Like Tree38Likes
Old 12-10-2015, 11:59 PM   #8656
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Originally Posted by OriginalDonk View Post
Looks like JC is offering many of their new tread designs in 60mm (similar to 2.4, VTR, EVO) for both 2WD and 4WD buggies (e.g. Smoothies and Reflex). Paul replied on a previous page that they're not likely going to release 2.2 Smoothies. While stock guys are definitely running 60mm/2.4, many of the mod guys in 2wd and 4wd are still running 2.2's at my local tracks (OCRC, LRH, etc.). I tracked down Maifield's Surf City OCRC setup and it says he was running 60mm front and 2.2 rear. Odd.
Have people transitioned over to 60mm across the board elsewhere in the U.S.? Just picked up a new wheeler and eyeing some 60mm Bar Flys to run on my 2wd and 4wd buggies though I'll probably be an odd man out. Maybe it's because people run AE or TLR wheels for the most part and stick with the 2.2s?
Anybody else notice that Prolines newest release (Micron) is available only in 2.2 and their VTR 2.4mm wheels have been discontinued?
Jack Smash is offline   Reply With Quote
Old 12-11-2015, 05:15 AM   #8657
PW
PW's Avatar
Send a message via AIM to PW
Originally Posted by Bracket View Post
Ever plan on releasing an updated DEX210 body? The existing Finnisher looks great, but doesn't clear the bulges in the side pods, and the bodies from Durango look... uh... "unique".
Not at the moment; we will reevaluate once they have all their new kits released and settled back in.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 12-11-2015, 06:20 AM   #8658
Hinch45's Avatar
Has anyone else had issues with the JConcepts Titanium Knurl Tip Front Axle Set? I ordered these along with the Jconcept front hexes and my B5m Lite about 3 weeks ago. From day one, there has always been a gritty feeling on the left side when I hand turn the axles. After each run it gets a little worse. I removed everything multiple times and cleaned them, again same result. I changed the bearing with a brand new bearing, same issue. I switched the axle from the left side of the car to the right and now the right side has a gritty feel to it. It's obviously the axle but can't figure out the problem. I have tried everything I can think of but can't get one side to spin smoothly. These things are not cheap at set At $30. Any ideas?
Hinch45 is offline   Reply With Quote
Old 12-11-2015, 07:59 AM   #8659
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
sounds like a B5 front hub issues, that occurs with poorly lined up inserts. Now, the real question is: Is it smooth with the fit axles?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 12-11-2015, 08:29 AM   #8660
Trader Rating: 18 (100%+)
Hunch,
I'll see you tonight. I had the same issue. I may have a solution.
Eric
eragot is offline   Reply With Quote
Old 12-11-2015, 08:42 AM   #8661
PW
PW's Avatar
The only time I've seen this is when someone has glued in their bearing inserts in the steering block and they weren't 100% squared up when they set. I actually had this problem myself when I glued up a set trackside in a hurry .
If indeed you find something wrong with the axle itself, please contact JConcepts directly and we will help anyway possible.
Paul Wynn
Old 12-11-2015, 10:02 AM   #8662
Hinch45's Avatar
Thanks for the response, and I thought about the bearing insert, which I did glue. However , when I swapped the axle from one side to the other the problem followed. The other side was smooth. So again I can only guess it's the axle itself.
Old 12-13-2015, 10:08 AM   #8663
mes
Sorry if this has been asked before: Are there already 12 mm front wheels by JConcepts that fit the TLR 22 3.0 and has the same offset, e.g. the ZX-6 front wheels?
mes is offline   Reply With Quote
Old 12-14-2015, 05:40 AM   #8664
PW
PW's Avatar
Unfortunately the TLR 2wd offset is different from any other buggy and we only have the standard/original hex wheel.
Paul Wynn
Old 12-14-2015, 09:07 AM   #8665
mes
Thank you, Paul!
Old 12-14-2015, 05:03 PM   #8666
Potoczak's Avatar
Trader Rating: 112 (100%+)
Any idea on a time frame release on the carbon/aluminum setup board you guys are coming out with??
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 12-14-2015, 06:53 PM   #8667
Trader Rating: 19 (100%+)
anyone know of any jconcepts coupon codes out there?
Brandon Powell is offline   Reply With Quote
Old 12-15-2015, 05:29 AM   #8668
PW
PW's Avatar
I'm not sure it's been confirmed yet to go into production, but it's being well received .
Paul Wynn
Old 12-15-2015, 11:50 AM   #8669
skrichter's Avatar
Send a message via AIM to skrichter
I see your 60mm wheel for the 22-4 (which I use on the HB D413) is not in stock at your warehouse (nor many other online retailers). Are you discontinuing this item now that TLR has announced the 22-4 61mm? I hope not
http://www.jconcepts.net/shop/bullet...24-front-wheel
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 12-15-2015, 12:00 PM   #8670
PW
PW's Avatar
As far as I know, we are just out of stock and we will still carry them.
Paul Wynn
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
