Like Tree29Likes
Old 02-17-2013, 02:50 PM   #5911
jmc5313's Avatar
Default F250 Krackn
I'm really dissatisfied with my F250 body.....Ive ran JConcepts for awhile and this thing is ridiculous....it cracked along the upper body seam all the way down the truck in less than two races....my illusion chevy 1500 lasted almost an entire season with me behind the sticks at the same tracks!!! Holding each one in my hand it is easy to tell the weight difference between the two...i know that u want as little high mounted weight as possible.....but a body that will not last is not something im interested in...I'm going to consider my F250 a waste of time and money....good thing there are alot of other body choices available.
AE SC10.2 -REEDY SONIC MACH 2 17.5 LRP FLOW
TLR 22 SCT LRP X20 7.5 LRP SXX TC
Kyosho RB6 LRP X12 8.5 LRP SXX TC
TLR SCTE 2.0 REEDY SONIC 550 4.0 LRP FLOW
3MTA3
jmc5313 is offline   Reply With Quote
Old 02-17-2013, 03:19 PM   #5912
rider313's Avatar
Trader Rating: 94 (100%+)
Did you happen to have a change in paint colors there were the body was scored?
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Old 02-17-2013, 04:56 PM   #5913
Trader Rating: 41 (100%+)
Lexan thickness differs from time to time just the way it is. I noticed it on the high downforce wings. Call them jconcepts will make it right.
2SlowTC is offline   Reply With Quote
Old 02-17-2013, 05:33 PM   #5914
jmc5313's Avatar
Default I'm stupid.....
Yha it was.....and yha that's where it seperated....did it myself and made myself look dumb on a forum where i try not to look stupid...in the words of Homer Doooooh!!!
3MTA3
Old 02-17-2013, 06:25 PM   #5915
rider313's Avatar
We have a done it before. Just remember a gentle touch on your next one.
Dan Williams
MNRC Chairman
Old 02-17-2013, 06:40 PM   #5916
biggles97's Avatar
Hi Paul,
The orange 3Ds for 2wd buggy work really well on the hot dusty outdoor tracks here in Australia.
I'm hoping JC will release orange 3Ds for stadium truck too. Green DDs work great but the wear rate is too high (one or two packs at most). Orange Bar Codes don't work as well when it's dusty.
Cheers!
B5, T4.1, B44.2
Speed Passion, Savox, Spektrum, Turnigy
biggles97 is offline   Reply With Quote
Old 02-17-2013, 07:41 PM   #5917
asc6000's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Tradin Paint View Post
That sounds like more of an insert issue. Are you running open cell inserts, have they gotten wet?
Using the supplied foams brand new, you should see my tire fitting area, since we don't need 8-10 batteries per car per class anymore I go overboard in the tire thing. Even fitting JC closed cells leaves a gap between the tire and the foam and the tire just squirms all over the place. Fill it with a fat open cell and the sidewall just rolls over. I like the rubber and the tread just wish it was a beefier carcass.
Good news on the XB4 body, holding my breath though as I am not a fan of most of the squared off cab forward thing.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 02-18-2013, 01:19 AM   #5918
Tradin Paint's Avatar
Default Turnbuckles
When can we expect the new turnbuckles in stock on the website?
Happy with: Team Associated, Team Tekin, Airtronics, Avid, JConcepts, Fantom motors and Aero Model batteries.
Proud Supporter of Warehouse 3 RC Hobby Shop, that just happens to have an indoor track
"Because Size Does Matter"
Ryan H.
Tradin Paint is offline   Reply With Quote
Old 02-18-2013, 01:23 AM   #5919
Suspended
Trader Rating: 440 (99%+)
Jconcepts: Are you planning on releasing any 17mm hex SCT (SCTE OFFSET) wheels for use on the Tekno SCT410 truck anytime soon? I know the DE Racing wheels are good but I prefer a little variety when it comes to wheels.
MattP is offline   Reply With Quote
Old 02-18-2013, 04:55 AM   #5920
rider313's Avatar
PW said earlier this month there was currently no plans for the 17mm SCT wheel. However he said the requests were noted.
Dan Williams
MNRC Chairman
Old 02-18-2013, 06:05 AM   #5921
PW
PW's Avatar
Send a message via AIM to PW
Originally Posted by dgdcustoms View Post
Will we ever see regular bodies again? Or are the cab forwards all we have to look forward too? I'm not a big fan of these bodies and they look way weird to me...
It's possible; things always seem to come and go full circle, but unfortunately you are in the minority right now and it won't be any time soon .
jmc5313....I was shocked to see your initial post about the F250. That has been hands down our most durable SCT body and we actually have quite a few indoor tracks that use the F250 body for their rental trucks because of it. I'm happy to see you found the remedy .
Hi Paul,
Cheers!
The 3D's for truck are on the list for sure, but I really have no idea on the time frame and can't promise them in Orange compound.
Sounds kinda bizarre what you are describing. The DD has been one of the most successful tires we have ever produced and I've never seen an issue with foam fitment. We normally run that tire in med/low bite conditions with great results, but we have run them on high-bite dusty conditions with equally great results.
We are waiting on the new ball-cups to arrive as they will be packaged as a set . No official ETA as of right now, but hopefully soon.
Input noted.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 02-18-2013, 06:13 AM   #5922
Suspended
Ok thanks. I hope you get enough requests to make some. DE kinda has the market cornered on 17mm sct wheels right now.....
Old 02-18-2013, 06:42 AM   #5923
Jmuck69's Avatar
What version ballcups did JC settle on? You ran one version at the Clash and Jason was running another version.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 02-18-2013, 09:25 AM   #5924
PW
PW's Avatar
Both...
Paul Wynn
Old 02-19-2013, 07:20 AM   #5925
Will there be dish inserts available for the Slash Hazard wheels?
Would like to thank my sponsor "Walmart".
JasonLee is offline   Reply With Quote
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
