Like Tree38Likes
Old 12-21-2013, 08:54 AM   #6931
jk racing's Avatar
Trader Rating: 20 (100%+)
The new Hazards for the RC10 are 1.9 front & 1.7 rear. I dont think you can run any 2.2 tires on them. I just glued up my JC tires onto the Hazards last night
--Joey --Venom Batteries & Chargers -- Maclan Motors
Old School Racer & Vintage RC Car nut
RC10,RC10 Worlds rere (X2),RC10CE,RC10M,B2,B3,B4,B5, B5M, B6D 10T,T2,T3,T4,T5M,GT5M
JRX2,LXT,XX-CR,22.4 1.0
RC10L4-O,Academy SPX-O,TRX1
jk racing is offline   Reply With Quote
Old 12-21-2013, 09:09 AM   #6932
oldnfat's Avatar
I understand. Too bad those tires will not work on our indoor track. I was just hoping that there might be something coming to use the 2.2 tires and keep the stock rc10 axles.
oldnfat is offline   Reply With Quote
Old 12-24-2013, 01:57 AM   #6933
Guest
Send a message via Yahoo to kyoshoracer77
Hello P.W
I got yalls sway bar mounted on my sc10.2 and I can't get the front sway bar mounts tight enough without locking down the sway bar from moving freely, do I need to do a little trimming on the mounts or just run it tight and see if it frees up? The rear mounts are fine, nice an tight and free. In the front I used the 1.6mm bar and 1.2 in the rear. (To me it seems like the slot needs to be just a hair deeper or sand half of the nylon washer to get free movement??)
kyoshoracer77 is offline   Reply With Quote
Old 12-24-2013, 03:41 AM   #6934
KAWIDAD's Avatar
Trader Rating: 24 (100%+)
[QUOTE=kyoshoracer77;12839446]Hello P.W
I got yalls sway bar mounted on my sc10.2 and I can't get the front sway bar mounts tight enough without locking down the sway bar from moving freely, do I need to do a little trimming on the mounts or just run it tight and see if it frees up? The rear mounts are fine, nice an tight and free. In the front I used the 1.6mm bar and 1.2 in the rear. (To me it seems like the slot needs to be just a hair deeper or sand half of the nylon washer to get free movement??)[/Q
The 2 blue "slide nuts"(not sure what they are called) that go on the top plate have different size groves notched in them. You might just have to turn those 90deg and use the bigger notches. Hope that helps
"The successful warrior is the average man, with laser like focus"-Bruce Lee
"A lot of people are afraid of heights. Not me, im afraid of widths"
KAWIDAD is offline   Reply With Quote
Old 12-24-2013, 05:51 AM   #6935
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
Any plans on a nb48 silencer body?
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 12-24-2013, 07:10 AM   #6936
PW
PW's Avatar
Send a message via AIM to PW
Possibility...
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 12-24-2013, 08:48 AM   #6937
Guest
[QUOTE=KAWIDAD;12839518]
Originally Posted by kyoshoracer77 View Post
Hello P.W
I done that, the wire is in the biggest slot.
Old 12-25-2013, 09:25 AM   #6938
mblgjr's Avatar
Trader Rating: 86 (100%+)
[QUOTE=kyoshoracer77;12840087]
Triple check the castle piece just to be sure. Installed a couple of these kits without issue. If you still have interference just faintly file the slot or backdrag a hobby knife across the edges of the alum to break the edge. Otherwise it'll be fine in about 5mins of runtime so long as it's not jamb up tight.
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 12-25-2013, 08:23 PM   #6939
Guest
[QUOTE=mblgjr;12842349]
I took off some of the blue anodized and I was able to tighten it up fine.
Are the jconcepts ball ends as tight to snap on like the one on the sway bar?? If so I want them!!!!!!!!
Old 12-26-2013, 06:52 AM   #6940
Now that the B5 has been announced, are you still going to move forward with Centro parts? I am hoping that you will still release the narrow rear hinge pin mounts.
AERob is offline   Reply With Quote
Old 12-26-2013, 07:31 AM   #6941
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Good question ....
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 12-26-2013, 09:53 AM   #6942
mblgjr's Avatar
[QUOTE=kyoshoracer77;12843725]
Yes, they fit very well when used with stock ball studs.
Pair the JC ends with the JC studs for a "Zero slop" fitment
Ends
http://www.jconcepts.net/store/index...roducts_id=708
Ball Studs (available in .200/.300/.400 lengths
http://www.jconcepts.net/store/index...roducts_id=710
Old 12-26-2013, 11:01 AM   #6943
s.amadorJR's Avatar
so what is the scoop on the black compound tires? I will be trying some this weekend but I want to know if anyone has compared it to AKA's Super Soft compound.
www.LAPartsHouse.com
https://www.facebook.com/LAPartsHouse
[email protected]
(714) 441-2274
s.amadorJR is offline   Reply With Quote
Old 12-26-2013, 05:46 PM   #6944
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
What can you tell me about the following items?
Splitters?
G-Locs?
Dirt Webs?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 12-26-2013, 07:02 PM   #6945
mblgjr's Avatar
JC green is softer/grippier than Aka SS.
Black is best when running in cool, damp, clean/indoor conditions. It offers that last bit of traction, esp when it's cold. Its def a bit grippier than green, but doesn't drive "softer" or squirmy like some ultra soft compounds can.
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
