Like Tree28Likes
Old 12-15-2011, 06:32 PM   #4546
Trader Rating: 520 (100%+)
Originally Posted by TWRC View Post
For those cut DDs, would you just take one of the rear tires, cut out the double lug section out of the center and then glue the 2 halves back together with CA?
Yeah, I have made quite a few sets just like the ones in the pic. I either use the 2wd rears, or 4wd fronts and match them to a current pair with the correct width, cut and CA back together. Go slow, and dont use a lot of glue, basically just get the cut wet..
flame56mx is offline   Reply With Quote
Old 12-16-2011, 07:25 AM   #4547
PW
PW's Avatar
Send a message via AIM to PW
Originally Posted by rcman182006 View Post
Any plans on Mono wheels for the DEX210/410?
Not at the moment.
I did however mount our B4.1 alloy hex on the rear and put our new hex wheel on . Unfortunately couldn't do anything for the front .
We only use a rear tire so that you have the proper carcass once glued back together. I count 4 lugs from each side and then cut; this gives you a total of 8 lugs across once glued back together.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 12-21-2011, 06:17 AM   #4548
PW
PW's Avatar
NEW PRODUCT
JConcepts New Release – Pit Mat
JConcepts – 48” x 24”
Part # – 2133
UPC Code – 845937006295
JConcepts is quickly becoming the pit boss with the release of a pit mat with brand authenticity. Making your pit area clean and professional looking has never been easier with the textured, soft and durable design from the detailed oriented crew at JConcepts. Quickly roll or unroll to set-up or tear-down the pit area, the JConcepts pit mat is versatile enough for the racer always on the go.
Features:
· JConcepts branded in opposing direction
· Textured, padded material, soft and durable
· Black color for stain resistance
· Roll-able design for easy transportation
JConcepts New Release – 2.8″ G-Locs Tire
2.8″ On-Road Performance from JConcepts. There is a new 2.8” tire on the block and all-out speed rests in its DNA.
In Aeronautics, G-Loc is the moment where consciousness is lost. The G-Locs 2.8” tire, by JConcepts is where consciousness begins. The super low-profile, aggressively treaded tire is purpose built for those aggressive speed-runs and specifically for vehicles capable of high-voltage or high-horsepower fun. G-Locs are competition inspired from the ground up to perform straight out of the package. Deep G-Loc tread-depth and style provides the healthy footing for maximum durability and ground pounding asphalt traction. Thick, reinforced tire carcass, with internal overlapping X-braced ribbing provides unparalleled support, reducing unwanted tire expansion, for gained high-speed control. G-Locs, are manufactured using the exclusive ROAR National Championship winning yellow compound for the best gripping performance.
The 2.8″ G-Locs provide elements that combine light-weight, performance and durability with the inclusion of Profiled closed cell inserts. The highly successful insert material made it’s fame on the 1/8th off-road racing circuit and now into the JConcepts 2.8″ line. Feel at ease while doing high-speed runs with the durability and performance of the closed cell material which provides durability and feel when others run short.
The low-profile diameter tire body profile with hefty G-Locs tread, together with the durable Profiled closed cell inserts has revolutionized speed tires for the most popular assortment of vehicles on the market. Your 2.8” equipped vehicle has never been more fun than when paired with a 3s Lipo or buzzing nitro engine and G-Loc tires. Wheelie popping speed combined with G-Locs traction and stability is a combination that is second to none. JConcepts is World Proven Innovation and Design.
Features:
· Super low-profile
· Deep G-Loc tread-depth and style
· Thick, reinforced tire carcass
· Overlapping X-braced ribbing
· Exclusive, winning, yellow compound
· Thin-wall, Profiled closed cell inserts
Product Vid Click Here
G-Locs – yellow compound – tire / insert (fits 2.8″ wheel)
Part # – 3056-00
UPC Code – 845937005854
(fits Traxxas style 2.8″ bead wheel)
2.8″ G-Locs – yellow compound – black wheel – (pre-mounted)
Part # – 3056-3030
UPC Code – 845937006738
(fits Stampede 4×4 F&R and E-Stampede and E-Rustler 2wd front)
Part # – 3056-3040
UPC Code – 845937006745
(fits E-Stampede and E-Rustler 2wd rear)
Revo®, JATO™, T-MAXX™, SLASH®, SLASH 4X4® etc. are trademarks and registered trademarks of Traxxas L.P.
