JConcepts Thread
#4682
Maybe you received the wrong wing, miss packaged? We make a direct fit Kyosho wing #0116 and it has a wider mounting base strictly for the Kyosho. I made the mold for the wing, so I can assure you I have mounted a few wings onto the Kyosho car . I've never had to bend the mounts to make the wing fit the marked holes on our wing.
Here is a pic of the #0116 wing I mounted last week onto the new RB5 WC kit to confirm fitment on the newest kit. We have also just finished a new Hi-Clearance wing #0125 for the RB5 series cars that uses the same wing mounting locations.
Next are there any plans for Kyosho truck bodies now that the 22t might spark an interest in 2wd truck? I would be interested in a cab forward design rather than the illusion style ones. Also another question will the 22t body fit the rt5?
#4683
I was sold a set of JC Rulux wheels 3330B for my SC10RS. The hex fits fine, but the offset looks a lot wider than stock. Are these ROAR legal on this truck?
#4684
The 3330B wheels are for the HPI Blitz and would be considered to wide for ROAR races. You need either the 3332B or 3344B for the SC10RS.
#4686
#4687
http://www.vijaytransformers.com
The 'VIJAY TRAFO" make transformers are being manufactured at an unit which is well equipped with latest Technology and is supported by competent & experienced engineers and as per International Standards as well as Indian Standards i.e. as per IEC :76 and IS : 2026. These transformers are non inflammable & moisture proof. The manufacturing process is divided into 5 stages:
Stage 1: Raw material arrangement - M.S. Sheet, Copper or Aluminum Wires, Oil, Lamination etc, and inspection of in-coming material as per our Quality Parameters.
#4688
Vijay. Thank you for your interest in JConcpets products.
#4689
When will the new Chevrolet sct body be available? And when are you going to start making your tires in the USA instead of china....and I know they are designed here..
#4690
The Chevy SCT body is available, and should be in stores. Part number 0200.
#4692
Proline Chevy body kit with JConcepts Barcodes (Super Soft). Straight black for my first expedition into painting a body. The front rubs a lot up by the corners and had to be trimmed quite a bit. Without any trimming it would have ripped the tires up in no time. Also, the back needs to be trimmed if you want to run it lower, more like the stock body kit.
#4693
#4694
