Like Tree38Likes
Old 03-03-2015, 12:25 PM   #8266
"When will we see the new B5 series parts - i.e. rear drive axles, wing mounts, etc."
I really don't know, but I guess the truck needs to come out first...
Paul Wynn
Not sure how to take that.....does that mean that the B5 owners have to wait for JC parts until the T5 comes out?
Kinda_Quick is offline   Reply With Quote
Old 03-03-2015, 04:31 PM   #8267
Originally Posted by louie8269 View Post
Alright guys I need some help:
I have a race this weekend and I want to make sure I have good traction (obviously)
I got some 60mm jconcepts wheels and gold dirt webs with dirt tech inserts.
From what I've been reading the dirt techs are way too hard/stiff out of the bag to be effective right away. There won't be much time to break-in the wheels/inserts/tires before qualifying. ( I will be breaking in the tires properly regardless )
What would you guys recommend I do? I don't have other inserts and I will not be able to order them before the race.
Would you:
A: Just run them and hope they break in before the mains
B: Cut out the ribs on the inserts before gluing
C: Use open cell inserts (not even sure this will work because the open cells are from 2.2 tires)
D: Other (please explain)
TIA guys!
I have never been a closed cell fan in the past and never could find a closed cell foam I really liked. I decided to give the dirt-techs a shot in gold dirtwebs and actually really like them. I softened them by putting 3 rows of punched holes in them with a leather punch. They were still a little stiff at first but started to feel good after the first quick practice run or so. The foams are soft enough at the top of the tire to absorb bumps in the track's surface and make good bite, but stiff enough to hold up in hard corners. This was with 2.2" tires but I'm sure it would work great with the 60mm tires too.
Rusty's Sled Shop LLC ~ Dirtheaven Hobby and Raceway-Champion,WI
Ballistik Ink Designs ~ Revolution Raceway-Appleton,WI ~ Cherry Juice Tire Traction
Support your local hobby shops!
RIchie-Peters is offline   Reply With Quote
Old 03-03-2015, 11:26 PM   #8268
Originally Posted by PW View Post
Don't cut the fronts or SCT; just run them normal.
PW,
By cutting the ribs, won't that make a gap between the tire and the insert? Was told that roughing up the shiny groove area between the ribs will help soften the tire faster (will absord water,etc and break down faster). Others have mentioned hole punching. Your thoughts please.
Micah123 is offline   Reply With Quote
Old 03-04-2015, 12:08 AM   #8269
Trader Rating: 29 (100%+)
I use my tire punch to punch holes in the jc foams and it works very well. Removes enough material to soften the foams but doesn't seem to effect the integrity or longevity of the foam.
Takin the lil guy racin...
Skeeter36 is offline   Reply With Quote
Old 03-04-2015, 06:38 AM   #8270
PW
PW's Avatar
Send a message via AIM to PW
Paul Wynn
Sorry...I read it as T5 . Not really sure when the new B5 accessories will be out, so stay tuned.
PW,
The 60mm package is so tight once glued, the gap is filled with the cut inserts. I do everything possible to keep water, sauce, etc from getting into the insert, so I don't recommend anything to enhance water absorption. If you feel the insert needs to be softer, I would recommend punching holes.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 03-04-2015, 07:22 AM   #8271
Anyone want to comment on their results and technique on making holes in their inserts (how many, where to punch on insert, etc.) Saw a post that incl pics on punching holes in an aka black but wanting an update from those who have experimented with dirt techs.
Old 03-04-2015, 09:42 AM   #8272
aeRayls's Avatar
As another guy mentioned. Use a leather punch that you use to put holes in your tires. Put 2 or 3 holes in each of the inner ribs. Flipping it inside out is a huge help.
When I first got the 60mm wheels and tires I tried 3 things:
1. Stock insert nothing done to it. This was too firm for my medium grip bumpy indoor track.
2 stock insert cut. This was by far better for my conditions.
3. Open cell insert. I stuffed a 2.2 open cell insert in there. It actually doesn't feel too bad at all and gave a lot of forward bite. Unless track conditions really suck and grip is really low, I wouldn't run em.
All in all... The 2.2 just plain works better at my home track.
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 03-04-2015, 12:27 PM   #8273
[QUOTE=PW;13884888]Sorry...I read it as T5 . Not really sure when the new B5 accessories will be out, so stay tuned.
Got it - thanks! Hopefully the rear drive axles will be out soon
Old 03-10-2015, 11:26 AM   #8274
rigor's Avatar
Trader Rating: 38 (100%+)
When are the complete set of T5m truck fin turnbuckles going to be available? Only like 2 weeks from now until the T5m kits ship I believe!
* Jesse H. *
rigor is offline   Reply With Quote
Old 03-10-2015, 12:13 PM   #8275
PW
PW's Avatar
We have them in stock and should be released any day now
Paul Wynn
Old 03-10-2015, 07:33 PM   #8276
1/4milecrazy's Avatar
First of all, Why are turnbuckles such a big deal??
Second, Paul, is there something you might want to tell us about?? A new release or something that people have asked about in this thread? Namely me.
Apparently "equal" and "partners" means different things to different people.
1/4milecrazy is offline   Reply With Quote
Old 03-11-2015, 06:51 AM   #8277
PW
PW's Avatar
You can always follow our "jconcepts" instagram page for sneak peeks of up coming products. You might see some things you like.....
Paul Wynn
Old 03-11-2015, 06:29 PM   #8278
iDesign5's Avatar
Default Dirt Webs For Carpet
I was just curious if maybe Dirt Webs in orange or red would be a viable solution to indoor off-road for carpet? I hate running PL carpet tires when I exclusively buy JConcepts stuff.... We still have a fair ways to go ground wise before we can head outside to the dirt.
iDesign5 is offline   Reply With Quote
Old 03-11-2015, 10:25 PM   #8279
That's where I saw them first. Me likey
Old 03-12-2015, 06:29 AM   #8280
PW
PW's Avatar
Honestly I have never run carpet off-road, so I don't really know first hand what to recommend. The few drivers that I know running on carpet use gold compound slicked out tires, but their local tracks don't allow the harder spiked tires.
Paul Wynn
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 12:04 PM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 09:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 10:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 04:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 07:54 PM
