JConcepts Thread
#4321
I agree J Con has the best CS I have dealt with. Even operator errors are treated with the same respect.
#4322
My outdoor short course racing season is over today. My only tires on the front for the season were dd's, and for the rears I'd switch between dd's and calibers. I like the dd's, but more than half the lugs are ripped clean off, and my calibers look brand new. Both of the sets have seen the same amount of use. Should I buy another set of dd's and hope they hold up? Or try something new?
Thanks;
Josh
Thanks;
Josh
#4323
Super Moderator
Trader Rating: 31 (100%+)
We really need a 2.2 Stadium Truck CC foam, those produced by another company leave a lot to be desired..
#4324
Thanks;
Josh
Thanks;
Josh
Eventually tires wear out...
#4326
Thanks;
Josh
Thanks;
Josh
#4327
The gears are machined instead of molded; this gives you a much truer running gear for better gear mesh. The slipper-pad is also captured in a deeper pocket that better holds the pads. The gear also has markings to tell you what tooth count it is without removing.
They are in transit via slow boat; so a couple more weeks.
I also wanted to comment on your tires. I've been mounting a bunch of new rubber as of late and I've noticed that your tires mount and balance so much easier it's rediculous. Thank you!
#4328
New Hex wheels for 1/10 scale
Just wanted to see if there any updates as to when these will be available? Also, are they always available on the JC site before anywhere else? thanks!
#4330
The JC site normally has them a few days early.
#4333
#4334
What size wrench is needed for the 8/32 and 4mm SCT wheel nuts? I plan to get a set for both my SC10 and SC10 4x4.
#4335
