JConcepts Thread
#5776
Yes, the Hi FLow body fits. I use it on my SCR. The wheels wells are a little off and none of the body mount dimple holes fit. If possible, make the body post holes before you paint it. Just have to take you time to make the body mount holes. I mounted mine so the front bumper fits inside the body.
#5778
The RB6 and Centro are around the same; around 112+mm wide. None of our bodies will be snug if you're at 90mm.
#5780
All of our SCT bodies are made from .050 material. Sometimes the tolerances can vary slightly and you may get a slightly thinner one, but only like .005 difference. A .030 SCT body would be paper thin on the sides and that's no exaggeration .
#5781
JC's new high flows are some of the lightest SCT bodies on the market today.
#5782
The bead on the truck bar codes is dumb. The top of the side of the bead is not flat where it rests against the outside edge of the wheel--looks like the bead is an "I" beam. I glue all my 1/10 scale tires on the side of the bead, not the bottom of the bead, making it very easy to slice open the bead at a 45 degree angle for re-foaming. The missing material also allows for the tire to be pressed down into the bead misaligned at the top as well as providing less ability to keep the tire sealed against the rim at the side, lending to collecting dirt between the tire and wheel even when the tire is still glued well further down the bead.
Definitely do not care for gluing these tires up or this carcas design.
#5783
Paul, I sent an email yesterday to [email protected] concerning b4.1 axles I bought and had a small issue with. Is this the correct email address? Thank you!
#5784
#5787
Paul do you have the part # for the SC swaybar kit ?
#5788
IOW, just boiling away doesn't seem to completely break the tire from the rim, it needs a little assistance. Just don't use anything sharp or else you'll cut the tire.
#5789
What is the best choice for the mOst steering groovy rounder or rip?
#5790
Unfortunately I've never tried it; so maybe someone can chime in here.
I believe it's going to be 2166, but they are still delayed.
Depends on the surface; rounders have the most on clean, grooved surfaces. We use Rips 99% of the time when a ribbed tire is called for.
