Like Tree33Likes
Old 11-18-2013, 06:01 AM   #6751
PW
PW's Avatar
Send a message via AIM to PW
Originally Posted by B4TravSC10 View Post
Silly question. Does the JC body for the 22 fit mid-motor
Yes, but it doesn't have the cut lines.
Are the JC C4.2 rear bulkheads going to be cheaper than the $50 ae ones?
Press release should be posted this week...
We will be offering a complete rear upgrade kit for $78 (alloy bulkhead, new graphite tower, and alloy wing mounts). The parts will also be available separately and I think the bulkhead will be $24.
We will also be offering the narrow hinge-pin set for around $30
I believe everything is going through QC and packaging now, so hopefully we should be seeing everything very soon.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 11-18-2013, 07:35 AM   #6752
Trader Rating: 17 (100%+)
Default Narrow rear pivots
Paul Could you please explain to us what narrow suspension pieces do? What other changes are needed to make it all work properly, track width, upper turnbuckle position??
dirtyrc is offline   Reply With Quote
Old 11-18-2013, 08:05 AM   #6753
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
They decrease rear toe. Will they be adjustable with inserts, or only come in predetermined values?
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 11-18-2013, 09:28 AM   #6754
Default Narrow suspension C4.2
If that is the case then why is Jconcepts and Ghea marketing them as narrow suspension pieces? From what I understand the narrow toe blocks frt and rear are narrower than the factory toe blocks that come in the kit. PW please corret me if I am wrong.. Based on one of your previous posts you stated that if you narrow the hinge pins you also need to move the inner upper ball stud inboard as well.
Old 11-18-2013, 09:56 AM   #6755
Send a message via AIM to David Alberico Send a message via Yahoo to David Alberico
I did some testing with some inserts and I still like the JC inserts, a lot of guys asked me how I got mine to last, I've had a couple sets in a few different tires and they last quite a while and I was asked how...I actually use scotch guard on them and blocks out the water for when they are washed....Just a tip for everyone. I really prefer the feel of the JC inserts
Castle Creations, J-Concepts, WMD Products, Clints Creations
David Alberico is offline   Reply With Quote
Old 11-18-2013, 10:04 AM   #6756
mxnickj's Avatar
Trader Rating: 51 (100%+)
Can anyone explain to me why a set of double dee's (on a RC8.2e buggy) would have strips of the tread pins missing after only 2-3 packs run through them? When you look closely at the tires there is small spots where there is about 4 or 5 pins in a row just completely missing.
mxnickj is offline   Reply With Quote
Old 11-18-2013, 10:18 AM   #6757
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Thumbs up
Nice tip!! thanks..
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 11-18-2013, 10:40 AM   #6758
t0p_sh0tta's Avatar
Usually only see that when jumping pipes, or powering off of them. The absolute fastest way to ruin a tire IMO.
Old 11-18-2013, 11:21 AM   #6759
PW
PW's Avatar
Basically what happen is the C4.2 comes with a wider inner hinge-pin width compared to the original C4.1, but some of the drivers still prefer the C4.1 rear suspension geometry. So we are making narrower hinge-pin mounts to have the option of the C4.1 geometry on the C4.2 (the toe-in stays the same at 3deg). The wider pin mounts basically lower the RC and the narrower pin mounts raise the RC. Our new rear tower has the corresponding inner camber-link mounting locations for either hinge-pin geometry.
Like t0p_sh0tta mention; most of the time it happens when the buggy gets hung-up on pipes and excessive throttle is used to get off the pipe. There has been occasions when it happens on the very first run without any pipe jumps; this could be a defect in the tire and you should contact JConcepts directly - [email protected]
Paul Wynn
Old 11-18-2013, 12:09 PM   #6760
Trader Rating: 42 (100%+)
Default stadium truck tires
how are bar codes mounted on the wheels. little y's out or big y's out? havent mounted truck tires in a long time, forgot this lol
X-factory x-6^3/orion/ revtech/jr/futaba
Ft B4.2
Haulenass210 is offline   Reply With Quote
Old 11-18-2013, 12:14 PM   #6761
fq06's Avatar
Small "y" to the inside has more side bite.
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 11-18-2013, 12:17 PM   #6762
PW
PW's Avatar
"Y" = more side-bite
"u" = less side-bite
Paul Wynn
Old 11-18-2013, 12:38 PM   #6763
Should the front and back be mounted different?
Ft B4.2
Old 11-18-2013, 12:40 PM   #6764
PW
PW's Avatar
Driver/truck preference; more steering, less steering, more rear bite, less rear bite....
Paul Wynn
Old 11-18-2013, 02:10 PM   #6765
3srcracing's Avatar
Trader Rating: 25 (100%+)
How much will the C4.2 Rear Bulkhead cost?
A Main Hobbies | Protek R/C | Team Powers R/C | Cheater Racing
3srcracing is offline   Reply With Quote
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
