Like Tree28Likes
Old 04-10-2014, 10:19 AM   #7456
clw
Originally Posted by clw View Post
Summertime temps 87 (again) in Florida, Rear Green DDs not the best and fell apart on a calcium treated outdoor clay track. What's a good tire to churn out practice laps without breaking the wallet? I would assume the Orange compound with the heat, bar codes, 3D's , Dirt Webs?
Stick with a groovy in a firmer compound or match the front to the rear choice?
2wd mod buggy (4.2)
Paul:
I grabbed a pair of V1 Bar Codes in blue for both the front and rear. Also ordered a rear 3d in Orange for hot days when the track isn't so abrasive (the calcium washes out). Anything else I need?
What DD's doe I run in the S Fl mid-day runs if the track has moisture?
clw is offline   Reply With Quote
Old 04-10-2014, 10:37 AM   #7457
PW
PW's Avatar
Send a message via AIM to PW
Originally Posted by racer x 1 View Post
Any eta on when dirtwebs will be readily available for the rest of us?
We have had at least 4 different shipments come in and go out to dist, dealers, and direct in the last month.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 04-10-2014, 10:50 AM   #7458
PW
PW's Avatar
Paul:
Unfortunately racing in Florida and especially south FL during the summer is extremely aggressive on tires. Just about every tire that performs well is going to wear very quickly (2 to 3 runs max). We don't run them very often, but Hybrids are probably the best wearing tires for the rear. That might be a great option in blue compound.
Paul Wynn
Old 04-11-2014, 08:15 PM   #7459
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
Is the a silencer body in the works for the EB48.2?
pink_sleeve is offline   Reply With Quote
Old 04-12-2014, 10:38 AM   #7460
rregl0612's Avatar
Trader Rating: 33 (100%+)
Originally Posted by PW View Post
Yes; it will be months before anything production is available. My guess is the wheels will happen first and then the tires. The cool thing is the current tires are easily converted by cutting the bead off. So essentially you can have 1 tire and run whichever wheel setup works best for your track .
Thanks!!!!
And in that case can I put in a request for jc to make a hex Rulux wheel??
Thanks to my sponsors, My Wallet, endorsed by Some crazy pharmaceutical corporation!!!
Member of "The White Wheel Mafia!"
Bumps and Jumps, Pitstop Hobbies, LCRC!
rregl0612 is offline   Reply With Quote
Old 04-12-2014, 06:43 PM   #7461
I have a set of bar codes. I run on an indoor clay track. When the track is wet, after the misters come on, after the track is watered and we wait 20 minutes, the bar codes are like driving on ice. They slip and slide like crazy. Yet, after 10 minutes after the misters, they start to hook up again. Then about 45 minutes after they water the track they start to grab again.
I have tried 3 different sauces, but they have not really helped all that much.
They just changed the track where I drive and man o man, I could not get around a corner without sliding and spinning. It was real bad. The track seemed to be wetter then it was before the change.
Any idea's on how to get them to stick?
Is there another tire that would work?
Brothers Ions seemed to work well with the wetter conditions, but did not work as well with the drier track.
Buzz.
blvdbuzzard is offline   Reply With Quote
Old 04-14-2014, 05:45 AM   #7462
PW
PW's Avatar
Buzz.
I'm guessing you are running Gold compound? Sounds like smaller pin tire (Ion) is good in the wet condition and the bigger pin (Bar Code) is better in the dry? Have you tried a worn out Bar Code when its wet; ghost-pin or slick?
I would think our Gold Dirt Web should be really good.
Paul Wynn
Old 04-15-2014, 06:41 AM   #7463
5th wheel's Avatar
does anyone know where I can get the little screws that go into the J concepts 12mm hex. mine are kind of getting stripped out..thanks
5th wheel is offline   Reply With Quote
Old 04-15-2014, 07:00 AM   #7464
samuelsonmark71's Avatar
Trader Rating: 21 (100%+)
2mm x 6mm will go in a little deeper. I think that is what I have used in the past to make it work/last longer
Samuelson Designs - Custom Airbrushing for your RC needs
---Mugen Seiki, NitroPro Fuels, Samuelson Designs, AKA (Military Assistance)---
samuelsonmark71 is offline   Reply With Quote
Old 04-15-2014, 07:26 AM   #7465
PW
PW's Avatar
Yes; the current hexes now come with 2mm x 6mm screws. You could check a local hardware store or most hobby shops carry them in their fastener section. Most shops that sell plane stuff will have DuBro screws and they have all the sizes.
Paul Wynn
Old 04-15-2014, 07:30 AM   #7466
If I beg and plead, will a body be made for the Tekno ET-48?
I'm not an expert, just a truggy enthusiast
kawi650 is offline   Reply With Quote
Old 04-15-2014, 07:55 AM   #7467
PW
PW's Avatar
I will add it to the loooooooong list of request, but anything Truggy seems to stay towards the bottom
Paul Wynn
Old 04-15-2014, 08:18 AM   #7468
Tech Legend
Wild Cherry's Avatar
Congratulations for JConcepts new Dirt Webs.
IMO
They are the biggest improvement in tires made in many years.
With the competition bringing their new shoes to the market these Dirt Webs are making them go back to the development dept.
kudos to BK and his latest efforts.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 04-15-2014, 08:49 AM   #7469
5th wheel's Avatar
Thanks guys for the info on the 2mm/6mm screws.
Old 04-15-2014, 08:54 AM   #7470
mxracer458's Avatar
Trader Rating: 47 (100%+)
Buzz.
If your running sdrc you need a soft tire,golds are to hard and I've never got them to work out there,i use ions in soft only because i can't get a hold of any dirt webs yet. Ive used sticky kicks and something else i can't disclose for tire sauce and the tires were hooked up,i would get some soft dirt webs when they come out
mxracer458 is offline   Reply With Quote
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
