Like Tree28Likes
Old 12-15-2013, 01:16 PM   #6901
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
Originally Posted by kyoshoracer77 View Post
Help anyone??
Front and rear for the truck included in package.
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 12-16-2013, 05:36 AM   #6902
PW
PW's Avatar
Send a message via AIM to PW
The sway kit yall got for the t4.2 an sc10.2. Is it a front and rear kit or do I need to buy 2 of them to complete 1 truck or a buggy??
It is a front and rear kit.
just me or does that look like a taller pressurepoint? that would be a dialed tire around here.
Just a standard Pressure Point with some really sticky dirt.
PW,
Is the pivot blocks going to be the front and rear? Or just the rear? Also, a price? Thank you.
It's a front and rear that narrows the rear hinge-pin width. I will have to check on price.
Is there an eta and a part number for the new front buggy tire dirt web ?thnx
The 2nd week of Jan and Part number is going to be 3077
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 12-16-2013, 06:03 AM   #6903
Captcha's Avatar
Hey paul, shoot me a PM if you still need my help at Shiverville this weekend, and let me know what time to be there and such.
Brandon Ryan
Public Relations, and Hype-Man
301 Raceway & Hobby
3404 NE 37 PL.
Wildwood, FL 34785
Captcha is offline   Reply With Quote
Old 12-16-2013, 07:16 AM   #6904
mxnickj's Avatar
Trader Rating: 51 (100%+)
What are some recommendations for tire additives? There are so many out there and I'm pretty new to the whole indoor clay racing scene. I do 95% or my racing outdoors where the tire sauce isn't really a big deal. Whats a good place to start? I've heard good and bad about just about every brand out there so I don't know what to believe.
mxnickj is offline   Reply With Quote
Old 12-16-2013, 07:18 AM   #6905
Trader Rating: 119 (99%+)
It's all track sensitive. Nobody on here can really give you good advice unless they race at the same track. What works at my track my not work at yours. Best advice is to go to your local track and ask the fast guys. Then just stick with that no matter what you might read about it
skoalisbad4me is offline   Reply With Quote
Old 12-16-2013, 07:21 AM   #6906
Captcha's Avatar
We make our own for one of the local indoor tracks that we used to primarily race at. We thought it would only be good there, went to the regionals, and it was the only sauce working at a different track. Now with our outdoor track picking up, we are using it again once the track warms up, but using just basic good ole wd-40 and black compound JC tires went it is cold and damp.
The point behind this post, is that anything can work anywhere, first you have to have the right tire. All any additive really does is soften the rubber to help the tire get up to temp quicker.
Brandon Ryan
301 Raceway & Hobby
3404 NE 37 PL.
Wildwood, FL 34785
Old 12-16-2013, 02:15 PM   #6907
tfrahm's Avatar
Send a message via AIM to tfrahm
(I did a search and came up with nothing, so...)
I finally was able to get the new 'Black' Bar Codes for my stadium truck... The LHS didn't have any of the JConcepts #3205-1 inserts (and neither did their distributor, and JConcepts shows "out of stock"), so I test fitted closed cell inserts from ProLine and AKA... The red AKA inserts seemed(?) to over-fill the tire, causing too rounded a profile. The blue ProLine inserts were "close", but did under fill the tire, but since I wanted to use the tires last weekend, I used them. That now seems to have been a poor choice, since the tires hooked up great in terms of forward bite, and worked most of the time in terms of side bite, but were EXTREMELY unpredictable in the corners. It appears that the 'Black' Bar Codes are slightly "bigger" than 'blue' or 'green' because I can use ProLine inserts with those compounds without problems, but the 'Black' tires are not "filled" by these inserts and in the turns, they hook up great, then suddenly (and unpredictably), the tire will roll under, causing the truck to snap loose... Very hard to drive... Even worse, the tires "work" where the traction is not as good, but snap loose where the track is the most "tacky"...
Given the lack of JC inserts, what are other people using...?
PS: in the buggy 'Black' Bar Codes, AKA inserts seem to be perfect. At our local indoor track, the stock JConcepts white foam is too soft for use in the rear tires (major roll-under in the turns), so I need to find a good closed-cell insert...
"If you cannot win, make the one ahead of you break the record."
Biff Racing Team #420 (Ah... The "good old days"...)
The local indoor Offroad Track: The RC Race Barn
TLR22-3.0, TLR22T-2.0, TLR22SCT-1.0
tfrahm is offline   Reply With Quote
Old 12-16-2013, 03:38 PM   #6908
Trader Rating: 33 (100%+)
Any info on a mid motor body for the Kyosho RT6? Heard one was being made but couldn't find much info on it.
GettinLapped is offline   Reply With Quote
Old 12-16-2013, 04:17 PM   #6909
Eta on the dirt webs?
Mike Richardson
At the track having fun with my friends
blingy is offline   Reply With Quote
Old 12-16-2013, 06:18 PM   #6910
Suspended
Trader Rating: 23 (100%+)
Look up ^
Airtronics - Carburant Racing - EZ Customs - 92zero Designs
Team G Racing is offline   Reply With Quote
Old 12-16-2013, 07:51 PM   #6911
Thank you P W
Mike Richardson
Old 12-16-2013, 08:11 PM   #6912
Guest
Send a message via Yahoo to kyoshoracer77
The only reason I asked about the sway bars is because the jconcepts website only shows pics of the front and not the rear.
kyoshoracer77 is offline   Reply With Quote
Old 12-16-2013, 10:13 PM   #6913
aeRayls's Avatar
My question is, where did you get Black compound barcodes for stadium truck? Last time I checked JC doesn't make them.
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 12-16-2013, 10:46 PM   #6914
Are there any plans to make the " Silent Speed " spur gears for the new 22 HD slipper pad design?
Medicinal Coma is offline   Reply With Quote
Old 12-17-2013, 06:13 AM   #6915
PW
PW's Avatar
The current Finnisher body has lines for mid motor; nothing mid-motor specific at the moment.
Most likely just an oversight on our part.
I was thinking the same thing; someone must have a nice hook-up
I honestly didn't even realize they changed; we will have to look into it. So no plans at the moment
Paul Wynn
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
