Like Tree33Likes
Old 01-06-2013, 12:37 PM   #5746
Autocratic's Avatar
Trader Rating: 26 (100%+)
Paul, are Bar Codes the top tire in steering, or will a ribbed tire give better performance in some cases? Example, at Mike's the track is getting more bumpy and I've started to grab ruts. Car setup with Green Bar Codes (full rear foam) is very consistent and fast, and I don't want to loose the steering the car has now, but I was thinking of running a ribbed front to help the situation. Is there a ribbed tire that has about the same steering as the Bar Code?
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
Old 01-06-2013, 12:51 PM   #5747
Grandturk's Avatar
Originally Posted by mxracer458 View Post
Gold,I don't mind if they get alittle softer since I sauce them up just can't get hard and brittal
You can try to bake them off - 350 degrees in the oven. But don't use acetone as it typically shrinks and hardens clay compound tires.
Your Product Name Here
Grandturk is offline   Reply With Quote
Old 01-06-2013, 02:23 PM   #5748
mxracer458's Avatar
Trader Rating: 47 (100%+)
Does the heat do anything to the compounds?
mxracer458 is offline   Reply With Quote
Old 01-06-2013, 02:46 PM   #5749
Grandturk's Avatar
Some say yes some say no. I would probably just cut the tire open to reuse the closed cell foam - if applicable - and write it off. Not worth the time ad effort for a $10 set of tires
Old 01-06-2013, 03:42 PM   #5750
fq06's Avatar
I boil for about 20 or so minutes. Leaves the rim mostly clean and then use Satellite City debonder (solvent) to get the CA off the tires.
Comes out perfect.
BCE SCT410 / Hobbywing 3656sd ~ RX8.2
DEX210 / Trinity 17.5 ~ RS.2
Westcoast Raceway (R.I.P.) | SMC | PowerLab
fq06 is offline   Reply With Quote
Old 01-06-2013, 05:40 PM   #5751
Autocratic's Avatar
When are we going to see Pressure Points for 1/10 buggy?
Old 01-06-2013, 07:08 PM   #5752
Super Moderator
Trader Rating: 17 (100%+)
I've seen them and they are pretty cool
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 01-06-2013, 07:27 PM   #5753
mxracer458's Avatar
It's for a sc truck so 20$ a pair
Old 01-06-2013, 07:32 PM   #5754
Trader Rating: 22 (96%+)
yes they are
dezertranger96 is offline   Reply With Quote
Old 01-07-2013, 01:27 PM   #5755
PW
PW's Avatar
Send a message via AIM to PW
There are cases where ribs are very close or equal in steering, but not often. I do remember Jason Ruona and Brent Thielke really liked green Rips last year at Mike's (JConcepts Indoor Nats) because they made the car easier to drive without giving up much steering. They were using 3/4 rear white foam (inserts) in the Rips.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 01-07-2013, 10:38 PM   #5756
Odin544's Avatar
Trader Rating: 93 (100%+)
Any plans of a new body for the Xray XB4?
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 01-08-2013, 06:51 AM   #5757
PW
PW's Avatar
Yes
Paul Wynn
Old 01-08-2013, 10:27 AM   #5758
Jeff Werner's Avatar
Trader Rating: 14 (100%+)
Send a message via Yahoo to Jeff Werner
Any updates on the front sway bar for the SC10? Our track is one where they would really be helpful. Seen them listed on the insert of the JC body I just put on my SC10. Any update would be great.
Thanks-
Jeff Werner is offline   Reply With Quote
Old 01-08-2013, 10:37 AM   #5759
PW
PW's Avatar
Thanks-
There's been a delay with production on 1 part; hopefully soon
Paul Wynn
Old 01-08-2013, 12:11 PM   #5760
Outtacontrol58's Avatar
Trader Rating: 91 (98%+)
Send a message via AIM to Outtacontrol58
Is there an EB48 body in the works? Tekno says they sent a buggy to you guys but didn't have any info after. Thanks for the good products and any info would be great!
Outtacontrol58 is offline   Reply With Quote
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
