Like Tree28Likes
Old 02-16-2016, 02:03 PM   #8716
Jmuck69's Avatar
[QUOTE=potatobed409;14393439]
Originally Posted by PW View Post
I think something will happen, but it will be later in the year
Hope not. I got tired of sanding down 2.2 dirtwebs so I had to switch brands. Why not make them in Black Compound instead of Green? Greens work once
you put about 30 packs through the car.
Use Liquid Wrench (yellow cap). makes any tire work
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 02-16-2016, 04:38 PM   #8717
DriveItLikeYSIT's Avatar
Trader Rating: 92 (100%+)
P-Dub..Are you'll gonna offer the triple dees to other platforms like stadium truck or sct?
TEAM DRIVER==> BocaBearings|Pro-Line Racing|HWNA|Gens ACE|
EBSL - HW XR8 SCT PRO ESC & HW G2 4300kv motor
EXOTEK 22 SCT 2.0 - HW XR10 PRO ESC & HW Bandit 10.5t
EXOTEK 22T 2.0 - HW XR10 PRO ESC & HW G2 7.5T
DriveItLikeYSIT is offline   Reply With Quote
Old 02-16-2016, 08:35 PM   #8718
Volition's Avatar
What jconcepts tyre is equivalent to the proline holeshots? 10th buggy, thanks
Volition is offline   Reply With Quote
Old 02-16-2016, 09:02 PM   #8719
ray_munday's Avatar
Double Dees are most similar in terms of design. However usually I find the 3D works better on our hard packed / dusty surface tracks during the summer, whereas the Double Dee tends to work better during winter when the track has a little more moisture.
Team Associated Factory Driver: B6/B6D, B64D, SC5M
JConcepts Factory Driver: Tyres, Rims, Wings, Bodies & Accessories
Reedy Factory Driver: Blackbox 510R ESC, Sonic 3 BL motors, Lipo
KO Propo EX-1 KIY_____www.keilorrc.com.au
Check out my help thread: http://www.rctech.net/forum/10587838-post1.html
ray_munday is offline   Reply With Quote
Old 02-17-2016, 01:33 AM   #8720
Volition's Avatar
Cheers Ray, I've used the 3D on my 2wd and do prefer it. I'll stick with them and I'll try the double Dee as the weather cools. I noticed though that a 4wd front is not available for the 3D. I take it the double Dee would be the tyre of choice for 4wd, moving to a barcode with less dust. Where does the Hybrid tyre fit in?
Old 02-17-2016, 07:48 AM   #8721
How long of a wait for gold dirt webs for SC and Buggy? I know they are very popular and always seem to be on back order. I have had to go to a different company because of it. Hopefully you guys will order enough this go around so they stay in stock
Scottysspeedsho is offline   Reply With Quote
Old 02-17-2016, 09:07 AM   #8722
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
AKA is no better. Proline seems to be the only with tires in stock
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 02-17-2016, 11:13 AM   #8723
True for sure !
Old 02-17-2016, 02:44 PM   #8724
the incubus's Avatar
Trader Rating: 17 (100%+)
for 4WD Buggy the 3D's are the way to go when the track is soft, perhaps a bit mushy. The outside of the tread digs in better than DD's but once the track dries up, I find DD's perform better. I've also found that when & whereDD's are great, Splitters will work even better!
The best combo I've run on any of my Wheelers is a DD front (Black or Green) and Splitter rears (Black or Green). This tends to work on any track I've been to.
Hope this helps.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is online now   Reply With Quote
Old 02-17-2016, 03:07 PM   #8725
gokarter64's Avatar
what ever happened to those carbon rear towers for the b5m that were shown in a video a while back. they looked really nice
Cars: TLR 22 3.0 Mod, Mugen MBX7 ECO, TLR 22 3.0 Stock, TLR 22-4, TLR 22T 2.0
Electronics: Airtonics, Orion, LRP, Xpert, Maclan
Goodies: Exotek, Avid, Raw Speed, Jconcepts, MIP . Paint By: Double Deuce Designs
gokarter64 is offline   Reply With Quote
Old 02-17-2016, 04:05 PM   #8726
Volition's Avatar
Hope this helps.
Do the 3d's come in a 4wd front? I don't think they do.
I thought it best to keep the same tyres front & back. Not to mix them up, as you would get different traction levels.
So where do these splitters & hybrids sit? Are they between the DD's & flipouts. Or heading more towards the 3D from a DD? Cheers
Old 02-17-2016, 05:30 PM   #8727
mhughesjr's Avatar
Is there any plan to make reflex tires for ST?
We normally use holeshots or DD on our hard packed outdoor clay track; however, I tried a pair of reflex tires f/r on my B5M during our second heat and I was on rails. The track was dry and low dust.
mhughesjr is offline   Reply With Quote
Old 02-24-2016, 08:12 AM   #8728
skinned's Avatar
when will the blue and black camber gauges be "in stock"?
skinned is offline   Reply With Quote
Old 02-24-2016, 10:55 AM   #8729
PW
PW's Avatar
Send a message via AIM to PW
Originally Posted by Cain View Post
Anyway, on to the tire questions. Right now, indoors I run on a track where tires like Panthers slick clays work or Proline Primes in clay work too, when sauced. However, I did find that with some cheap Proline ions in the M3 compound I could run these with good traction and no saucing needed.Others at least for 2wd buggy do basically the same with other tire styles as we are not allowed to run carpet hard pin tires.
So, I figured pick up some dirt webs or brocodes, etc. in green compound and some in gold just in case with some dirt tech inserts. Do I sound like I am on the right track, especially in compound comparison?
For outdoors, it can get VERY LOOSE HERE, old school dirt conditions so got blockades and step pins in the box. However, when it does dry a bit, tires like Losi's old IFMAR Pins work quite well. I am wondering if the flip outs would do the same thing?
Sounds like you are on the right track.
Yes; Flipouts would be similar to IFMAR Pins.
No plans at this time.
We received buggy Gold Dirt Webs last week and they are currently being shipped to all Dist/Hobby shops right now; SCT webs are in production now. It's not about ordering enough or not, it's about the vendors only being able to produce X amount of rubber.
There have been some updates to the alloy parts and this has delayed the projects.
Not at this time.
No firm ETA, but hopefully end of next month.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 02-25-2016, 01:51 PM   #8730
Hay, any ETA for TLR 4.0 and 4.0E hop-ups?
janisdaubergs is offline   Reply With Quote
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
