Like Tree38Likes
Old 04-13-2015, 06:29 AM   #8341
PW
PW's Avatar
Send a message via AIM to PW
Originally Posted by micrors4guy View Post
Any idea when the diamond bars and reflex 8th scale tires will be available?
The Reflex's are in packaging now and Diamond Bars are in production, so Reflex's should be any day now.
Originally Posted by Socket View Post
Do the 3D's offer more side bite than the dOuble Ds?
Paul, any insight on this?
It's surface dependent, but I personally think DD's have more traction on hard packed slimy or dusty surfaces.
Any plans for titanium hinge pins for the associated B/T5 Series?
Not at the moment; past history hasn't proven well for Ti-hinge pins.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 04-13-2015, 01:27 PM   #8342
With the diameter of the b/t4 series I could see that. The 5 series is running 3.5mm hinge pins though. I would think the extra diameter would make up for it.
Cautrell05 is offline   Reply With Quote
Old 04-13-2015, 01:53 PM   #8343
PW
PW's Avatar
The 5 series uses 3mm pins, but it's worth looking into. Thanks for the feedback.
Paul Wynn
Old 04-13-2015, 01:55 PM   #8344
carcrusher46's Avatar
Trader Rating: 17 (100%+)
It's not necessarily the diameter that is the issue; it's the material properties of titanium. Titanium will not bend/deflect like steel will prior to yielding (breaking) and in the case of hinge pins, it's sometimes better to finish the race with a slightly bent hinge pin that can be replaced very cheaply versus snapping an expensive titanium one and being out of the race to boot.
Matt Stoltz
Thank you to my sponsors:
Team Associated - Reedy - JConcepts - Life Fast RC Paintworks
carcrusher46 is offline   Reply With Quote
Old 04-13-2015, 02:00 PM   #8345
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
inside rear pin is 3.5mm rest are 3mm.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-14-2015, 10:23 AM   #8346
mes
Right, that's why I could not use my shims when I still had installed the plastic suspension mounts. Everything has been fine with the FT aluminum mounts except they are blue. Too bad no one has come out with a full set of black aluminum goodies for AE's 5th gen series. I am not about to hold my breath, but beating a dead horse won't hurt...
mes is offline   Reply With Quote
Old 04-14-2015, 10:55 PM   #8347
timannnn6's Avatar
Trader Rating: 124 (100%+)
Any chance 12mm hex 60mm front wheels for the b44.3 in the works?
timannnn6 is offline   Reply With Quote
Old 04-15-2015, 12:11 AM   #8348
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
The 22-4 ones are what Cav told me to use at the Midwest race before the AE versions were released
pink_sleeve is offline   Reply With Quote
Old 04-15-2015, 06:12 AM   #8349
PW
PW's Avatar
Like pink mentioned, the 22-4 wheel is the same offset and can be used on the B44.3 with the 12mm hexes - 60mm wheel
Paul Wynn
Old 04-15-2015, 08:09 AM   #8350
timannnn6's Avatar
Thanks guys...new to 4wd 1/10 scale.
PW, maybe market/label the TLR 22-4 wheel to the b44.3 guys?
Old 04-15-2015, 08:15 AM   #8351
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
The problem there is that if you want to run these on a b44.3 you NEED the 12mm hex. A lot of guys that have had the b44, b44.1, b44.2 all have most likely had wheels/tires from those platforms. The old hex is not 12mm and even the b44.3 it is an option part. As more migrate to the 12mm front hex then I would think you would see this marketed to them. Until then maybe a disclaimer on the package or something of that sort.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 04-15-2015, 08:21 AM   #8352
timannnn6's Avatar
I'll add another twist to that. I run an Xray XB4 2015 and you either use kyosho or AE wheels (stock wheels are 14mm hex). I run a b5m so had plenty of AE rears. I went with the b44 fronts not knowing that the front hex is like 9.5mm (again, new to 1/10 4wd). I wanted to use a 12mm hex as I like my tires balanced properly. No 9.5mm balancer to be found.
Good to know that I can use the 22-4 wheels now.
Old 04-15-2015, 11:32 AM   #8353
Trader Rating: 129 (100%+)
PW, is the Silencer body for the B5m thicker than the stock body? Looking for increased durability. Thanks.
Chris Gierse is offline   Reply With Quote
Old 04-15-2015, 12:08 PM   #8354
PW
PW's Avatar
Yes . The kit body is really thin compared to most of the aftermarket bodies.
Paul Wynn
Old 04-18-2015, 12:18 AM   #8355
What's the word on gold Stadium Truck Dirt Webs? I've had them on backorder forever and the date keeps getting pushed back.
Naxn is offline   Reply With Quote
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 12:04 PM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 09:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 10:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 04:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 07:54 PM
