Like Tree387Likes
JConcepts Thread
Old 07-04-2015, 05:06 PM
  #8446
PW
PW's Avatar
Wishing everyone a safe and enjoyable 4th of July weekend!
PW is offline
Old 07-08-2015, 10:38 PM
  #8447
Suspended
Paul, just saw the tire sticks, they look great. Any word on the Reflex tires shown in the product release?
Mantis Toboggan is offline
Old 07-09-2015, 05:57 AM
  #8448
PW
PW's Avatar
Unfortunately I don't have an ETA yet, but it must be getting close.
PW is offline
Old 07-09-2015, 07:43 AM
  #8449
skinned's Avatar
I was wondering why the jconcepts 4mm serrated wheel nuts do not have the locking nylon in the middle?...I have purchased some and was curious about this...
skinned is offline
Old 07-09-2015, 08:39 AM
  #8450
PW
PW's Avatar
Our serrated wheel nuts are actually machined from a high grade aluminum.
The ones with the nylon are molded/cast; which are not as strong and wear much faster. Once the nylon stretches/wears out, you now have half the thread engagement. There just is no need for the nylon now that we are using the serrations. The reason you see some with both, is they are just taking the cheaper molded/cast nuts and adding the serrations to the existing nut.
PW is offline
Old 07-09-2015, 09:18 AM
  #8451
skinned's Avatar
Thumbs up
thanks for the answer/reply........they look "so cool" new...but as soon as you use them(as with all anodized metal) the blue comes right off which sucks....cause when im racing.... im trying to look good too
skinned is offline
Old 07-11-2015, 05:25 PM
  #8452
oPAULo's Avatar
What is the softest Jconcepts tire?? Super soft?? Indoor super soft?? Mega soft??
I currently run AKA chainlink supersoft but don't care for the EVO style bead. I bought a set of Dirt Web indoor soft and I find the quality to be superior. They spin so true and smooth and straight and I prefer the 2.2 bead. No vibration at all. They just don't hook up. At all.
So which compound is softest or similar to or better than AKA supersoft??
oPAULo is offline
Old 07-11-2015, 05:50 PM
  #8453
PW
PW's Avatar
Mega soft (black) is the softest of the JC compounds. The JC super soft (green) would be very similar to their super soft and the mega would be slightly softer.
The indoor soft (gold) is a completely different rubber and is comparable to "Clay" compound from the other brands.
PW is offline
Old 07-11-2015, 05:58 PM
  #8454
oPAULo's Avatar
Thanks so much!! Getting my order in for next weekend.
oPAULo is offline
Old 07-15-2015, 09:20 AM
  #8455
mes
I spoke with Team Associated and the truck is the same width as the SC10, which means you will still need the +3 Hazards to make it max width (ROAR).
Too bad, I've got some 0 offset wheels on the way meanwhile... Thanks for clarifying before I ordered even more of the wrong ones!
I personally think it will continue to be a tuning option unfortunately. Truthfully it's not an option that was really needed, but now its here along with the added cost and confusion .
In what conditions would you run the 2.4" wheels? I remember that Yokomo introduced the 2.2" wheels which eventually became today's standard when everyone else used 2.0" wheels, which were inferior on the bumpy tracks back then. Are 2.4"s similarly better on bumpy tracks? I'll drive a wheeler on the blown out dirt tracks in our region and stick to 2WD on astroturf. The reflex tires look promising, but I am not sure what to think of the closed cell inserts and the 2.4" wheels. So far, standard foams have been better on our rough dirt tracks than any of the molded inserts out there.
mes is offline
Old 07-17-2015, 07:19 AM
  #8456
I don't understand why you would release a outdoor tire for low traction tracks on a 60mm wheel with the hardest insert I know of. I like the looks of the reflex tire, we will have to wait and see how it works.
potatobed409 is offline
Old 07-17-2015, 08:06 AM
  #8457
PW
PW's Avatar
The Reflex isn't necessarily designed for "low traction"; it is designed to bridge the gap when you're between running a big pin tire (DD's, Flipouts, etc) and bar/web tires. The Reflex tires seem to really excel on hard packed surfaces that are not quite grooved yet or just starting to groove, but still dusty.
I've actually found that the 2.4" jumps/lands better and feels more stable. My lap times don't seem any better, but I like the comfort feel of them. This is with 2.4" Dirt Webs/cut rear insert, on an indoor orange clay grooved track.
PW is offline
Old 07-17-2015, 11:48 AM
  #8458
mes
Thank you, Paul!
mes is offline
Old 07-17-2015, 08:20 PM
  #8459
1/4milecrazy's Avatar
I have tried every combination of inserts tires and wheels you could imagine. Especially with Jcon tires, dirt webs, pressure points, whippits, rippts, diamond bars, bro codes, even electrons, ions and primes, ..........I cant even think of all of them. I am really liking the diamond bars, but they need some more testing, but I have not been able to beat Green/Green dirt webs on 2.4s with dirt tech inserts on hard packed clay, low dust and no groove. I am gonna start mixing up 2.2s and 2.4s front to rear to see how it affects the handling of the car.
1/4milecrazy is offline
Old 07-18-2015, 08:39 PM
  #8460
Suspended
Trader Rating: 11 (87%+)
Any plans to make black wheels?
Chichi is offline
