Like Tree29Likes
Old 10-19-2013, 09:35 PM   #6601
Originally Posted by lodhammerdin View Post
PW, I need to know if the JC reedy sonic motor timing cover will work on both the mach 2 motors as well as the original version 1 reedy sonic motors. Thanks.
yes works on both
Rick442 is offline   Reply With Quote
Old 10-19-2013, 09:40 PM   #6602
lodhammerdin's Avatar
Trader Rating: 77 (100%+)
Originally Posted by Rick442 View Post
yes works on both
No that I dont believ or doubt you but can you please tell me how you know? Money is a little tight with me now so I just want to be sure that I'm going to be able use it. I do appreciate your help in this matter, also, how do the timing markers line up with each other? Thanks again.
FT B44.2 / FT B4.2 / FT SC10.2 / Reedy / Orion / Airtronics / Pro-Line
lodhammerdin is offline   Reply With Quote
Old 10-19-2013, 09:46 PM   #6603
wayboarder's Avatar
Trader Rating: 14 (100%+)
When is the expected in stock date for the C4.2 aluminum bulkhead?
wayboarder is offline   Reply With Quote
Old 10-19-2013, 09:53 PM   #6604
I know cause i have used it on both motors, it was made for the sonic mach 1 because it had a plastic timing cover, the mach 2 has an aluminum one stock so not need to replace it but i did any way.The timing marks line up the same as factory. If money is tight i would spend it on things to make you car go faster or handle better, cause this just will make your motor look cool.
Old 10-19-2013, 10:03 PM   #6605
Ok. Thanks. I was intending to buy it to help with motor temps. Did they help with motor temps at all?
Old 10-20-2013, 03:03 PM   #6606
Can anyone tell me what kind of differences in motor temps they saw when going from the plastic end bell cover to the aluminum JC one for the reedy motors?
Old 10-21-2013, 05:50 AM   #6607
PW
PW's Avatar
Send a message via AIM to PW
Originally Posted by cooper126 View Post
PW, will the C4.2 rear aluminum bulkhead be available in blue and black?
That is the plan.
I don't know for sure, but I think the first of Nov.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 10-21-2013, 05:53 AM   #6608
PW
PW's Avatar
Originally Posted by KAWIDAD View Post
Ok, I got a quick newb question(my first body to cut out and paint). When cutting out the "champion" name plates, where do I cut them? Where I have the black line or closer to the bottom where the red piece of tape is, so the jconcepts stamp will be part of name plate? Thanks for help
Yes, cut it where you have the black line.
Paul Wynn
Old 10-21-2013, 10:32 AM   #6609
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
what is the thickness on the non precut chassis protectors?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 10-21-2013, 11:30 AM   #6610
Trader Rating: 99 (99%+)
Default #2181 ball cup placement ??
Anyone have images other then on the few jconcepts website on what #2181 ballcups to use where on the AE Rigs? I have the complete .2 collection.
If no pics, a explanation of where what cups are used would be appreciated.
I do understand the rear hub and steering linkage ones of course.
Thanks in advance
RC8.2e - B5M - B44.3
isarctard is offline   Reply With Quote
Old 10-21-2013, 11:34 AM   #6611
PW
PW's Avatar
.5mm
Paul Wynn
Old 10-21-2013, 11:39 AM   #6612
wow, that is almost 20 mills
Old 10-21-2013, 11:43 AM   #6613
PW
PW's Avatar
Thanks in advance
It's racer preference:
The rounded cups are standard length and are my preferred cup. The square cups are longer (overlap the turnbuckle) for added strength, but can be a little more difficult to use. These cups are made from a much harder material and can be very tight on the turnbuckle threads. I have found that if you pre-drill the cup with a 3/32 drill bit, it threads on much easier allowing for easier adjustment.
Paul Wynn
Old 10-21-2013, 11:45 AM   #6614
PW
PW's Avatar
That's with the paper backing; I still prefer the clear uncut chassis tape over the precut
Paul Wynn
Old 10-21-2013, 11:47 AM   #6615
tyvm, for such a quick reply.
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
