Like Tree38Likes
Old 06-10-2008, 10:50 AM   #1891
MOmo's Avatar
So I was looking through the tools and since most people share the difficulties in accessing the motor Screws, I wondered what "tool" is receommended. Someone told me they make a wrench that makes it easier to get at the motor screws.
MOmo
RACE CARS: B44.1, RC8.2E FT, RC8TE ME, YZ-2T, D08
RADIO: Futaba 4PKS/3PKS. BATTERY: Venom
ESC: SpeedPassion. MOTORS: SpeedPassion / Venom
"Im not a racer, but I play one on the Internet"
MOmo is offline   Reply With Quote
Old 06-10-2008, 10:54 AM   #1892
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Originally Posted by MOmo View Post
So I was looking through the tools and since most people share the difficulties in accessing the motor Screws, I wondered what "tool" is receommended. Someone told me they make a wrench that makes it easier to get at the motor scres.
MOmo
Maybe a ball end hex driver ?
The jconcepts tools are pretty dialed. The bigger metric ones are ball end and work great for tight angled spaces.
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 06-10-2008, 12:04 PM   #1893
Davidka's Avatar
Trader Rating: 75 (100%+)
Ball ends are handy but for motor screws it's best to use them for setting the mesh and then use a good ol' L-shaped hex wrench to snug them down. The ball head has much smaller contact with the screw and can strip the heads easily. If you're talking about 2wd vehicles then it's easiest to remove the right rear tire so its not in the way.
Old 06-10-2008, 12:18 PM   #1894
carbon madness's Avatar
I think they are talking about the BJ4 WE/ B44.
Normally what I do is remove the battery holder and the posts, then pop a ball cup off in the rear, and you can fit a normal hex wreanch in without a problem. (it might seem like a lot of work, but it is worth it as it is really simple to get to the motor then.
マイクル ユージャック
*Team CFX Racing**Evil 3 Paint Works*
carbon madness is offline   Reply With Quote
Old 06-10-2008, 01:20 PM   #1895
Trader Rating: 80 (100%+)
Send a message via AIM to cpatel529 Send a message via Yahoo to cpatel529
Will the JConcepts high down force B44 body and undertray fit on the non-worlds BJ4?
Chirag
Chirag Patel (San Diego, CA)
cpatel529 is offline   Reply With Quote
Old 06-10-2008, 01:28 PM   #1896
MOmo's Avatar
Normally i use the L shaped hex, but I never seem to get a solid fit. Also, I run Lipo and I have extended battery posts. The angle is just awkward enough to get a long handle wrench from the end.
Chirag,
I would think it should fit. Amain should have the body for your BJ4. I need to look at something different I got my motor too hot and need to cool my motor and ESC better.
MOmo
Old 06-10-2008, 02:19 PM   #1897
Trader Rating: 14 (100%+)
The best way to tighten the motor screws on the bj4 we and the b44 is to use an angled hex wrench. But you will probably have to cut a little off it. This is what I did. Pretty much I cut about 3/16th of an inch off the short end and it fits between the battery posts and the motor.
trilerian is offline   Reply With Quote
Old 06-10-2008, 03:53 PM   #1898
d16dcoe45's Avatar
Originally Posted by Davidka View Post
The rears have the same offset as AE and Losi, they are meant to be compatible.
The only issue I have found using the Rulux on the rear of a Losi is that the recess of the wheel doesn't quite reach the shoulder on the Losi axle. This means that if you tighten the wheel on fully the wheel will be able to flop around a bit. Just put a very thin washer under the ny-lock wheel nut when installing the wheels.
Also about the handling difference--maybe its an issue of wheel stiffness? It might be that the Rulux are silghtly stiffer which can affect the handling? Anybody?
Jay Lestingi
Tamiya 419x/Associated TC7.1/Sanwa M12s/Xpert servos
d16dcoe45 is offline   Reply With Quote
Old 06-11-2008, 12:44 PM   #1899
AndyMoore's Avatar
Trader Rating: 53 (100%+)
Send a message via AIM to AndyMoore
Originally Posted by totally losi View Post
Does any one know when and where the Jconcepts race is for the 2008 season? I think last year it was the first week of Dec in tampa, fl.
The 08 Clash will be December 12-14 at the Coral Springs track here in Florida. We are working on updating the website and finalizing race details at the moment.
Originally Posted by What up? View Post
Just ran the Bar codes for the first time on the new track in Huntington CA with Red Losi Block heads in the front, Great combination until the front Bar code is released. Ended up TQing and winning the main with this combo, and the car just felt great the whole night and had very little tire wear.
Great job JC on putting together some good tires for us to use.
Good job, we appreciate your support!
Chirag
I know the body fits, but there is space between the rear of the chassis and the body due to the difference in battery layout. I cant speak to the fitment of the undertray, but I imagine it would fit the same, again with some extra space in the rear.
|JConcepts|Winning Edge Designs|
AndyMoore is offline   Reply With Quote
Old 06-11-2008, 05:19 PM   #1900
AndyMoore's Avatar
A quick ROAR Fuel Buggy Nats Vid:
http://ca.youtube.com/user/JConceptsRacing
http://ca.youtube.com/watch?v=9VwLEAfjqzU
Old 06-15-2008, 02:36 PM   #1901
AndyMoore's Avatar
Happy Fathers Day!
Old 06-15-2008, 06:23 PM   #1902
Suspended
Andy have you seen the thread I started about molded inserts for 1/10th scale buggies? It seems to be getting alot of attention. I'm just sayin'.
R.I.P. Grimace360
ifuonlyknew is offline   Reply With Quote
Old 06-15-2008, 06:44 PM   #1903
RURC's Avatar
I watched Paul Winn lock up the Florida TC Mod championship today. Great job Paul.
Michael
3 Phase Racing///Schumacher///Max Amps///TigerMoth Racing
Team Tekin ///FMC lipo chargers///Neu Motors///Multiplex
McAllister Racing///Lauterbacher
Real racers dont wear boxers.
RURC is offline   Reply With Quote
Old 06-16-2008, 03:45 PM   #1904
pq49z's Avatar
Default rounders
any idea when rounders will be back in stock?
pq49z is offline   Reply With Quote
Old 06-16-2008, 05:30 PM   #1905
AndyMoore's Avatar
We dont miss much.
It may be a week or two before they are back on our website. Perhaps a web retailer has them in stock currently? amain/tower?
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
