Like Tree29Likes
Old 04-21-2014, 05:53 AM   #7486
PW
PW's Avatar
Send a message via AIM to PW
Originally Posted by Tyler Keel View Post
I know this thread is mostly used for 1/10th type discussions as far as tires go, but, I just wanted to jump on say how impressed I am with the 1/8th scale tires that I have been running. I've been running mainly Stackers, Black Jackets and Hybrids all in blue and green compound and have seen very minimal wear over the past month and a half of running them almost every weekend. Couldn't be happier with the switch!
Thanks guys!
TK
Thank you Tyler!
Start the dramatic music
I will volunteer for the one way mission that is testing the SC Dirt Webs. I know it will be a parlous mission to under take. I know it will be filled with lots of finger pulling and wheel spinning and flying dirt, well clay in my case, for hours on end. I may even get blisters on my throttle finger from the long hours of testing. I will use the entire out put of the power company charging my batteries to continue the testing to the fullest. May my untimely demise help those that come after me.
It is a sacrifice I am willing to commit to to help others. That is the kind of guy I am.
Now lots of explosion sounds.
End of trailer.
Buzz.
Valiant effort, but I think we have it sorted
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 04-21-2014, 06:03 AM   #7487
clw
Originally Posted by the incubus View Post
I've found that when 3D's and DD's begin to lose traction or bite, Splitters are perfect!
Those little nobs are so robust the tire bites on the loosest of surfaces. It's what I used for round 2 of the JConcepts Winter series at Coral Springs. Both my cars hooked up well, even though in 2WD mod my driving stunk up the joint and I got clipped nasty in 4WD.
Incubus:
On our S. Florida red clay, from too wet to black groove, is the order; DD, 3D, splitter, Bar code V1, Bar code V2?
Where does the hybrid fit in? Do I have the order correct?
clw is offline   Reply With Quote
Old 04-21-2014, 09:26 AM   #7488
the incubus's Avatar
Trader Rating: 17 (100%+)
I've never had success with bar codes on clay. Usually DD and when it's slippery the splitters. Just bought some super soft 3D's to test a month ago but I won't be Abel to get out for months.
There's no particular order either. It all depends on when you run in the order between track maintenance and the ambient temperature and intensity of the sun. If you run right after they wet down the track DD, as it dries out 3D or splitters, but all work well regardless for the most part. I buy my son the black mega soft DD's and those things are glued!
Trial and error is the best way to learn, but asking fellow racers helps quite a bit.
Another popular tire choice at my track are pink HB Megabytes.
ROB RIVERA
≈ PRS1 2014 :: SP Reventon Pro 1.1 :: Team Powers Plutonium17.5 ≈
≈ DEX410 :: SP Reventon Pro 1.1 :: Reedy Sonic 6.5T ≈
WWW.TRICOUNTYHOBBIES.COM :: WWW.CRPPLUS.COM
the incubus is offline   Reply With Quote
Old 04-21-2014, 07:46 PM   #7489
Well can not blame a guy for begging, can you?
The clay is an indoor track. So it never dries out. I have gold bar codes. Is there a softer compound? I think the shop carries blue?
Buzz.
blvdbuzzard is offline   Reply With Quote
Old 04-22-2014, 08:47 AM   #7490
When will the new grey inserts be for sale on the web site or anywhere?
troyd is offline   Reply With Quote
Old 04-22-2014, 08:52 AM   #7491
Trader Rating: 91 (100%+)
So where are we on that MM RT6 Finnisher? Got a part number yet?
Just leave him alone, he knows what he's doing!
Eric Tomczyk is offline   Reply With Quote
Old 04-22-2014, 09:16 AM   #7492
PW
PW's Avatar
They started shipping to dealers already and will go live today on the website
It's finished and we are working on press release info now; part number is 0269.
Paul Wynn
Old 04-22-2014, 10:06 AM   #7493
mes
Originally Posted by PW View Post
It's finished and we are working of press release info now; part number is 0269.
Finally!
mes is offline   Reply With Quote
Old 04-22-2014, 11:41 AM   #7494
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to BOLISARIO
How do the 2wd grey fronts compare to using open cell foams? Did JC finally find the perfect cc foam that has the same softer feel of an open cell but lasts 2-3x as long?
BOLISARIO is offline   Reply With Quote
Old 04-22-2014, 11:55 AM   #7495
PW
PW's Avatar
The grey inserts are med/firm and the white foam is still considered soft. Still no magic soft "cc" inserts that last for ever...ha
Paul Wynn
Old 04-22-2014, 12:24 PM   #7496
Mason's Avatar
Bolisario, in the mean time run some duck tape around the foam insert once. this will keep the tire carcass from eating the foam up so fast.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 04-23-2014, 04:21 PM   #7497
Is jConcepts got plans to come out with dirt webs for short coarse.
Old 04-23-2014, 05:44 PM   #7498
Trader Rating: 109 (100%+)
Send a message via AIM to kwiksi
Yes.
kwiksi is offline   Reply With Quote
Old 04-28-2014, 08:56 AM   #7499
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
Any plans to improve your supply chain as it relates to tire availability? Even Amain appears to be getting cheeky/sarcastic with availability dates on the Dirt Webs now...
MarkA is offline   Reply With Quote
Old 04-28-2014, 09:31 AM   #7500
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
I ran the DW's in 2wd SC in gold and I believe it was orange at Cactus. They work great!
Indoor clay with the golds has an immense amount of forward bite, almost too much if there's such a thing! lol..good stuff!
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,KoPropUSA,JConcepts,Avid RC,MIP,SikLidz,ImagineItGraphx, FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
