Like Tree38Likes
Old 08-23-2013, 06:50 AM   #6406
PW
PW's Avatar
Send a message via AIM to PW
Originally Posted by LoudOne View Post
Which front wheels from JConcepts fit the B44.2? Are the Rulux wheels a direct fit?
The older Rulux 3307 will fit the B44.2, but we don't offer a Rulux for the rear using hex. You would have to switch to pin style in the rear.
We also offer a dish wheel 3349 that fits the B44.2.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 08-26-2013, 01:51 PM   #6407
Waflet's Avatar
Trader Rating: 30 (100%+)
Hideeho
I installed a full set of the JC ball cups, including the angles ones to clear the rear shocks. I had heard they popped on easily, so I wasn't terribly surprised when they were. I used the square ones on the outside rear camber links & both inside & outside front camber links. I used the smaller round ones on the steering links. I also installed the short ones for the steering link. The plastic seems to be a rather hard (but not brittle) plastic. They looked good & had minimal flashing from the casting process. I was quite pleased with the cups overall. I did this install in the morning of a race day, so I didnt have time to run it before the 1st qualifier.
Our current layout has a jump onto a table top which forces a flat landing. The table top surface is on the same level as the top of the jump, which doesn't throw you too high, & is about 5'-6' in the air. If I land it slightly nose down I don't bottom even though it is a flat landing. In other words it's a pretty easy jump. Before the 1st heat I go out to run a few warm up laps & to make sure everything worked. After running 3 or 4 laps I was on comming back to the start line to get ready to start the qualifier & landed completely flat for the 1st time. To my surprise the car bottoms HARD & stays there. When the marshal picks it up BOTH rear wheels flop out. Both rear inner ball cups (the angled ones) had popped off. I put them back on (after asking for a minutes grace ) & proccede with the race. During the race I popped 2 more ball cups, both rear inner cups, none were the result of tumbling or particularly hard landings.
Needless to say, by the 2nd heat I had RPM cups back on the car. Enough said!
"Just leave me alone, I know what I'm doing."-Kimi Raikkonen
Mugen MBX7R Eco/Tekin RX8g2/Savox 2274/SMC 1900kv/Aitronics mt-4/promatch
Mugen MSC7(1/10 pro4 sct)/Tekin RX8g2/Savox 2274/Tekin Pro4HD 4300kv/Airtronics mt-4/SMC
Waflet is offline   Reply With Quote
Old 08-26-2013, 02:10 PM   #6408
KAWIDAD's Avatar
Trader Rating: 24 (100%+)
Waflet- did each type of ball cups fall off or was it just the angled ones? I was going to purchase the same kit, so trying to get as much info as possible.
KAWIDAD is offline   Reply With Quote
Old 08-26-2013, 02:12 PM   #6409
PW
PW's Avatar
Originally Posted by Waflet View Post
Hideeho
Unfortunately the angled ballcups aren't designed for the inner rears and that is most likely the issue. They are designed for the outer rear to give extra clearance for the rear wheels, not for BB clearance.
Here is a quote from the website and press release "Included is an angled version of the Wedge which can be used on the outside of the rear camber link for increased clearance on the rear wheel."
Website updated.
Sorry you had some issues with the inner ballcups popping off, but I swear by these ballcups and won't be changing back.
Paul Wynn
Old 08-26-2013, 02:17 PM   #6410
Suspended
hoonigantoo is offline   Reply With Quote
Old 08-26-2013, 02:19 PM   #6411
Waflet's Avatar
Here is a quote from the website and press release "Included is an angled version of the Wedge which can be used on the outside of the rear camber link for increased clearance on the rear wheel and also to the inside which increases clearance around big bore shock springs."
Hideeho
The highlighted part was the part that was important to me as b4 driver. With the way I have things set up I don't actually need extra clearence, so I guess I'll give the regular cups a try on the inside, since I have them any way.
The problems were just with the angled cups on the inside. The out side & fronts never popped.
Old 08-26-2013, 02:27 PM   #6412
PW
PW's Avatar
Hideeho
Sorry I didn't catch that; they were suppose to fix that because the ballcups were hitting the dust cover.
Website has been updated.
Paul Wynn
Old 08-26-2013, 02:48 PM   #6413
PW
PW's Avatar
Hideeho
Quick question; are you using the shaved "U" brace or just the stock one with 1 or 2 limiters?
Paul Wynn
Old 08-26-2013, 05:05 PM   #6414
Any plans for a finnisher body for TD DEST210 ?
Team Associated TC7.1/HW XR10 Stock Spec/HW Bandit 10.5T/Arrowmax LP 52000 7.6v
IVAN RM is offline   Reply With Quote
Old 08-26-2013, 05:20 PM   #6415
Jmuck69's Avatar
Trader Rating: 14 (100%+)
The ballcups are solid and haven't popped one. I did use the angled ballcup on the inner rear and did hit the dust cover but I heated that area of it and depressed it so it clears and spur gear clears. I use the black gearcover.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 08-26-2013, 05:40 PM   #6416
onefast8's Avatar
Trader Rating: 41 (100%+)
Any chance JC could make a rear tower for the B4 to run BB shocks that doesn't require any shimming, canting of shocks or dremeling, since AE isn't apparently interested in producing an adequate tower?
Jake R.
onefast8 is offline   Reply With Quote
Old 08-26-2013, 05:46 PM   #6417
YankeeFan123's Avatar
Get either the Associated A or C hub and you can mount it on the back side of the hub
Brenden Edwards
B5M| T5M
YankeeFan123 is offline   Reply With Quote
Old 08-26-2013, 05:49 PM   #6418
onefast8's Avatar
Been there, done that. No thanks.
Jake R.
Old 08-26-2013, 05:56 PM   #6419
Has anybody drilled holes through the ballcups for easier adjusting?
Edit: sorry dumb question lol. will get the new ballcups.
Any ideas if the new ones work with DEX210 and AE ball studs?
jaank is offline   Reply With Quote
Old 08-26-2013, 07:06 PM   #6420
KAWIDAD's Avatar
I take it you did try to mount on the back of hub....what affect did it have? Why didnt you like?
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 12:04 PM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 09:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 10:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 04:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 07:54 PM
