Like Tree33Likes
Old 10-07-2015, 06:30 AM   #8566
PW
PW's Avatar
Send a message via AIM to PW
Originally Posted by skinned View Post
any chance on more color choices for 4mm nut #2089-2090?
maybe green or plain aluminum in the future?
thanks
Sorry, unfortunately not at this time.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 10-07-2015, 07:25 AM   #8567
PW
PW's Avatar
Congratulations to JConcepts very own Spencer Rivkin for winning the 2015 IFMAR 2wd Off-road World Championships!
JConcepts would also like to congratulate Ryan Mafield and Kody Numendahl for their top ten performances.
1st Spencer Rivkin
Items used:
-Alloy servo mounting bracket 2445
-Finnisher front wing 0151
-Hi-clearance rear wing 0143
-Prototype S2 body 0294
-Finnisher alloy wing buttons 2214
-Alloy locking wheel nuts 2341
6th Ryan Maifield
Items used:
-Hi-clearance rear wing 0123
-Prototype S2 body
-Titanium Fin turnbuckles 2225
-Alloy locking wheel nuts 2156/2341
8th Kody Numedahl
Items used:
-Finnisher rear wing 0138
Also of note:
7 out of 10 drivers used the JC Finnisher front wing.
Paul Wynn
Old 10-07-2015, 09:15 PM   #8568
Jack Bonhomme's Avatar
Did Alex K from Connecticut go to Japan? It looks like him holding the USA sign in the opening ceremony picture.
YouTube Page: JackBonhommeVideos
Sponsors: FTM Grip, Redline Hobbies, Garcia Graphix
Tracks:Barnstormers, 46RC, R/C Madness
Jack Bonhomme is offline   Reply With Quote
Old 10-08-2015, 05:14 AM   #8569
PW
PW's Avatar
No...Alex was qualified, but couldn't make it. Alex will be attending the JConcepts Indoor Nationals this weekend at RC Excitement.
Paul Wynn
Old 10-09-2015, 07:05 AM   #8570
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Paul,
will the new JC front hubs address the -1mm ackerman?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-09-2015, 08:03 AM   #8571
PW
PW's Avatar
Originally Posted by Wildcat1971 View Post
Paul,
?? Please explain
Paul Wynn
Old 10-09-2015, 11:34 AM   #8572
Originally Posted by PW View Post
?? Please explain
many drivers are removing 1mm from under the stud to fix the bump steer. It has been a common mod since the car came out.
Sorry I meant bump steer not ackerman
Old 10-09-2015, 12:38 PM   #8573
PW
PW's Avatar
Ahh...calling it hub and ackerman threw me off
As far as I know most of the team guys have gotten away from that mod, but I will have to check and see if that will be incorporated into the new steering block.
All the new alloy parts with the exception of the new chassis will be a end of year or early 2016 release. The new chassis should be released within the next 2 weeks
Paul Wynn
Old 10-09-2015, 12:50 PM   #8574
Easier to go up from, than shave down an alum hub Say it is weight savings, lol. It would be nice for more bump steering tuning.
Old 10-09-2015, 01:12 PM   #8575
I'm curious if this is 1/8th buggy? We haven't had/sold 1/8th DD's in a very long time, unless it may have been an old clearance item? These would certainly have an older style wheel that was used before the close-ended wheel nuts became popular.
Like you have alluded to, sounds like the close-ended wheel nuts are not allowing the wheel nut to fully engage into the wheel. Our more current wheels shouldn't have this issue and I would recommend using an open-ended wheel nut for those older wheels.
just saw your post and thought I would give a little update.
Found one of my closed end wheel nuts (tekno) had a small dent in it. Must have caused it to not tighten properly. So no problem there, i'll fix my post.
I bought them a little over a year ago from Amain and never got around to using them until recently. I have however had all 4 wheels almost completly come unglued on one side. Never had any problems with any other pre-mounts that I have bought. I will also check that up to the amount of time they sat around, maybe the glue just got old. No biggie I just glued them back up.
Other than that I really do like the feel of the tire.
Tekno eb48.2
Tekno sct410.3
one8updragracer is offline   Reply With Quote
Old 10-11-2015, 07:02 PM   #8576
1/4milecrazy's Avatar
Just got home from the JConcepts indoor nationals at R/C Excitement in Fitchburg MA. Great showing from the Jconcepts drivers in attendance. All courteous and helpful.
Thanks to JConcepts for sponsoring the event.
1/4milecrazy is offline   Reply With Quote
Old 10-12-2015, 06:27 AM   #8577
skinned's Avatar
are the jConcepts 12mm hex hubs for the rear of sc10.2 wider than the stock ae clamping hubs?......after awhile my rear wheels are kinda wobbly from always removing and tighting with the jConcepts serrated nuts...and im maxed out on tighting.....
skinned is offline   Reply With Quote
Old 10-12-2015, 06:52 AM   #8578
PW
PW's Avatar
The JC hexes are the same width.
When you start with a fresh wheel, you don't have to over tighten them when using the JC wheel nuts. If you do continually over tighten them or just use the same wheel for a long period of time, the serrations will eventually wear or crush the wheel and it will get to thin where the wheel nut locks onto the wheel.
Also keep in mind that each brand of wheel is different, some wheels are softer/stiffer than others, they can be slightly thinner or thicker where the wheel nut makes contact, different types of plastics, etc...
Paul Wynn
Old 10-12-2015, 12:21 PM   #8579
skinned's Avatar
thanks for the info...I do use the same wheels all season for racing....I did use a washer on the outside of the wheel to keep it from wobbling to get through the last race I was in...but it kinda defeats the whole purpose of the serrated nut.
Old 10-14-2015, 01:53 AM   #8580
ScottKelly911's Avatar
Paul, will the new JC aluminum shock caps for the 5 series be available in blue ano or just black? The ones in the vid were black. I know the other shock parts will be avail in both, just want Confirmation if the shock caps will be too.
Associated B6D w/laydown, Hobbywing Just Stock/Schuur Speed 17.5 Race Car
Associated SC5m 2wd Shortcourse truck Tekin RS Pro/Reedy Sonic 8.5 Race Truck
Tekno SCT410, Tekin Pro4hd 3000kv on 3s Mostly for fun
Associated B5M, Hobbywing Just Stock/Reedy 8.5 Mod Just for fun
Home track OCRC & Home away from home SCVRC
ScottKelly911 is offline   Reply With Quote
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
