Like Tree38Likes
Old 03-26-2014, 11:47 AM   #7411
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
I ordered some clamping hexes for my B44.2 buggy from Tower Hobbies, and one of them was defective. Out of the bag It was drilled too large so the screw didn't thread at all, and doesn't clamp. Should I contact JC directly for a replacement or go through the distributer, Tower?
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 03-26-2014, 12:28 PM   #7412
PW
PW's Avatar
Send a message via AIM to PW
You can contact us directly with a description of the problem and all your info - [email protected]
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 03-26-2014, 12:39 PM   #7413
mschumi101's Avatar
Thanks, will do.
Orange Powered!
-Ted
Old 03-26-2014, 02:53 PM   #7414
mick33b4's Avatar
I had the same issue with new B4.1 front hexes. Same vendor. I put a message in through the jconcepts website but have not recieved a response. I will send a message to the 'info' address.
Support MI Off-Road Tracks: AMS:RC Clubhouse:Larry's:Dirtburners
mick33b4 is offline   Reply With Quote
Old 03-26-2014, 05:32 PM   #7415
namewasdallas's Avatar
Just ordered the Monore carbon fiber battery strap for the 22sct hopefully this ends my issues with the battery and foam blocks coming out of the truck. I've been running the blue barcodes and love them. But looking at your website I was a little confused as the different compounds go by how hot it is? if I understood correctly?
I'm running a indoor clay track in Upstate NY and its not heated and the indoor temp is in the 40's right now. So are the blue barcodes good for that.
namewasdallas is offline   Reply With Quote
Old 03-27-2014, 05:47 AM   #7416
PW
PW's Avatar
Normally when it gets cold, we tend to drop down to a softer compound to compensate (rubber hardens in colder temps), but its all traction dependent. If the track is cold, but still produces great traction, then stick with the Blue.
Paul Wynn
Old 03-30-2014, 03:59 AM   #7417
protc3's Avatar
Hey PW, got the punisher all painted and cut. Love this body dude. I need white rims.lol
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-30-2014, 10:23 AM   #7418
Very Nice! My sentiments exactly about the Jconcept entire Line of Punisher Bodies... They always seem to make the car a bit more stable, predictable and Fly nicely... Of course they look great as well!!!
Robert (Bobby) Stroud
Sponsors: Serpent, JCONCEPTS, PT RC Racing oils.
offroadlover is offline   Reply With Quote
Old 03-30-2014, 11:42 AM   #7419
protc3's Avatar
Thanks buddy. Yeah, i got them for all 3 of my cars. Love the tires as well.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 03-30-2014, 04:48 PM   #7420
Default tires punching
I have decide this year too use 4 small holes in my tires to vent them instead of just the two holes. i also have place my hole on the inside of the tire. so my hole location are inside on 3 set of tires at 3 , 6, 9, and 12 if your looking at a clock. Im nut sure if this is a good thing or bad i have herd of this before but forgot where. i am mainly hopping this will help keep the dirts out of the tires just a little more before. i seem to have to open up the same set of tires like 3 times a year before they even get worn out to get the dirt out of them from the tracks, has anybody done this yet. pro and cons maybe or just some input if it good or a bad idea lol.
Team Argus
Team Rw- Mods |www.rw-Rw mods.com|
Hotbodies D8T Argus .23 | tb - 1 pipe|
Hotbodies D812
Hotbodies ve8 Tekin 2050
imrob is offline   Reply With Quote
Old 03-30-2014, 06:39 PM   #7421
T. Herwig's Avatar
Trader Rating: 25 (100%+)
Send a message via AIM to T. Herwig
Nice, love this body too.
Tyler Herwig
Tekno RC teknorc.com ∙ JConcepts jconcepts.net ∙ Spider Hobbies spiderhobbies.com ∙ SMC smc-racing.net ∙ Upgrade RC upgrade-rc.com ∙ Kustom RC Graphics kustomrcgraphics.com
T. Herwig is offline   Reply With Quote
Old 03-31-2014, 12:58 AM   #7422
zachattak's Avatar
Got a question. Where would you use 7's for in 1/8th buggy? Im thinking hard packed light dust, maybe if its blown out to knock the edge off?
Thanks!
DRIVE HARD, RACE HARDER....
zachattak is offline   Reply With Quote
Old 03-31-2014, 04:42 AM   #7423
CENTRAL's Avatar
Will the Double Dees (green) be a good choice for a 4WD 1/10 Buggy on loose – dry soil?
Thanx!
CENTRAL is offline   Reply With Quote
Old 03-31-2014, 05:58 AM   #7424
Captcha's Avatar
When you say four holes on the inside of the tire, are you meaning the sidewall itself? I personally think 4 holes is overkill, and if you do mean the sidewall, then the sidewall would be significantally softer. I normally race at a track that requires slicks and sauce, and we do 2 holes inner sidewall because it prevents the sauce from getting onto foam and deteorating it quicker, but I also run JC rims which have 2 holes pre drilled.
I hope this helps.
As for the green double dees, how much dust does the track get usually, or loose dirt? Does it have a groove under that layer?
Brandon Ryan
Public Relations, and Hype-Man
301 Raceway & Hobby
3404 NE 37 PL.
Wildwood, FL 34785
Captcha is offline   Reply With Quote
Old 03-31-2014, 06:04 AM   #7425
PW
PW's Avatar
Looks awesome Jason and white wheels will look sweet!
Unfortunately we only get 2 or 3 runs out of a set of tires in FL, so I will have to leave that for someone else to answer .
You got it . Hardpack grooved surfaces and they are good in the bumps or square edges.
Will the Double Dees (green) be a good choice for a 4WD 1/10 Buggy on loose dry soil?
That's where I would start.
Paul Wynn
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
