Like Tree38Likes
Old 11-18-2013, 02:11 PM   #6766
Send a message via ICQ to JiuHaWong
Originally Posted by PW View Post
We will be offering a complete rear upgrade kit for $78 (alloy bulkhead, new graphite tower, and alloy wing mounts). The parts will also be available separately and I think the bulkhead will be $24.
We will also be offering the narrow hinge-pin set for around $30
I believe everything is going through QC and packaging now, so hopefully we should be seeing everything very soon.
Nice! Hopefully we can get the parts before xmas!
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 11-21-2013, 01:20 PM   #6767
Just picked up a set of 1/8 Barcodes. I've searched but can't seem to find the difference between mounting the big "Y" in versus out. Any help would be appreciated. Thanks
Mototech is offline   Reply With Quote
Old 11-21-2013, 01:24 PM   #6768
Jake S's Avatar
Trader Rating: 66 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
http://www.jconcepts.net/index.php?/...ail_details/39
google, 10 seconds.
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 11-21-2013, 02:09 PM   #6769
Trader Rating: 26 (96%+)
Is it true that the new bulkhead will only work with the jconcepts tower?
ntJeff is offline   Reply With Quote
Old 11-21-2013, 02:28 PM   #6770
PW
PW's Avatar
Send a message via AIM to PW
Correct; with the added inner camber link holes (for narrow hinge-pin mounts) and lower alloy wing mounts, the bulkhead/tower mounting holes needed to be changed.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 11-21-2013, 02:54 PM   #6771
tedstryker's Avatar
Trader Rating: 75 (100%+)
eta for carbon front tower b4?
AGAMA A215E
TLR 22T 2.0
Kyosho RT5
Kyosho RB6.6
tedstryker is offline   Reply With Quote
Old 11-21-2013, 04:43 PM   #6772
So the lower price of the bulkhead is irrelevant, because I would need a new shock tower....
Guess I'll get the ghea one.
Old 11-22-2013, 05:30 AM   #6773
PW
PW's Avatar
I haven't heard anything yet.
If that's the way you choose to look at it. That's the great part about this hobby, we the racers have so many choices.
I personally see it as getting optional parts that gives me more adjustment and a much stronger rear tower and bulkhead (I've seen 2 Ghea bulkheads bent; one on Maifield's car at the Worlds). I also like the option of having alloy wing mounts.
Paul Wynn
Old 11-22-2013, 06:54 AM   #6774
aeMatt's Avatar
PW...Can you provide status of black B4 hingepin braces? JC still going to offer black or only blue? Thanks.
Team Associated\\\\\\Reedy\\\\\\JConcepts\\\\\\Airtronics\\\\\\Upgrade RC
www.rc10.com/www.jconcepts.net/www.airtronics.net/www.upgrade-rc.com
aeMatt is offline   Reply With Quote
Old 11-22-2013, 07:05 AM   #6775
5th wheel's Avatar
How does tHat J concepts chassis protector work on the b4.1 I know it sticks on the bottom of the chassis is it really worth the money for it and if you need to get to the screws on the bottom of the chassis I don't see how you would do that without messing up the chassis protector. and once you peel it a way to get to the screws I am guessing it's no longer any good. say if you need to tighten something up or remove the transmission it's hard to do with the chassis protector and does it really protect the bottom of the chassis in the screws I notice on mind that it does rub the track coming of the jumps a little bit thanks for your help
5th wheel is offline   Reply With Quote
Old 11-22-2013, 07:58 AM   #6776
PW
PW's Avatar
We just received them and they are in stock, but the website hasn't been updated yet.
It's precut to fit the B4.2 chassis and is peel and stick. There are 2 main reasons people use chassis tape:
1. To protect a fresh chassis and T-plate. Keeps it looking new months/years of use. Makes it nice for resale value .
2. The chassis tape provides a smooth or slick surface to decrease friction between the chassis and dirt surfaces. We don't see this problem much here in FL, but in the smaller indoor tracks up north & mid-west. Their tracks are normally wet/damp sticky surfaces and the chassis can stick to the dirt up the faces of jumps and or hard landings. It also helps from screws snagging the dirt and keeps the dirt from packing in the screws.
I have peeled back my chassis tape a few times to work on the car, but you can only do it a few times when the tape is fairly fresh.
Paul Wynn
Old 11-22-2013, 09:28 AM   #6777
Waflet's Avatar
Trader Rating: 30 (100%+)
Hideeho
As an end user, I can say the chassis protector does make a big difference in the wear of the chassis. I do have a suggestion though. I noticed on mine, & then compared to other b4 chassis', most of the wear is in the back on the "T" plate. How about including, or selling seperately, an extra precut sheet for just the "T" plate to get extra reinforcement for the highest wear area?
To remove the screws that need to come out, I use an exacto & cut a small circle for the screw to come out. I try to make it smaller the the head & pull it through. When done like this It will be under the screw when it is screwed back in. When I have failed to get it right, I still haven't had much issue with it tearing.
"Just leave me alone, I know what I'm doing."-Kimi Raikkonen
Mugen MBX7R Eco/Tekin RX8g2/Savox 2274/SMC 1900kv/Aitronics mt-4/promatch
Mugen MSC7(1/10 pro4 sct)/Tekin RX8g2/Savox 2274/Tekin Pro4HD 4300kv/Airtronics mt-4/SMC
Waflet is offline   Reply With Quote
Old 11-22-2013, 10:15 AM   #6778
PW
PW's Avatar
Originally Posted by Waflet View Post
Hideeho
Noted and will mention it during the next project meeting.
Paul Wynn
Old 11-22-2013, 12:46 PM   #6779
KAWIDAD's Avatar
Trader Rating: 24 (100%+)
Hideeho
+1-on both topics
"The successful warrior is the average man, with laser like focus"-Bruce Lee
"A lot of people are afraid of heights. Not me, im afraid of widths"
KAWIDAD is offline   Reply With Quote
Old 11-22-2013, 12:47 PM   #6780
mxnickj's Avatar
Trader Rating: 51 (100%+)
Hideeho
Same thing I noticed on 1/8 buggy chassis also, the rear takes most of the abuse. I wish there was something like the chassis protector for 1/8 scale that covered the whole chassis and not just sections like the DE skidplates do. They work awesome for what they were designed for, I just wish there was another option with more protection.
mxnickj is offline   Reply With Quote
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
