Like Tree38Likes
Old 04-24-2008, 07:37 AM   #1696
d4man's Avatar
Is anyone going to answer my question about Ultra Stiff Inserts like Trinity *used* to make??????????
The greatest trick the devil pulled was convincing the world he didn't exist...
I always thought I had a pretty good imagination, but it turned out to be just my imagination.
NOT a member of Team Terribles!
d4man is offline   Reply With Quote
Old 04-24-2008, 07:39 AM   #1697
Trader Rating: 23 (93%+)
BJ4 Direct Shaft Kit kit can this work with a one way or not i dont fully understand it. thanks
afish is offline   Reply With Quote
Old 04-24-2008, 05:07 PM   #1698
J_P
J_P's Avatar
Yes. The direct shaft replaces the one way shaft. The shaft used to have one way bearings, so the front shaft would spin freely. Originally, this was for three ways of set up. One way shaft- One way Diff- Direct shaft. Also, with the direct shaft, you could go diff, or One way diff.
You will have to find what works for you. Depending on track. How much you need brakes. And what you personally like.
JConcepts * Associated * Reedy
J_P is offline   Reply With Quote
Old 04-24-2008, 07:12 PM   #1699
Jason Ruona's Avatar
At this time we don't have an insert planned that would be that hard.
What tires did you use these hard inserts with in the past? I believe I used them in slicks a long time ago.
Jason Ruona is offline   Reply With Quote
Old 04-24-2008, 07:16 PM   #1700
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
how bout molded inserts for 10th scale? especially for fronts
_|Team Academy GV2 Pro_|_Team Academy SBV2 Pro|_--->Losi xxxbK2 (FOR SALE)
_|Factory Tracks Midwest Series_|_www.factorytracks.com|_
_|Team Upgrade-RCid_|_www.upgrade-rc.com|_
_|MRC/Team Academy_|_www.modelrec.com|_
rdub202 is offline   Reply With Quote
Old 04-24-2008, 08:29 PM   #1701
so if i used that would it still be a one way and i just would have all 4 tires breaking
Old 04-24-2008, 09:36 PM   #1702
AndyMoore's Avatar
Trader Rating: 53 (100%+)
Send a message via AIM to AndyMoore
The direct shaft entirely replaces the center one-way assembly, and all 4 wheels will brake.
|JConcepts|Winning Edge Designs|
AndyMoore is offline   Reply With Quote
Old 04-25-2008, 05:41 AM   #1703
PW
PW's Avatar
Send a message via AIM to PW
Unfortunately they don't work very well.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 04-25-2008, 08:00 AM   #1704
d4man's Avatar
When we race indoors during the winter we used the "old" Trinity Bomb One Blue (Ultra Stiff) inserts in our Pink Taper Pin slicks.
Trinity has now come out with an insert that is hard as concrete and requires massive amounts of time to dremel and shape the insert.
I was hoping JConcepts would come out with a Foam that was the equivalent of the "old" Trinity Bomb One Blue before Trinity changed the foams. Thank you!!
Old 04-25-2008, 08:35 AM   #1705
johnnyboy's Avatar
Trader Rating: 28 (97%+)
The Goosebumps seem to hold up well. Very little wear from a full weekend on a dry hard packed clay track.
"Almost Live Race Coverage": www.johnnyboy.ca
.:Team Orion : JConcepts : B-Fast RC:.
johnnyboy is offline   Reply With Quote
Old 04-25-2008, 11:15 PM   #1706
TheOldBoy's Avatar
Send a message via MSN to TheOldBoy
Is there a hobby shop in Australia that sells the goosebumps?
On our track, when it's dry and dusty, only hope you have of traction are bowties. When some moisture in the track, bowties again, although losi step pins did perform there when moisture was up, but they went away as track dried out. Would be intersted in trying those goosebumps out going by the feedback on them so far.
Founding Member of TMORC, Nov 1984.
Lies and karma will catch up to those who are dishonest or continually try to blame others for what they have done and it is those legal action is pending, nothing more, nothing less.
TheOldBoy is offline   Reply With Quote
Old 04-26-2008, 10:30 PM   #1707
J_P
J_P's Avatar
Sounds like it is the tire you need. I'm sure you will find some soon.
Old 04-27-2008, 03:17 AM   #1708
nhodd's Avatar
Send a message via Yahoo to nhodd
Default tyres
Hey those tyres look wicked and i will have to get one of those new t4 bodies
nhodd is offline   Reply With Quote
Old 04-27-2008, 05:52 AM   #1709
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
What's up with the Rulux rims not being able to use Losi tires because of molded in rib on the inside of the wheel being more narrow? The only way to mount them is to cut the tires inside rib more narrow.
Dasupacat1 is offline   Reply With Quote
Old 04-27-2008, 09:13 AM   #1710
RCBLUE's Avatar
Which also the same thing you should do with Losi tires on AE or Proline wheels too. I've been cutting the inside bead for years.
Don't sweat the petty things...........Pet the sweaty things!!
Serpent America
Lunsford Racing
RCBLUE is offline   Reply With Quote
JConcepts BJ4 Funkymojo R/C Items: For Sale/Trade 11 03-28-2006 11:04 AM
WTB: JConcepts BJ4 goldberghere R/C Items: Wanted to Buy 0 03-20-2006 08:06 AM
FS: JConcepts BJ4 cnk R/C Items: For Sale/Trade 14 11-22-2005 09:48 PM
[FS] JConcepts BJ4 - NEVER RUN TBone77 R/C Items: For Sale/Trade 5 10-27-2005 03:23 PM
FS/FT: Jconcepts BJ4 $425.00 skriete R/C Items: For Sale/Trade 3 10-25-2005 06:54 PM
