Like Tree33Likes
Old 03-17-2014, 06:41 AM   #7366
Trader Rating: 26 (96%+)
Is there any significant size difference between your new wheel, and the AKA evo wheel?
I'd like to continue using my JC tires on the AKA rims until yours are released, if that's possible.
Also, is it needed to trim the insert as well? (CC)
ntJeff is offline   Reply With Quote
Old 03-17-2014, 06:52 AM   #7367
Just trimmed the bead off of an old tire, and man you have to be careful, cut a bit too deep some places.
Did I do it wrong, or is the mounting area, or "new bead" really small?
Old 03-17-2014, 06:58 AM   #7368
Captcha's Avatar
I was talking to mark pavidis of AKA when they came to FL, and the reason AKA's new evo rims are not roar legal is because the glue bead is slightly to wide. So that would be the reason why the JC wheels new bead you made seem "small".
I have not seen the new JC wheels in person yet, I was practicing with JR Mitch yesterday at NRH, but I was not scoping his equipment out to see if he was testing them, or not.
Brandon Ryan
Public Relations, and Hype-Man
301 Raceway & Hobby
3404 NE 37 PL.
Wildwood, FL 34785
Captcha is offline   Reply With Quote
Old 03-17-2014, 07:34 AM   #7369
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Hi - A couple questions:
1. I noticed sometimes people sand the center section of the tire almost removing the center lugs. In what condition would you do this?
2. Is it ok to run CC in rear and stock 3/4 rear foams in front or should I go CC all around?
Thanks JC!
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 03-17-2014, 07:40 AM   #7370
Captcha's Avatar
Thanks JC!
1. I do not know this answer, as I have never seen this done.
2. I only run 3/4 rear foams in the front of my buggies, as I do not like CC on a rm car. I also run CC rear foams, and personally like this combination.
Brandon Ryan
301 Raceway & Hobby
3404 NE 37 PL.
Wildwood, FL 34785
Old 03-17-2014, 08:47 AM   #7371
Grasschopper's Avatar
Trader Rating: 54 (100%+)
Hmm...I thought that the AKA wheel wasn't legal because they made the bead dia larger than the current standard wheel. Where are details on the new JC wheel?
www.smc-racing.net for all of your Lipo needs
RC10B5, Caster S10B Pro, 22T
Grasschopper is offline   Reply With Quote
Old 03-17-2014, 08:53 AM   #7372
Captcha's Avatar
Larger/wider, if you look at the bead it is not flat horizontally instead of vertically. Thats what I meant by wider.
Brandon Ryan
301 Raceway & Hobby
3404 NE 37 PL.
Wildwood, FL 34785
Old 03-17-2014, 08:55 AM   #7373
Wattsup23's Avatar
Trader Rating: 29 (97%+)
repost
Team Watts Racing
Wattsup23 is offline   Reply With Quote
Old 03-17-2014, 08:59 AM   #7374
Um...what?
When I think wider I go to wheel width inside to outside. Larger dia is the wheel or bead dia.
I'd do WAY better if there were some cross sectional images to look at.
Edit: Ok so my understanding of what AKA did is correct (just watched a video with Mark P). They brought the wheel main OD (not including center ribs) up to the OD of the outside ribs on a standard wheel. Mark talks about it making for a lighter wheel/tire/insert combo (IMO would be great for stock racing) and the ease of gluing. Bringing this home for the JConcepts thread is this was JCon has done as well or did they go a different route? I'd love to hear that they did the same thing as that would help pave the way for ROAR approval IMO.
Old 03-17-2014, 10:01 AM   #7375
I hacked up an old tire just to see how it'd mount up to the EVO wheel, and I have some doubts.
The red part is the new "bead", and it only measures 2.33mm +-, I don't think that's going to hold up to mod motors very well IMO.
The bead on the AKA Evo rim measures 4.70mm +-. Huge difference.
I think I'll wait until dedicated tires come out, don't want to mount up some nice tires only to have them ruined.
Hopefully they'll be out sooner rather than later, but till then I'll stick with the U shaped bead.
Old 03-17-2014, 10:12 AM   #7376
Mason's Avatar
back the chuckwagon up. 2.33mm is plenty. Kinwald glued tires together only using the thickness of the base of the tire(ie not including tread lugs). You drive on these now called BK Bars, Barcodes, etc. CA is some powerful stuff.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 03-17-2014, 10:16 AM   #7377
PW
PW's Avatar
Send a message via AIM to PW
We decided to keep our new Bullet wheel the same size as the evo wheel; which is 60mm or 2.4" O.D. This will more than likely become the new industry standard even though it's still illegal for ROAR/IFMAR events.
Check out this vid from the Cactus where Jason explains the new wheel starting around the 2:30 mark
+ YouTube Video
Give me some time and I will try to explain things a little better.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 03-17-2014, 10:28 AM   #7378
Mason's Avatar
Generally this would be used in a higher bite situation and the outside patterns would be left to keep the edges from grabbing real hard. I think the bro codes resemble this a bit. Many indoor places do this where the track changes between treaded and slicks.
Hope this helps.
Mason McCombs
Old 03-17-2014, 04:56 PM   #7379
suby723's Avatar
Trader Rating: 21 (100%+)
What is the red compound for 2wd buggy front dirtweb? Is this a clay tire or for outdoors?
suby723 is offline   Reply With Quote
Old 03-18-2014, 05:29 AM   #7380
PW
PW's Avatar
Red is designed for blue groove/hot weather conditions and falls between Blue and Orange. No relationship to Gold/Clay compound.
Paul Wynn
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
