Like Tree38Likes
Old 01-05-2015, 12:09 AM   #8101
AZJP's Avatar
Trader Rating: 20 (100%+)
Is this bag (jconcepts medium roller bag) photoshopped to appear larger? It states its 26" in length, which would make that girl about 4'5" in comparison to the bag. I had this bag in my amain shopping cart after seeing the picture, but didn't pull the trigger when I read it's only 26" long.
AZJP is offline   Reply With Quote
Old 01-05-2015, 06:30 AM   #8102
PW
PW's Avatar
Send a message via AIM to PW
No; the background has been photoshopped out, but the bag, girl, etc are actual size. My guess is the bag looks larger because it's closest to the camera.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 01-05-2015, 06:36 AM   #8103
Waflet's Avatar
Trader Rating: 30 (100%+)
Hideeho
Comparing the girl to the truck, she probably is under 5' tall. The truck isn't jacked up, is not that large to begin with, & she is barely tall enough to look in the window.
"Just leave me alone, I know what I'm doing."-Kimi Raikkonen
Mugen MBX7R Eco/Tekin RX8g2/Savox 2274/SMC 1900kv/Aitronics mt-4/promatch
Mugen MSC7(1/10 pro4 sct)/Tekin RX8g2/Savox 2274/Tekin Pro4HD 4300kv/Airtronics mt-4/SMC
Waflet is offline   Reply With Quote
Old 01-05-2015, 06:49 AM   #8104
heinen81's Avatar
Default Bullet Wheels
Does anyone have any advice on gluing the 60mm wheels to the 2.4 tire?
I searched a few videos that make it look pretty easy... but man these are tough. With no outer edge to catch the glue... the glue has really no other place to get pushed to the face of the wheel, and with no bead on the tire to "snap" into the wheel, its extremely hard to keep the sidewall of the tire even all the way around as there is no outer lip on the wheel to locate it. I don't know, but these seem like a mess. Anyone have luck?
-Speed Passion- Team Associated B5M; SP PRO 1.1 & 17.5 FANTOM TEAM HT
-Speed Passion- Team Associated B44.3; SP Reventon PRO 1.1 & 7.5 v3.0/13.5 MMM
heinen81 is offline   Reply With Quote
Old 01-05-2015, 06:59 AM   #8105
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
use less glue I like to use thinner glues and use less of it.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-05-2015, 07:05 AM   #8106
heinen81's Avatar
Yeah I didn't use much, I guess it was less a problem than I made it sound, because I didn't really get any on the wheel face... but I found it extremely hard to get the side wall "true" all the way around with no real "bead" on the tire, or lip on the wheel, for it to catch and locate on.
Old 01-05-2015, 07:24 AM   #8107
we need a glue jig like the 8th scale guys have
Old 01-05-2015, 07:36 AM   #8108
Mason's Avatar
man up, put a band on the tire. get 'er done. Just keep checking those beads after the first couple of runs.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 01-05-2015, 07:38 AM   #8109
+1 on tire bands. the little glue straws are great to applying the glue right where you want it also.
Old 01-05-2015, 08:05 AM   #8110
PW
PW's Avatar
I'm a huge fan of thin glue; especially when mounting 2.2, but I've found that med glue is the way to go on the 60mm tires.
After cleaning the tires and mounting them on the wheels, I make sure the inner bead of the tire is sitting flat/flush with the wheel bead all the way around. Using med glue with glue tip (glue tip is the key), I pull back the sidewall with my thumb in an angle so that the inner most part of the tire bead is still in contact with the wheel and apply a thin layer of glue about 3/4" at a time as I work around the tire. I put my JC rubberband on the tire and then quickly wipe away all the excessive glue that is pushed out of the bead. Sometimes I will use 2 bands on the rear tires to make sure the bead is completely flush.
Paul Wynn
Old 01-05-2015, 09:41 AM   #8111
rider313's Avatar
Trader Rating: 94 (100%+)
I love my JC roller bag. I am shocked at how much I could fit in it compared to my three drawer Mugen bag. I was conteplating going with a Ogio 9800 and this bag. I went with the JC for its a bit smaller taking up less room in the pits and car. I don't pack light and I can fit all my parts, oils/cleaners, tools, ps/charger, tire washer, car stands lots of tires and pit mat. If I slimmed up some of my containers I could fit my 2 1/10 buggies in there to, but I just throw them on the top against the handle when wheeling.
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Old 01-05-2015, 10:04 AM   #8112
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
I can pack nearly everything I need to go racing anywhere with the JC bag and one 9800. They're built well, are lighter which allows you to pack in the gear. The 9800 is nearly 15 lbs to start off so a bit of a weight penalty when travelling.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 01-05-2015, 10:05 AM   #8113
Jmuck69's Avatar
Does she come with the bag?
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 01-05-2015, 08:24 PM   #8114
1/4milecrazy's Avatar
PW, since we are on the subject of bags I would like to make a suggestion if you think it would be nice maybe run it by the team.
Has anyone ever looked into a modular style bag system? A few pieces that can be bought separately but have a way of attaching to other pieces. Like a roller that that a med or small bag can be secured to and a radio bag that can go on top of that.
Something like this to give you an idea.
I race buggy, stadium truck, 2 and 4 wheel SCT, have a plethora of tires for each model, plus all the stuff that goes along with them and I use an SCT back pack and a roller now, but I still need more room. I hate having to make multiple trips out to the truck when unloading.
Apparently "equal" and "partners" means different things to different people.
1/4milecrazy is offline   Reply With Quote
Old 01-05-2015, 10:38 PM   #8115
Waflet's Avatar
Hideeho
That is an AWESOME idea! That's genius!
Maybe a base bag with a rigid frame that folds open with storage space for tools & oils, wheels & a long pull out handle. The expand with a line of semi rigid bags that attach to that on the outside or the top (& attach to the handle). You could have seperate bags for each type of car, each type of tire, setup board/station, charger/tx, lipos, etc. each person would buy the main wheeled bag & the supplemental bags for what ever clas they run. Then each race day you grab the main bag & bags for what ever clas you are running that day & attach it all together. One trip with 1 bag gets you everything.
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
