avatar
Any chance you folks at JC are working on a body for the Xray XB2?
B-Main Racing
TLR 22 3.0, 22-4 2.0, 8ight-E 4.0, 8ight 4.0
GFRP M1
ryan432greening is offline   Reply With Quote
Old 08-10-2016, 05:39 PM   #8993
oPAULo's Avatar
Question about tire compounds...
During the winter at the indoor tracks around here the tracks stay moist and we're all on clay compound.
During the summer with the heat and the fans on and the doors open it's a different story. Soft, super soft, mega soft.
Should I actually measure track temperature and make my selection by that? Wouldn't a super soft give me a bit more traction than a soft or does it not work that way? I've actually had good luck with mega's and closed cell inserts but according to the temperature chart I'm way off.
oPAULo is offline   Reply With Quote
Old 08-11-2016, 07:36 AM   #8994
Super Moderator
I doubt you will see any JC bodies for any Xray car.
JConcepts Thread
Old 08-11-2016, 11:59 AM   #8995
Gotcha, thanks for pulling that thread. Thankfully the rest of my cars are common enough for JC product. Thanks for the reply.
JConcepts Thread
B-Main Racing
GFRP M1
Old 08-12-2016, 07:00 AM   #8996
Phillip F's Avatar
Trader Rating: 15 (100%+)
Originally Posted by PW View Post
Our Finnisher for the MBX6r might work #0237.
No Finnisher planned for the MBX-7, but we will do a new body for the rumored MBX8 if/when its released
Any plans for a Finisher body for the B6?
Phillip F is offline   Reply With Quote
Old 08-12-2016, 07:17 AM   #8997
PW
PW's Avatar
Send a message via AIM to PW
Actually we decided to make an S2 and should have something end of the month or first of Sept.
It does fit, but moves the servo forward and can cause clearance issues with the steering.
I love the Finnisher body for the B5M .... will JConcepts make one for the B6?
Yes, we will do a F2 body soon .
Yes, you can just cut the bead off the 2.2 tire and mount to the 2.4/60mm wheel.
I just go by what works best regardless of temps . Sounds like you are on the right track with your compound selections
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 08-14-2016, 07:59 AM   #8998
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
question on carpet racing when you are not allowed to use carpet style pin tires:
At the track i'll be running at in the winter previously I used clay compound tires in either a very minimum tread setup (say a barcode sized tread) or slicks basically sauced. They worked well, but one of the very fast drivers uses a wedge 2wd tire up front and I believe something like a red compound losi ifmar pin. As they are not a "hard" carpet tires, those are legal and he doesnt' sauce which is kind of nice.
Carpet is grey ozite mixed with something else, not sure what though as can be seen here:
+ YouTube Video
For 2wd buggy, ,I am looking to use the one of the various 2wd front tires for carpet out there, but curious how does the jconcepts swagger compare to the schumacher wedge in yellow compound and do you run these without foams?
Also, would flip outs be an option for the rear that could be similar to the losi IFMAR pin I described?
Lastly, I wonder if a similar front and rear flip out setup on 4wd buggy would be an option too based on what i mentioned (right now using worn proline ions)
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Cain is online now   Reply With Quote
Old 08-14-2016, 01:01 PM   #8999
has the cva kit (part #2437) for the b5m line been discontinued? thanks
mel_russ615 is offline   Reply With Quote
Old 08-15-2016, 05:25 AM   #9000
+ YouTube Video
IMO, the Swaggers are more consistent through the corner, and have more grip than the Schumachers or Proline Wedges. I've run all 3. Before the Swaggers the Schumachers were my favorite...Before...
Yes run them without Foams
Scott R is offline   Reply With Quote
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
