Like Tree38Likes
Old 08-14-2013, 08:28 AM   #6361
Super Moderator
Trader Rating: 17 (100%+)
Originally Posted by PW View Post
I will look into it.
We have had several customers tell us that they use the 4PK case, but I can't confirm it myself. I will try and found out.
This does work. I test fit my 4PL in Mike Gay's 4PK case and it fit's fine.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 08-14-2013, 09:46 AM   #6362
PW
PW's Avatar
Send a message via AIM to PW
Originally Posted by KAWIDAD View Post
Any idea when the carbon fiber steering rack for the ae vehicles (jci2264) will be back in stock?
Not sure; I will try and find out.
Thank you Bob
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 08-14-2013, 01:16 PM   #6363
PW
PW's Avatar
Click Here for info - over 400 pre entries and counting
Paul Wynn
Old 08-14-2013, 01:51 PM   #6364
I have the Futaba hard case and a 4pl didn't fit. Would take major trimming. Don't know if the jconcepts case foam is different, but that's my experience.
arizona82 is offline   Reply With Quote
Old 08-14-2013, 01:52 PM   #6365
CraigMBA's Avatar
Trader Rating: 22 (100%+)
I don't participate much on this site anymore, but I want to thank JC for the awesome sway bar kit. I built one that turned out to be very similar to BKs original about a year and a half ago (thanks to too much time and a scaling ruler and a bunch of pictures) and the JC product contains several pieces (aka pre bent sway bars, chassis mounting hardware) that are an improvement over my original knock off.
Plus, it comes with that bomb PW setup....
Thanks again.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 08-14-2013, 02:14 PM   #6366
TomErickson's Avatar
I tried 3ds (green) last night on our medium bite clay track with some dust and they worked great on my B4.2FT. Great balance of forward and side bite. I would recommend these to everyone that races at Dirtburners in Livonia.
---Thanks to my Sponsors: Novak R/C, and Nankin Hobbies ----
TomErickson is offline   Reply With Quote
Old 08-14-2013, 02:21 PM   #6367
Super Moderator
As I said, I took my radio and placed it in Mike's JConcepts case for the 4PK and it fit fine.
Old 08-14-2013, 05:11 PM   #6368
D.Martijn's Avatar
This definitely isn't normal; what type/brand of wheel are you using?
Hi, like Wildcat said, I was able to fix it. but.... Only for a short period of time..
I fixed it, ran a race on sunday and the clicking is there again..
I'm running the Team Associated 12mm hex wheels.
The other axle doesn't have this problem.
I tried many things, putting all new bearings, switching axles, removing some material in side the steering block so the bigger diameter of the axle cant rub it, 1 shim, 2 shims..... The clicking is still there, it's driving me nuts.
I did noticed when I opened the package the axle that is clicking had a little rougher finish on the bigger diameter part?
Here is a video I made about the clicking.
http://www.youtube.com/watch?v=rWLTb...JEPA4y_frbEI6A
D.Martijn is offline   Reply With Quote
Old 08-14-2013, 05:49 PM   #6369
BIGSKI15's Avatar
Trader Rating: 18 (100%+)
I'm building my rib and wedge turn buckles for my b4.2 but I have a question. Is everyone using the smaller cups all the way around other than the angled cups in the rear? I built my rear turn buckles with the angled cups on the u brace and the heavy duty cups on the hub tower. I was planning on using the smaller cups in the front unless there are other recommendations.
B6D
B5M
Airtronics M12
BIGSKI15 is offline   Reply With Quote
Old 08-14-2013, 05:54 PM   #6370
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
I built mine with the beefier cups in the front, the normal looking cups on the steering rack and the beefier/angled on the back with the angled one at the hub carrier. This is what worked well for me.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-14-2013, 07:00 PM   #6371
Jmuck69's Avatar
Trader Rating: 14 (100%+)
How many axle shims are you using behind the nut that locks the axle in the steering block? I use one so the axle has a little play but if you use two or more it might be putting too much strain on the bearings and causing the clicking.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 08-15-2013, 02:20 AM   #6372
D.Martijn's Avatar
I tried one but it was still there...
Old 08-15-2013, 06:06 AM   #6373
Hi,
I'm new to 2wd buggy and need suggestion for tires, I'm running on the track with very thick dust.
Thanks!
Wilson Picaldy is offline   Reply With Quote
Old 08-15-2013, 06:45 AM   #6374
PW
PW's Avatar
I've never seen this before and not sure what it could be. Did you order the axles direct or through a distributor? Maybe we can get you a replacement depending where you got them.
Can we get a little more info about the track? Is it hard packed with dust on top or soft/thick surface? I always start with 3D's when the surface is multi-layered.
Paul Wynn
Old 08-15-2013, 06:58 AM   #6375
Venom1836's Avatar
At Bashers RC Racway we usually run Green Barcodes front and rear (V1)... (2wd/4wd buggy)
Is there another setup that offers similar traction but last a little longer? I am getting tired of replacing tires every few visits to the track.
Thanks!
-Venom
You canít fix stupid
Venom1836 is offline   Reply With Quote
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 12:04 PM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 09:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 10:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 04:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 07:54 PM
