JConcepts Thread
#6196
JC Ball cups
Is anyone selling the new JC ball cups?
Qestion, what are the advatages of the new JC Titanium axles over the standard JC axles? Are the standard ones known for breaking or is it a weight thing?
Thanks!
Thanks!
#6197
Going through production and packaging; hopefully soon.
Yes; this wheel is actually the correct size that was the industry standard many years ago, but over time all the manufactures have made their wheels much bigger for better performance. The tire size never changed because the larger wheels with the standard tire size gives a much tighter fit and stiffer sidewall. If you want the "current" industry standard size then it's part #3302.
Not at the moment.
Not available yet; not sure of the ETA right now.
Mainly just a weight thing, but also a "bling" thing as well .
Don't think the Ball-Cups have shipped to dealers yet.
Hi, question!
Just bought a set of 1/8 buggy wheels, part number 3303, and they are small!
Smaller than the rest of my wheels, and too small to properly fit my proline tires
Please help! Thanks!
any bodies in the works for the mbx6 eco or mbx7 eco
I was looking to order a Titan in the lighter thickness for stock racing. On the JC website it prompts you to pick a thickness, but there is only the HD option available. Is that just a web mistake or are the "lighter" versions not avail. atm?
#6198
Is there a conversion or a way to make the new Rips tires and Hazard wheels fit a Losi XXX-SCB?
#6199
I can't really confirm all this, but it should be possible.
#6201
sounds weird. maybe it's a "different" type stand and doesn't use holes.
post a link to it and that mighty help sort things out.
#6202
I believe you make the holes so the shocks you have fit. I'm sure they do that, no holes, because of the many different sizes of shocks out there right now.
Blake
Blake
#6203
http://www.amainhobbies.com/product_...nd-Matte-Black
I guess looking at it in the picture it doesn't have the holes either.. I guess I should have paid more attention
#6204
Yes you need to put your own holes in. They could have made holes for you but then there would have been the need for and 1/8 scale specific, a 1/10 scale specific and a 1/10 with big bores specific shock stand. All you need is to use a reamer and open up the holes to the proper size for your application.
#6205
R/C Tech Elite Member
#6207
#6208
#6209
#6210
On the b4.1 dose anyone have trouble keeping the camber set were you put it.it keeps changing on me even when I drop it on the pit table to check ride hight. I have not even run the buggy yet and the camber changes. Why is that? is the b4 that bad of quality from ae.
