Like Tree29Likes
Old 04-09-2012, 12:57 PM   #4936
Impossible question to answer, but I need to ask...
What would be an all around decent tire that will give me longest wear on a slash 4x4? I can't do a new set of tires every other race and I also have two kids with SC trucks to take care of. Since we are all learning we will be getting as much practice as we can.
there are two tracks in my area. One is an indoor clay track (red and really nice) and the other is an outdoor dirt track that seems very packed down and has rocks and pebbles as part of the mix. The clay track is about an hour from me, vs 20 minutes or I would just go there all the time. (plus it's $10 practice and only open 3 days a week.)
MikeInCtown is offline   Reply With Quote
Old 04-09-2012, 01:02 PM   #4937
PW
PW's Avatar
Send a message via AIM to PW
Originally Posted by rc10t3b4 View Post
I run a Rc10T4 since it's release and been a proline fan. But after building this T4.1Ft I'm switching to Jconcept. I love the fit and finish of the tires(didn't even need to balance them) and the bodies is very strong. I hope you guys start pushing the stadium truck market even harder.
Thank you and yes
Any slick tires for 1/10 electric in the pipeline??
Not at this time.
Subcultures
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 04-09-2012, 02:20 PM   #4938
Outtacontrol58's Avatar
Trader Rating: 91 (98%+)
Send a message via AIM to Outtacontrol58
Is the rulux hex wheels for the sc10 and rulux hex wheels for the scte 4x4 the same offset? I was just wondering because I might use the same for each vehicle. Thanks and any info is appreciated!
Outtacontrol58 is offline   Reply With Quote
Old 04-10-2012, 12:04 AM   #4939
Hey guys. I got the Associated 8in1 hex driver set and figured to show my support for jconcept go with their standard nut driver http://www.jconcepts.net/store/index...roducts_id=196
but everywhere it's out of stock. Has this set been discontinued? I hope not.
HPI-Racing|Team Traxxas|Team Tekin|Spektrum|Jr Racing|Jconcepts|Thunder Power|SPC-Racing
Blitz ESE|Traxxas SRT|Traxxas TCP|Rs Pro 7.5t|DX3C|Z9100s|TP-610C|
World Class Champion's runs World Class Equipment...Go Tekin or go home!
rc10t3b4 is offline   Reply With Quote
Old 04-10-2012, 05:30 AM   #4940
PW
PW's Avatar
They are really close; I think they are about 1mm difference. The issue is the inner support ribbing on the sc10 & scte 4x4 wheels are different. The sc10 wheel won't fit the scte unless you remove some of the ribbing to clear the front arms.
Hazard wheels are almost ready for the SCT-E....stay tuned
Unfortunately they have been discontinued.
Paul Wynn
Old 04-11-2012, 01:12 AM   #4941
CraigMBA's Avatar
Trader Rating: 22 (100%+)
What is up with all the temporarily unavailable SC tires in clay compounds?
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 04-11-2012, 02:23 AM   #4942
elex300's Avatar
Trader Rating: 102 (100%+)
Paul, What solution do you recomend for tire cleaning and prep while racing. I've tried SG but have since read it will dry out the tires. Is WD40 ok since it's not a degreaser? I run 3 to 4 different tread patterns on each of my vehicles so they only last maybe 8 to 10 weekends. Is that long enough to see the bad affects of SG?
Erik Everett
EZ Customs (Rc Painting) www.facebook.com/ezcustomspainting
Jconcepts - Trinity/Revtech - Xtreme Hobbies - RCADDICTION Products
elex300 is offline   Reply With Quote
Old 04-11-2012, 04:56 AM   #4943
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
Someone correct me if I'm wrong but I believe wd40 softens the tire more drastically than simple green? I wouldn't use it.
Dylan Gerard
Serpent - Desoto Racing - Picco - AKA - Hitec - RC Addictions Products - Tekin - VRP - Avid RC - SMC - MIP - SkipGear - The Ohio RC Factory
Quad Racer 34 is offline   Reply With Quote
Old 04-11-2012, 05:46 AM   #4944
PW
PW's Avatar
I think the only gold SC tire we are sold out of is Bar Codes and they are in transit. Pressure Points and DD's in gold are in stock.
Simple Green works fine and I never heard about it drying out the tires. WD40 works great on tires if you are trying to soften the rubber or revitalize older tires.
Paul Wynn
Old 04-11-2012, 07:40 AM   #4945
CraigMBA's Avatar
Thanks for the quick answer. I do most of my business with Tower and Stormer, and both of them had "on order" or "temporarily unavailable" on a ton of stuff, but in particular, bar codes in blue or gold. We have a brand new indoor track (the only one between Orange County and Sacramento) and I have no idea what to run for compounds.
Old 04-11-2012, 08:36 AM   #4946
B00t13g's Avatar
I picked up two sets of hybrids yesterday for my 2wd buggy, they look great, but they did not take glue as well as aka or proline tires.
B00t13g is offline   Reply With Quote
Old 04-11-2012, 08:54 AM   #4947
PW
PW's Avatar
Strange...I haven't had or heard of any issues. They are the same "green" super soft compound used for all of our tires. What did you use to clean/prep the tires before gluing and what type of glue?
Paul Wynn
Old 04-11-2012, 09:03 AM   #4948
B00t13g's Avatar
I cleaned/ prepped the same way I always have. Motor spray on the included foams, cut off the extra molding parts let them dry used your tire bands and then glued them using the thin ca glue you get at your lhs in the clear bottle with a blue label. The glue just seemed to run off of the bead and get next to no tackiness. It happened on both pairs. After the first tire I re- cleaned the other three with no change.
Old 04-11-2012, 09:05 AM   #4949
B00t13g's Avatar
Also this was the first time I've ever used your tires. I glued some rebar fronts at the same time with no issues. Idk
Old 04-11-2012, 10:36 AM   #4950
PW
PW's Avatar
Not sure what is happening there.
I always use med JC glue without any issues, maybe the thin glue didn't soak in well on the new tires. I actually mounted a set of Hybrids trackside last week just before my run with med JC glue and it was perfect.
Paul Wynn
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