Paul Wynn
Old 12-21-2011, 06:20 AM   #4549
PW
PW's Avatar
JConcepts New Releases – Pressure Points SCT Tire
JConcepts, a leader in Short Course performance with accredited victories around the world, including back-to-back ROAR National Championships, has added another piece to its successful racing arsenal. The Pressure Points are the latest low-height tread option specifically designed to tame high-speed courses with either wet or blue groove traction conditions. The design starts as an angular, low pin design as a carryover from the successful Bar Codes front tire line-up. The small “points” combined with “lower case” Y elements developed on the original Bar Codes V1 rear tire provide the ultimate in surface area “pressure” penetration and tack.
The inner side-wall has built-in ribbing which limits carcass collapse and increases support on the outside during hard cornering and driving. The new inner ribbing, combined with the included JConcepts Profiled closed cell insert, is a perfect match to provide the ultimate in support, traction and consistency.
In the movies, it’s been said that loose is fast and on the edge of out of control. In our world, loose is slow and off the pace. The Pressure Points are designed to be driven hard while maintaining the grip necessary to drive at the limit. The edges of the side-walls have been carefully rolled for a smooth transition during corning which limits traction-roll characteristics and allows the driver control during the all important tipping point every driver has experienced.
Just like all JConcepts tires, the Pressure Points are a proven winner. JConcepts driver Ryan Maifield won the 2011 Reedy Truck Race of Champions in the 4×4 class utilizing the Pressure Points in green compound.
Go for the vitals with JConcepts, attack with Pressure Points.
Features:
· Available in Soft (Blue), Super Soft (Green) Indoor Soft (Gold) and Outdoor hot (Orange) compounds
· Low-height tread, specifically designed to tame high-speed courses
· Inner side-wall ribbing, limits carcass collapse and increases support
· Includes light-weight and durable Closed Cell “Profiled” inserts
Pressure Points – blue compound
Part # – 3049-01
UPC Code – 845937006578
(fits SCT 3.0″ x 2.2″ wheel)
Pressure Points – green compound
Part # – 3049-02
UPC Code – 845937006219
Pressure Points – orange compound
Part # – 3049-04
UPC Code – 845937006226
Pressure Points – gold compound
Part # – 3049-05
UPC Code – 845937006233
Product Vid - Click Here
JConcepts New Releases – Hazard SCT (white) Wheel
JConcepts Hazard wheel is the 2011 ROAR National Champion.
Short Course trucks have evolved into high-performance racing vehicles and adjustability is always the key to success. Introducing the Hazard 12mm hex wheel for the SC10 4×4 and SC10 by JConcepts. A powerful new look that combines the winning combination of a 10 spoke design, bead-lock appearance and center lug nut detail with a hint of inspiration from yesteryear. The Hazard will make an immediate impact on the performance of the SC10 trucks by widening the stance of the truck by 6mm in overall width. The increased width will maximize the SC10 and bring it up to the ROAR maximum legal limits in dimensional width.
Already a champion, the Hazard wheel earned the top qualifying position and 1st place at the 2011 ROAR Off-Road Nationals in the Pro 2 modified class in the hands of Ryan Maifield. A dominating performance taking the TQ in the first 3 rounds of qualifying and 1st place in A-main #1 and 2 to take retain the title for JConcepts.
By nature, Short Course trucks have a high center of gravity and tend to feel light or tippy in high-speed sections. There is no better way to improve on-track stability than to add width, and with the Hazard wheels, sweeping through the high-speed corners gets a little easier. Wheel profile, interior and exterior ribbing and spoke design were all areas of focus while creating the combination of durability, clearance, functionality and appearance. With the black color and a matte face appearance, being unique is worry free as practically any paint scheme can be matched to these exciting new wheels. The hassle-free and lightweight 1-piece design creates the ultimate race and show wheel for any competition.
To use the 12mm hex wheel on the SC10 it requires JConcepts part # 2081 for the rear and the Team Associated inboard hub hex conversion for front.
