Like Tree28Likes
Old 07-14-2007, 11:28 PM   #571
AndyMoore's Avatar
Trader Rating: 53 (100%+)
Send a message via AIM to AndyMoore
Originally Posted by chris c View Post
Anyone else having problems keeping the rear dif from not striping? BJ4WE
2 yesterday and yes i have the shims in it. They(shims) are putting pressure on the gears.
I STILL LOVE THIS CAR!!!
If you cant get the shimming quite right, pm me.
AndyMoore is offline   Reply With Quote
Old 07-14-2007, 11:34 PM   #572
AndyMoore's Avatar
So here are a few of the things we've been working on.
Products in focus Available September 2007
3007 - Double Dee's 1/8th buggy tire
3010 - Cross Hairs 1/8th buggy tire
3303 Rulux - 1/8th buggy wheels (white)
3303Y- Rulux - 1/8th buggy wheels (yellow)
Old 07-14-2007, 11:35 PM   #573
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Although 2 shims is standard, every part is sometimes a little different. Make sure to check the "Mesh" just like you would for the spur/pinion. I usually tighten it up until there is no play in the mesh, the move the diff back over 1 shim (take out of the left, add to the right (gear side).
Also, if you are stipping gears, make sure to replace both. Chances are, if one stripped, the other is damaged.
Think of it this way... something has to give when you land on throttle. It should give on the slipper first, then diff 2nd option, gears, the last and worst of all. If you are stripping gears, chances are your slipper should be loosened a touch, and you diff might be a little on the tight side as well.
Frank
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 07-14-2007, 11:55 PM   #574
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
Very cool tires, any plans for 10th scale ones?
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 07-15-2007, 04:41 AM   #575
Scrubb's Avatar
I used to have problems stripping rear diff gears (about 8 or so sets). One of the problems I had was the transmission case screw holes were a bit worn out and stripped, so the cases were not staying together correctly and letting the gears get out of alignment. So I replaced the cases and used slightly longer screws to hold the case together. I also shimmed the gears so that there was a bit of binding and let the gears wear in a bit. Lube the gears a bit with stealth diff grease and make sure you keep the gears and lube on them clean. Any dirt stuck (or worn gear material) in the teeth will push the gear mesh away from each other and start stripping. Make sure when you shim the gears, that there is no excess play. I would imagine that under load the diff ring gear could flex and deflect slightly enough to allow the gears to strip, so keep the tolerances very tight.
My shim setup is not far off from the instructions, One outdrive shim on each side of the diff, with one shim behind the drive pinion and two shims after the center drive shaft.
Scrubb is offline   Reply With Quote
Old 07-15-2007, 09:54 AM   #576
mfishel's Avatar
Originally Posted by tripthreat View Post
Although 2 shims is standard, every part is sometimes a little different. Make sure to check the "Mess" just like you would for the spur/pinion. I usually tighten it up until there is no play in the mess, the move the diff back over 1 shim (take out of the left, add to the right (gear side).
Frank
Sorry but I believe that 'mess' is what you get if your 'mesh' isn't right. Seriously though I'm glad that the thread went this way as I'm needing to redo my diffs and have never done this type before. So keep the tips and advice coming.
mfishel is offline   Reply With Quote
Old 07-15-2007, 09:59 AM   #577
TLRacing
Frank Root's Avatar
Haha, yeah I was 1/2 asleep writing that..
Old 07-15-2007, 02:37 PM   #578
chris c's Avatar
Trader Rating: 60 (100%+)
thanks guys....
i will replace the cases and new shims plus as frank says loosen the slipper a bit.
Again thanks for the help guys......
chris c is offline   Reply With Quote
Old 07-15-2007, 05:25 PM   #579
Brad S.'s Avatar
Trader Rating: 39 (100%+)
Brad,
If you havent sent one in yet, dont, haha. The tire deal coming in during the middle of the year has added a large workload to the "team" thing. We have to look at everyone again on a case by case basis, so we're swamped with that. I would wait a little while until the tires thing settles, and then reapply.
If youve sent us an email and havent recieved a response, then Im not sure what to tell ya other than try again before the summer is out. I dont handle that stuff...or emails for that matter so Im a little disconnected.
Just a tip, make sure that it is NOT a form letter, as those get deleted/shredded. Also include some information about yourself and your racing background, and then on a seperate page, break down your results. Hopefully youre a loyal customer, as that always helps.
Good Luck,
Andy
Thanks for the info Andy. I sent it in about 2 months ago! I'll wait till the tires come out. They look awesome. can't wait to have em!
Thanks again,
Brad
~Brad Shearer~
Team Associated ~ Motiv ~ JConcepts ~ Team Gravity RC ~ MIP ~ 92zerodesigns.com ~ Shearer-It Paint Designs ~ LiveTime Scoring ~ LiveRC.com
Brad S. is offline   Reply With Quote
Old 07-15-2007, 08:18 PM   #580
Davidka's Avatar
Trader Rating: 75 (100%+)
Which tires are those in the photo, the Double Dees or the Cross hairs?
Old 07-15-2007, 08:40 PM   #581
AndyMoore's Avatar
Those are the Cross Hairs.
Double Dees:
Old 07-16-2007, 10:51 AM   #582
b-man777's Avatar
Default jconcept tyres
hey all:Would like to know what the specs on the new jconcept tyres are and wether or not they are made by pro-line or are jconcepts owne design and manufacturing?Finally what scales and vehicles types will the new jconcept tyres be avalible for?Thanks for the info
b-man777 is offline   Reply With Quote
Old 07-16-2007, 03:56 PM   #583
AndyMoore's Avatar
Pr*line should be bleeped out in this thread, haha. The tires are DEFINATELY NOT made by Pr*line. We will have tires for 1/10th truck, buggy, and 1/8 buggy as of right now.
Old 07-16-2007, 10:12 PM   #584
RCBLUE's Avatar
Just no 4 wheel fronts from a company that created the best 4 wheel ever. Oh the irony (meant to be a joke just in case you were wondering).
Don't sweat the petty things...........Pet the sweaty things!!
Serpent America
Lunsford Racing
RCBLUE is offline   Reply With Quote
Old 07-17-2007, 03:28 AM   #585
nhodd's Avatar
Send a message via Yahoo to nhodd
Default tyres
looking forward to trying some soon
nhodd is offline   Reply With Quote
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