Features:
· Original 1:1 inspired JConcepts Hazard 12mm hex design
· 3mm per side additional width in offset
· Direct bolt-on fit for the SC10 4×4
· Bolt-on fit for the SC10 with 12mm hex adaptors
· Durable design, finish and material
· White in color with matte face appearance
· Hassle free and lightweight 1-piece design
· Devastatingly handsome
Fits:
· SC10 F&R with conversion adaptors
· SC10 4×4 front and rear
· Traxxas Slash 2wd F&R with wide-track suspension kits
Hazard – SC10 / SC10 4×4 – 3mm wider off-set – 12mm hex wheel – 2pc. (White)
Part # – 3344
UPC Code – 845937006615
(fits SC10 4×4 direct and SC10 with 12mm hex adaptors)
Paul Wynn
Old 12-21-2011, 06:55 AM   #4550
murky123's Avatar
those Pressure Points SCT Tire looks almost identical as the AKA wisbone SC
AE SC10 4x4, Durango DEX210 + DESC210R, HB D413
www.rcracing.nl www.mvb.nl
murky123 is offline   Reply With Quote
Old 12-21-2011, 07:05 AM   #4551
cant wait to try those tires out. and those white hazards look trick!!
Team-Powers/Dischargerc.com
derbrylac is offline   Reply With Quote
Old 12-21-2011, 07:25 AM   #4552
Trader Rating: 16 (100%+)
Send a message via Yahoo to Zach Phillips
Will Jconcepts be releasing the setup board pictured in some of the promotional pictures anytime soon?
KYOSHO | JCONCEPTS | ORION | SMACTRAC |
Zach Phillips is offline   Reply With Quote
Old 12-21-2011, 07:52 AM   #4553
PW
PW's Avatar
Yes; they are in the production line now and should start shipping early January .
Paul Wynn
Old 12-21-2011, 09:41 AM   #4554
Moderator
Muggydude's Avatar
Trader Rating: 89 (100%+)
How do you think the pressure points in gold will compare to the gold bar codes for hi bite indoor clay?
Muggydude is offline   Reply With Quote
Old 12-21-2011, 10:09 AM   #4555
-WHEELMAN-'s Avatar
Trader Rating: 266 (98%+)
Always stepping up your game JC!!! I am sure your warehouse with all this product must be a madhouse!!!!!!! Keep up the good work!!!!!
BRETT T. RICHARDS = SUPPORT YOUR TROOPS, LOCAL TRACKS AND HOBBY SHOPS OR THEY COULD ALL BE GONE ONE DAY!
-WHEELMAN- is offline   Reply With Quote
Old 12-21-2011, 10:24 AM   #4556
When can we start preordering chevy 1500 sc body??? And will they be similar to the x flow raptor bodys as far as venting them??
rickybobbyxxx is offline   Reply With Quote
Old 12-21-2011, 10:45 AM   #4557
Jmuck69's Avatar
What board is that? Where on the JC website can I find it?
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 12-21-2011, 10:57 AM   #4558
PW
PW's Avatar
I personally haven't tried them on that surface, but I would imagine even more grip. Unfortunately tire wear will be a little more in those conditions. I've run them on indoor tracks like Trackside, Mike's Hobbyshop, West Coast and they were awesome. Those tracks are damp/wet hard packed brown dirt surfaces popular in the northeast and mid west. I've also run them on outdoor slick groove or dusty groove surfaces with great success.
Thanks and yes
I'm not 100% sure, but we are working on the press release now. So it should be really soon . Yes, there will be panels that can be cut out for venting.
Paul Wynn
Old 12-22-2011, 08:35 AM   #4559
When will the Pressure Points be at A-Main? I have a huge order coming from them soon and might as well throw them in there as well, no need in spending extra on shipping.
Thanks.
God Bless!
Dave Richer
Rocket Tire Services
**Team HVR**
**Team C Racing**
Team RTS is offline   Reply With Quote
Old 12-22-2011, 08:41 AM   #4560
PW
PW's Avatar
Thanks.
I believe A-Main already has some in route .
Paul Wynn
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
